Old 05-20-2013, 03:57 PM   #1
ToddLite OP
ToddLite's Avatar
Oddometer: 108
950SE running rich?
So after a few rides on my new-to-me '07 950 SE I'm pretty sure the bike is running REALLY rich. Symptoms include:
- able to start w/ little or no choke
- ZERO popping on deceleration (never, not even once)
- black crud at the exhaust
- here's the kicker - I'm getting max 25-26mpg. Doesn't matter on/off road, easy highway cruising or tearing it up, whatever. 25-26mpg max.
Bike seems to run great to me - no weird stalling or idle issues - with the exception that very rarely on a low gear hill climb or something I chop the throttle at the top it might seem to bobble and "almost" stall. After copious amounts of searching this forum it sounds like to improve the mpg I need to check/modify:
- air filter isn't clogged/filthy
- float heights (lower?)
- needle heights, jet sizes, etc.
I am far from a mechanic but reasonably handy so I was going to look into the carb configuration (with the assistance of a knowledgeable buddy). Any other recommendations prior to tearing into the carbs? easy things to check, etc?
For the record, there have been a few diff exhaust configurations in its history. First stock then a 2-into-1 config and now it's been returned to a dual Wings exhaust with the "quiet end caps" in. PO claims he was getting 35mpg prior to selling it to me and is unaware of any re-jetting being done...
Any other thoughts from the experts out there? I'd welcome them...
ToddLite is offline   Reply With Quote
Old 05-20-2013, 04:06 PM   #2
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,051
Dirty filter is easy to see and a big cause or something stuck in the intake snorkel.
Mixture screw settings will effect the bottom but more than likely jetting by the sounds of it.
Also make sure the carbs are synced together or one may be working harder.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 05-20-2013, 06:49 PM   #3
David37
David37's Avatar
Oddometer: 404
I have an 07 KTM 950SE, like Twhiteside clean the air filter or better yet replace the air filter and replace the plugs while you have the bike apart. If you're still running rich, take off the carbs, clean and check what jet sizes are in your carbs.
David37 is offline   Reply With Quote
Old 05-20-2013, 08:15 PM   #4
ToddLite OP
ToddLite's Avatar
Oddometer: 108
Right on thanks guys that's what I figured... Thanks for the insights!!
Old 05-20-2013, 08:41 PM   #5
Afry
Why hike?
Afry's Avatar
Oddometer: 620
Huh?
KTM 950 SE
Yamaha TDR250
CRF450 flat tracker
Get on with riding or get on with dying - one or the other
Afry is offline   Reply With Quote
Old 05-20-2013, 08:57 PM   #6
corndog67
Oddometer: 1,281
Get it on a dyno and put a sniffer in the pipe. Hard numbers. No guessing.
corndog67 is offline   Reply With Quote
Old 05-20-2013, 09:36 PM   #7
ToddLite OP
ToddLite's Avatar
Oddometer: 108
I've actually thought about that but have never done that before... Have no idea how much something like costs or even where to go. Will certainly research and consider...
Old 05-20-2013, 10:42 PM   #8
corndog67
Oddometer: 1,281
Well, at our local bike night, they put my Duc on there, one baseline run with sniffer, was $35 or $40. Cracked me up when "130 Cubic Inch, 130 HP, 130 lbs of torque" loud guy got called on the spot, dyno guy said, "Let's pull it and see..." and he agreed. It pulled 92 HP and 102 lbs of torque, my 916 pulled 95 HP and 67 lbs of torque, and the dude asked me how big it was, "900 ccs. Your bike just sucks, what is it, 2000 ccs?" He didn't like that.
Seriously though, a sniffer on the dyno will tell volumes about how well tuned it is.
Old 05-21-2013, 12:18 AM   #9
TrentW
MMmmmm....
TrentW's Avatar
Oddometer: 87
It could be something as simple as the Choke cable(s) not seated properly in the carbs / junction box, thus the choke is partially on at all times.
TrentW is offline   Reply With Quote
Old 05-21-2013, 04:39 AM   #10
charlie264
charlie264's Avatar
Oddometer: 8,366
Howdy Trent....still got the SE?
Old 05-21-2013, 05:58 AM   #11
HooliKen
Awesome is a flavor
HooliKen's Avatar
Oddometer: 3,014
Originally Posted by Afry View Post
Huh?
My thoughts exactly.
Are you the original owner? If not did the PO do an jetting. I will second that you should check enrichment circuit on both carbs. And in lieu of running on dyno with sniffer, pull plugs, they will tell you volumes about how you are running
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is offline   Reply With Quote
Old 05-21-2013, 09:05 AM   #12
triplenickel
triplenickel's Avatar
Oddometer: 2,430
I wouldn't waste money on a dyno there's enough proven documented combos here, but figure out what you have now first after you check the basics.
07 SE
PG007
Old 05-21-2013, 09:56 AM   #13
ToddLite OP
ToddLite's Avatar
Oddometer: 108
sounds good guys - thanks for all insight. Jetting history is unknown at this point as the PO didn't do anything (and he was the 2nd owner) so getting a look at the current config is definitely a need. I'd like to start out with the simple stuff before really taking things apart... and for $40 or so bucks I'd be intrigued by the dyno/sniffer results. Will consider once I get a handle how it's currently configured...
thanks again all
Old 05-21-2013, 12:45 PM   #14
TrentW
MMmmmm....
TrentW's Avatar
Oddometer: 87
Aye. It's soon to be winging it's way to NZ though... permanently. Can't wait...
Old 05-21-2013, 01:44 PM   #15
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,051
May I ask, have you sold it to a Kiwi or are you moving there and if so where? there is only a handful in NZ now so adding one brings the percentages up quickly then we will bring ours home.
Times are GMT -7.   It's 01:16 PM.
