Old 06-11-2013, 09:03 AM   #136
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,660
Originally Posted by gefr View Post
photos?
OK!
Donnie - Retired & Riding - 2010 990ADV - 48,200 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 06-11-2013, 09:22 AM   #137
dwj - Donnie OP
Oddometer: 14,660
Originally Posted by dwj - Donnie View Post
After six or seven hours, two spokes started to leak. No problem, take the tire off and apply some more Goop. What did surprise me is that the silicon had continued to shrink or the air pressure pushed more of the silicon into the spoke threads. I believe the air pressure had pushed the silicone further into the thread area, because I have about 20 dimples in the different nipple areas that definitely were not there when the tire was mounted. So, I am adding a bit of Goop to those, in addition to the two that are leaking. I was pleasantly surprised when there were no leakers when the tire was mounted, but I don't see this as a problem. I just need to have it bullet proof by the time I leave for Mexico Thursday!
From what I see, even if you have no leakers when the tire has been mounted for eight hours, it may be wise to dis-mount and have a look or at a minimum, take a look before starting the next long trip.
I rode 200 miles yesterday with no problem, but the tire lost a couple pounds of air pressure last night. I sprayed the rim with soapy water, but did not see anything. Spraying the solution actually creates a little bit of bubbles, so I applied the solution with a artist brush and let it run into the threaded area. There, two more! I removed the rim and again found craters on some of the spokes, including the two that were leaking. I assume that the pressure is pushing the silicone into the nipple area because I know that the silicone is drying. This is not really a problem, just a learning experience. I don't leave for another 40 hours on a 7,000 mile plus, one month ride. Fixing the leak and doing the other 100 things I need to do before leaving should not be a problem!
Old 06-11-2013, 09:56 AM   #138
dwj - Donnie OP
Oddometer: 14,660
OK!
I un-did the bolts up top and looked again. The inversed dimple is where the inside plastic shield fastens to the quarter panel. The inside shield may barely touch the radiator cap from the bottom side. I can't find any thing putting pressure toward the outside that might make the area where the interior panel connects to the quarter panel bulge out. I feel confident that this has not been like this in the past. My experience with the plastic on Goldwings is that as they age, irregularities in the plastic surface develope. Is that the case with these motos, or am I missing something?
Old 06-11-2013, 02:38 PM   #139
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,004
Looks like it was banged from the inside with hot stud.
I have never seen anything like that. My bike had a contact with a car on that very fairing, the paint substrate cracked but the plastic regained its shape.
Old 06-11-2013, 02:55 PM   #140
dwj - Donnie OP
Oddometer: 14,660
I have no idea how that could have happened! I think it has developed recently and nothing has happened as far as I know.
Old 06-11-2013, 02:56 PM   #141
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,819
Nah.
I'm going with the nipple theory.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 06-11-2013, 02:58 PM   #142
dwj - Donnie OP
Oddometer: 14,660
Originally Posted by FakeName View Post
Nah.
It is more sexy, ain't it?
Old 06-12-2013, 09:22 AM   #143
dwj - Donnie OP
Oddometer: 14,660
In case anyone is interested, I will be heading out Thursday morning for a month in Mexico! I do not plan on doing a Ride Report, but here is a link to my SPOT Tracking Devise. I will have it on everyday unless I am not moving or I forget!
http://share.findmespot.com/shared/faces/viewspots.jsp?glId=08YfgyM3oIdvUmMIJWYP8AtBSgg9Y4C kA
Donnie
Old 06-12-2013, 10:13 AM   #144
Trail bandit
Random adventurer
Oddometer: 204
Donnie
That spot thing is so cool! Almost too good. Looks like it could show how long you spend in the crapper! Satellite image shows you went next door recently.
Yes, will check in.
Note... I've just jumped on bike with water pump done, oil changed and madstad screen and aeroflow side screens. All excellent
Trail bandit is offline   Reply With Quote
Old 06-12-2013, 11:10 AM   #145
dwj - Donnie OP
Oddometer: 14,660
Yes, will check in.
Glad all of your mods worked out. I remounted my tire this morning, it has not leaked any yet! At least I don't think it has! If it does leak anymore before in the morning, I will probably throw a tube in it and be gone!
Old 06-12-2013, 11:16 AM   #146
marcone
V-Stromer
marcone's Avatar
Oddometer: 39
OK!
I think your bike just hit puberty
marcone is offline   Reply With Quote
Old 06-12-2013, 04:12 PM   #147
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 702
I keep a front tube right there kind of looks like a valve stem. are you the only owner? maybe it has been there from the last guy? just a thought
BigNastybrp is offline   Reply With Quote
Old 06-12-2013, 04:20 PM   #148
dwj - Donnie OP
Oddometer: 14,660
I am not the original owner, but I have owned it for over two years and only recently have noticed it. Being that it is fairly obvious, I can't believe that it has been there all along and I didn't see it. The "protrusion" is where the inner fairing screws into the outer fairing. It is as if something pushed it from the inside, but I can find no pressure points behind the fairing.
Old 06-13-2013, 06:51 PM   #149
dwj - Donnie OP
Oddometer: 14,660
My list for updates, spares, modification include:
CJDesigns SS Oil Drain Tube with my modification- Completed
Spare Fork Seal - On Moto
Adjusting Steering Stops - Completed
Convert Rear Wheel to Tubeless - Completed 36 hours and 500 miles and no leaks!
Anti Siege the Axle Adjusting Bolts - Completed
Trim Mudguard that is hitting Swingarm - Completed
Drill Drainage holes in Swingarm - ???
Loctite and Torque Screws on Plastic Chain Slider protector - Completed
2 Fuel Filter Kits from gefr - order when I return from Mexico - install one upon arrival and have other as a spare, establish as 20,000 - 30,000 mile PM
Spare fuel pump from gefr - order when I return
Order Water Pump rebuild kit from ???
Purchase Crashbar Bags from akarob???
Purchase under seat tray from hontri - when I return
Please offer advise as to included items and/or items to include.
Old 06-13-2013, 07:43 PM   #150
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,466
Kick Ass Upgrading!!!
You're really doing your bike right!!!
You're gonna have a great trip and will be extremely well prepared.
You should definitely go with the CJ hardened waterpump shaft and impeller upgrade kit... Others like AdvMachines can get it for you if CJ is still moving his shop.
Great job sticking with your tubeless rear conversion. That's a great choice (your persistence taught me I panicked too soon on my first try. I'll give that a second try after I wear down my rear shoe ).
You've mentioned nothing about camping gear. Wondering what your preferences are here?
Cheers...
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is online now   Reply With Quote
Times are GMT -7.   It's 02:59 AM.
