Old 05-21-2013, 05:55 AM   #1
Muddler OP
Muddler's Avatar
Oddometer: 751
DRZ400E Bearings, Seals etc
Did my wheel bearings and seals the other day and was surprised there wasnt a lot of info on the web. Therefore I thought I would get a bit of a list going. Im no expert, so if you contribute/correct me, I'll update the first post (can I do that?). Thanks to SteveROntario for his info. If this is a dumb idea I'm sure I'll be told .....
Rear Wheel Bearings
6004 2RS 20mm x 42mm x 12mm (x2)
6204 2RS 20mm x 47mm x 14mm (x1)
Front Wheel Bearings
6904 2RS 20mm x 37mm x 9mm (x2)
Rear Wheel Seals
29mm x 42mm x 6mm
29mm x 47mm x 6mm
The're supposed to go in backwards, to keep water OUT. Not everyone agrees, so you make your own choice...
Front Wheel Seals
BE 3444E 7 25mm x 37mm x 7mm (LHS)
BJN43587-C3 55 (Speedo)
Fork Seals
Gearshaft Seals
Countershaft Seal
MHSA 30 50 5 34
Fork Seals
Sump Plug Washers
#09168-10002 10mm x 14mm x 3.6mm (x1)
#09168-12002 12.1mm x 16.2mm x 3.7mm (x1)
Muddler screwed with this post 05-22-2013 at 08:10 AM
Muddler is online now   Reply With Quote
Old 05-21-2013, 06:27 AM   #2
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,648
I'm grateful when someone shares the wisdom.
plugeye is online now   Reply With Quote
Old 05-21-2013, 09:24 AM   #3
AtlasExp
beer me
AtlasExp's Avatar
Oddometer: 433
Thanks man!!!!! On the front I just purchased this item http://www.ebay.com/itm/330923922587...84.m1497.l2649 Link going to die some time so I will post pics and name of the item for peaple who will need it!
When to use this? When you not using original speedo or you hate to know how fast you r going!
Dual Sport Luggage Racks for: DRZ-S, SM and E and KLR650 and DR650: http://www.moto-racks.com/ Find me on Instagram " ahtoxa007 "
AtlasExp is offline   Reply With Quote
Old 05-21-2013, 09:57 AM   #4
revmaaatin
Sioux Empire Iron Horse
revmaaatin's Avatar
Oddometer: 341
[QUOTE=Muddler;21455459]Did my wheel bearings and seals the other day and was surprised there wasnt a lot of info on the web. Therefore I thought I would get a bit of a list going. Im no expert, so if you contribute/correct me, I'll update the first post (can I do that?). Thanks to SteveROntario for his info. If this is a dumb idea I'm sure I'll be told .....
Rear Wheel Seals
29mm x 42mm x 6mm
29mm x 47mm x 6mm
Wow.
Who knew?
I just installed a new tire on my new to me bike and was amazed that the seal garter spring was 'visible' or installeld 'backwards'.
Of course, I assumed it was wrong, removed the seal, lubed the bearing and reversed the seal.
Now looking at page 221, Fig 14 of the Clymers,
Yes, Virginia,
Muddler is 100% right--
the garter spring is suppose to be showing.
Looks like I get to do it over.
Thats what I get for not consulting the manual when I had the opportunity. grin.
Thanks for posting this great tip.
martinearl.
revmaaatin.
Methodist Circuit Rider
Iron Horse in the Sioux Empire
...fine is the line between foolishness and daring....Paul Vasey Rivers of America
revmaaatin is offline   Reply With Quote
Times are GMT -7.   It's 06:08 AM.
