Old 07-27-2013, 04:27 AM   #301
Trail bandit
Random adventurer
Oddometer: 204
Originally Posted by DirtJack View Post
It's in the 950 HOW (like most orange info ). cleaning the clutch oil jet.
Cjdesign sells an oil jet with slightly larger diamater and most importantly it is shaped like a cone so rubbish falls to the side. The original is a completely different story. It has a larger diamater hole for catching rubbish to make sure there is some available to block the jet.
Further...... I met Craig and asked him why he thought my Rekluse might be shuddering. Oil jet! The clutch was also incredibly noisy. Pull in the clutch at idle and noise went.
Solved. Shudder gone and I've swapped Rekluse to new 990 and the older bike is no longer noisy.
Trail bandit is offline   Reply With Quote
Old 07-27-2013, 05:21 AM   #302
farrell caesar
Seezer
Oddometer: 415
Ktm
Hey Donnie. Hell of a thread. I've been thru the gauntlet too. Shit, we don't need no validation. God bless the child whose got his own. Saludos, mi amigo, my brother from another mother.
seezer
farrell caesar is offline   Reply With Quote
Old 07-27-2013, 05:24 AM   #303
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,908
Hola!
Donnie - Retired & Riding - 2010 990ADV - 51,036 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 07-31-2013, 02:27 PM   #304
dwj - Donnie OP
Oddometer: 14,908
Here is the photos of the 27,000 plus mile fuel filters:
Do you think I could have used them a little bit longer?
Old 07-31-2013, 08:02 PM   #305
Rockwell
Rockwell's Avatar
Oddometer: 670
I've got about 52,000km on my original fuel filters. Just got my new ones from gefr in the mail. Just need to find the time to change them.
Sent from my Nexus 7 using Tapatalk 4 Beta
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 07-31-2013, 08:57 PM   #306
dwj - Donnie OP
Oddometer: 14,908
I knew I should have run them a little longer! I did know that water had gotten in my gas because the right drain hose was kinked and it rained a lot on the trip! I will make it a 20,000 PM on mine, plus carry spare filters. My replacements were from gefr as well!
Are you on the original Water Pump seal?
Old 08-01-2013, 12:40 AM   #307
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,082
I suggest you PM your clutch master/slave cylinders.
http://advrider.com/forums/showthread.php?t=171986
http://advrider.com/forums/showthread.php?t=655984
The slave cyl tend to get a small crack. The later models have a larger ball in the piston, so forces distribute smoother but the clutch is harder to pull.
Some master cyl were reported to develop wear lately. This is not very often, but can be a pain.
Cheers.
gefr is online now   Reply With Quote
Old 08-01-2013, 03:33 AM   #308
Rockwell
Rockwell's Avatar
Oddometer: 670
Originally Posted by dwj - Donnie View Post
[COLOR=darkorange]
Oil was leaking into the cooling system at around 10,000km. There were no signs of coolant in the oil though (no wavy oil filter). I did the water pump rebuild which solved the problem.
Old 08-01-2013, 05:11 AM   #309
dwj - Donnie OP
Oddometer: 14,908
Cheers.
Mine was not leaking, but I changed the O-Ring a couple hundred miles ago.
I am thinking of changing the shaft and seal, but not the bearings. Mine is not leaking, but at 27,000 plus miles, I guess it is past due and I would rather not do the first one on the road.
Old 08-05-2013, 05:26 AM   #310
dwj - Donnie OP
Oddometer: 14,908
I am still waiting on the Insurance Company!!! I have to vacate my house by August 28 and be living off the moto. Things need to get moving!!!
Old 08-05-2013, 03:43 PM   #311
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 576
Good info here.....Been seeing a few 950's and 990's with anywhere from 25k to 50k and I too was wondering how many miles before a rebuild. Soon I'll be seriously looking to downsize from 3 bikes to one, and pulling the trigger on a 950 or 990.
Slideways#96 is offline   Reply With Quote
Old 08-05-2013, 05:39 PM   #312
renogeorge
Oddometer: 1,425
I can't compete for the high mileage award. But I just sold a 950 SM with 32k miles. WP at 12k. Fuel pump replaced at 15 without having failed. Valves still in spec.
Now an '07 990 Adventure with 35k miles. Just changed original clutch slave for a trip to Alaska--had not failed. Changed fuel pump and filters with GEFR parts--had not failed. Valves had moved only slightly 1-2 shim sizes.
My spares for long out of country travel would be:
Fuel pump and 2 sets of filters, clutch slave, brake rebuild kits, brake pads, WP kit...
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 08-05-2013, 06:04 PM   #313
dwj - Donnie OP
Oddometer: 14,908
FWIW
Why the brake rebuild kits?
Old 08-05-2013, 06:26 PM   #314
renogeorge
Oddometer: 1,425
The brake rebuild kits are cheap and don't take up much space. And they would be hard to outsource. I have freshened up a few on my KTM dirt bikes and on the SM. The scenario would be one where your brakes started to get spongy and wouldn't bleed out. probably not a catostrophic failure but i am sure you know that. From my experience the KTM brakes are no more or less prone to brake problems than any of the Jap bikes. Never had a BMW but some of them have brembo brakes as do the KTMs.
Don't read any big problem into my comment--just my thinking as to the kind of travel you plan.
KTMs--300, 518, 990
Old 08-06-2013, 07:55 AM   #315
dwj - Donnie OP
Oddometer: 14,908
OK! Thanks!
Times are GMT -7.   It's 12:48 PM.
