Old 05-20-2013, 11:00 AM   #1
canadasax OP
canadasax's Avatar
Oddometer: 345
Mode and reset buttons not working
My set and mode buttons are starting to act up.
Sometimes I have to press the button or buttons 10 or 12 times before it will work.
I like to reset my mileage every time I refuel. (Often on this bike)
Has anyone taken one of these things apart to clean the contacts or something.
canadasax is offline   Reply With Quote
Old 05-20-2013, 11:09 AM   #2
Waterbaby
Oddometer: 102
Mine does the same thing I unscrewed the 4 screws took the top plate off and pushed the contacts and it worked fine put the lid back on but it still didn't work, I to will be interested if there is a fix for this
Waterbaby is offline   Reply With Quote
Old 05-20-2013, 04:14 PM   #3
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 932
In the 950, i had the remote button group and the information on the dash wash going crazy, often pressing the buttons on the dash would not do anything. It was one of the buttons on the remote that was stuck pressed and messed up everything...
Unfortunatly couldn't be fixed... broken pcb
690R
Old 05-20-2013, 08:30 PM   #4
Deepc
Oddometer: 299
unscrew the 4-bolt housing and do a little troubleshooting. Its a pretty basic setup. You might just need a little silicone spray on the rubber buttons. Good luck.
Deepc is offline   Reply With Quote
Old 05-21-2013, 04:43 AM   #5
Kobus Kruger
Oddometer: 7
I also had this problem, only on the "Mode" button.
I was about to install the "Rally" tripmaster switch on handle bar when I decided to remove the 4 screws.
I sprayed some Q20 on the contacts of the switch and then the "mode" was back working again, I was amazed. So yes sometimes it is as simple as to spray some contact cleaner on the switch.
For info here is link to DIY tripmaster switch: http://www.wilddog.za.net/forum/index.php?topic=79728.0
Kobus Kruger is offline   Reply With Quote
Times are GMT -7.   It's 08:01 AM.
