Old 05-21-2013, 07:23 AM   #1
Orangecicle OP
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,704
Low fender carnage
I was on the Great River Gravel Ride this past weekend when my knobbie front picked up a rock that took out my front fender. Before the carnage:
And then the photos from the trail {photos courtesy of ROKKLYM}
Luckily, I had switched out the old style crossover brake lines to the modern "S" type lines a year or so ago. http://advrider.com/forums/showthread.php?t=763632 That made all the difference. If I had had the old style lines on, no doubt that I would have gone down hard. As it was, I just did a little trail surgery, added a few zipties, and I finished the 270 mile gravel ride before riding about 250 miles to get home the next day. If I had the old style lines on the bike, the bike would not have been ridable.
So, if you have the old style brake lines, you really should changed them. Thanks ROKKLYM!!!
Orangecicle is offline   Reply With Quote
Old 05-21-2013, 07:54 AM   #2
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,735
Yes if you hadn't swapped brake lines you would have ended up taking a Lost Rider inspired header. Lost Rider (Advhandle) on his F800.
BMW F800 GS Crash from Lost Rider on Vimeo.
v8toilet is online now   Reply With Quote
Old 05-21-2013, 07:57 AM   #3
Orangecicle OP
Quest Adventurer
Oddometer: 2,704
Originally Posted by v8toilet View Post
Yes if you hadn't swapped brake lines you would have ended up taking a Chitown inspired header. Chitown/Lost Rider on his F800.
I figured out how to make the change on my bike after seeing that video and experiencing a discernible puckering in my nether regions just from watching it. Thank you Lost Rider!
Old 05-21-2013, 08:09 AM   #4
Rally_West
Central Scrutinizer
Oddometer: 142
Holy crap that video is horrific. I ride in the Ca dez all the time (mostly on my EXC) and pick up rocks and wire and stuff all the time. I have always been a little concerned about air flow, oil tank and header protection, but I have recently thought more about going High fender on the 990.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Old 05-21-2013, 12:04 PM   #5
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,496
It was snotty mud that ripped mine off.
Luckily it was gooey and snotty enough that I was only going about 20mph at the time, struggling with slip-sideways balance...
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 05-21-2013, 12:10 PM   #6
Frog uk
Oddometer: 277
Time to fit the high fender then?
Frog uk is offline   Reply With Quote
Old 05-21-2013, 12:19 PM   #7
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,496
Obviously, these events were at least a couple of rides PAST the BEST time to fit the high fender
For the price of a high fender and fork guards (under $80 IIRC), it would be quite silly to buy a new replacement low fender,
....and risk a "Lost Rider" off
Old 05-21-2013, 12:32 PM   #8
Frog uk
Oddometer: 277
Here's mine.
Old 05-21-2013, 12:55 PM   #9
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
Had the newer style brake lines with the old fender, two small holes and some small zip ties holding them in place close to the location where there are tabs on the newer style fender.
Since its up I have a newer style brake line with the plastic piece that holds it to the lower triple clamp and clips to hold speedo sensor cable.
That was mounted on a 2006 S model with 245 suspension.
Had to extend after for the 320mm suspension and have now routed them on the outside of the fork legs.
Was planing to put the old up for auction and 50% off any money would go toward my try to raise some money for charity.
A new OEM setup is quite expensive.
Have just not gotten around to put up anything in the flea market yet.
If interested dont spam this thread about it PM me.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 05-21-2013, 01:00 PM   #10
Orangecicle OP
Quest Adventurer
Oddometer: 2,704
Here's mine.
Which fork guards are those?
Old 05-21-2013, 01:06 PM   #11
Frog uk
Oddometer: 277
Sx80 I think, all the details on H.O.W.
Old 05-21-2013, 03:51 PM   #12
Orangecicle OP
Quest Adventurer
Oddometer: 2,704
The first piece of the puzzle is on the way:
Now I just need to source some cool fork guards.
Old 05-21-2013, 03:58 PM   #13
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,453
I was wondering how you kept from ripping apart the brake lines!
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Chad Berger DR650, KTM 990 Adventure R
Lone Wolf Expeditions
rokklym is offline   Reply With Quote
Old 05-21-2013, 04:26 PM   #14
Orangecicle OP
Quest Adventurer
Oddometer: 2,704
You and me both! The "S" brake lines were zip tied to the original fender with very small zip ties. When the fender rotated forward it just snapped the zips. The fix for the rest of the day was just to ziptie the lines to the fork uppers.
My old setup ran the lines inside of the forks, but I think I'll move them to the outside when I get the new fork guards, like this:
Times are GMT -7.   It's 12:13 AM.
