Old 05-21-2013, 01:48 PM   #1
GoGoGavin41 OP
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 846
HDB Handguard Clearance with Risers
So I have some pretty big Rox Risers (not sure how big, they came with the bike). I'd love to put the HDBs with mirrors on, but my stock guards are pretty close to the windshield as it is. I know I've seen plenty of pictures of 990s with both, but I'm just curious how tight the fit is. I've already rolled the bars back pretty far and I'm just about out of throttle cable, so I don't know how much farther back they'll go.
Speaking of which, anyone have some used ones they want to sell me?
GoGoGavin41 is offline   Reply With Quote
Old 05-21-2013, 04:02 PM   #2
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
you can turn your throttle housing 180 degrees so the cables exit the bottom. That will give you the slack you need
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 05-22-2013, 01:18 PM   #3
GoGoGavin41 OP
Oddometer: 846
Great tip! I'll have to take a look at that, I'd definitely like to be able to roll them back a bit father.
Old 05-22-2013, 02:03 PM   #4
Oldebonz
Oddometer: 67
Rubber sheath is a tight fit against starter,kill control box when turned upside down.Slide it over cables before tightening the 2 8mm head nuts holding the 2 halves together. Also plug the drain hole so it doesn't fill up in the rain.Still might need to reroute throttle cables,had to take mine out of the cable guide to the left of the steering head (DIFFICULT!!) and then there was enough slack .You don't want all that power coming on when turning right in tight quarters!
Oldebonz is offline   Reply With Quote
Old 05-22-2013, 05:53 PM   #5
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
I use the drain hole to squirt some WD40 in there from time to time
My throttle is shmooooooth
Times are GMT -7.   It's 10:13 PM.
