Old 05-22-2013, 04:56 AM   #1
Hearse OP
Project n'gagi
Hearse's Avatar
Oddometer: 148
Seat upholstery studs...?
Hey guys,
Busy covering my seat...for those who have done this before, what are these metal studs around the seat material? I want some for mine but have no idea what I'm looking for.
My seats made of fibre glass so no staple guns for me :(
For reference
Thanks!!
Once I get this done I can update my build thread with the seat!! ;)
Project n'gagi begins 07-11-2012 -- Get involved!!
2006 Honda VTR1000f
1975 BMW R90/6
Hearse is offline   Reply With Quote
Old 05-22-2013, 07:04 AM   #2
Kanticoy
Oddometer: 322
Thumb
They are upholstery snaps with a screw base. You can find them a lot of different places. I know craft stores like Michaels and Hobby Lobby carry them. You can get them in stainless too.
http://www.ebay.com/itm/30pc-Screw-I...-/190797797685
Kanticoy is offline   Reply With Quote
Old 05-22-2013, 06:36 PM   #3
DaveBall
DaveBall's Avatar
Oddometer: 1,163
You can also get them at any shop that specializes in convertible tops as well as boat upholstery. I have used the stainless ones from a boat shop. The last time I was there, they even had ones that you could cover with the same material as what you are attaching to, which helps to hide them, if that is what you are looking for.
DaveBall is offline   Reply With Quote
Old 05-22-2013, 07:24 PM   #4
Plaka
Brevis illi vita est
Oddometer: 4,608
Originally Posted by Hearse View Post
Hey guys,
For reference
Thanks!!
I'm doing the same thing but I want leather. I'll have a pro sew the cover and glue it in place, then I'll finish it with copper rivits and burs (the big ones). Looks like a Brooks bicycle seat. You can use many kinds of rivets, check out belting rivets at the craft or leather place (check Tandy online), or suitcase rivets.
Old 05-22-2013, 08:36 PM   #5
Hearse OP
Project n'gagi
Hearse's Avatar
Oddometer: 148
thanks heaps guys!
I am just trying to locate some of them before the weekend. We have a few boat stores and leather places...try hit them up
I need the ones where the one end can be terminated in to fibreglass....screw in type or even bolt?!
I have a lot of googling to do :(
2006 Honda VTR1000f
1975 BMW R90/6
Old 05-22-2013, 09:53 PM   #6
Plaka
Oddometer: 4,608
thanks heaps guys!
Rivets go all the way through. Rivets and burs hafe a taper on the end of the rivet chank. The bur is just a copper washer. it goes over the rivet shank taper and then you peen the rivet. Other rivets can also be used with washers on the inside. You can hammer them pretty flat inside if you need clearance. Be sure you have a real smooth anvil on the outside to preserve the finish.
Old 05-22-2013, 10:26 PM   #7
Hearse OP
Project n'gagi
Hearse's Avatar
Oddometer: 148
Thanks Plaka,
So the above ebay link is the correct item I am looking for?
Screw the base in to the fibreglass and then cap through the leather?
2006 Honda VTR1000f
1975 BMW R90/6
Old 05-22-2013, 11:17 PM   #8
Plaka
Oddometer: 4,608
Thanks Plaka,
What link?
BTW, what do you want the thing to do? Hold on the seat cover or just look like it does?
Old 05-22-2013, 11:23 PM   #9
Hearse OP
Project n'gagi
Hearse's Avatar
Oddometer: 148
What link?
My original issue is that I have a ledge around the bottom of my seat that i need the material to wrap around...other than the snap on's or contact glue - i am not sure how i am going to secure my vinyl to the underside of my fibreglass?
does that make sense?
ill try get a picture to explain further?
picture - you can see around the edge, i want the material to wrap around that and terminate under the seat....any thoughts how to do it that will LAST? :)
2006 Honda VTR1000f
1975 BMW R90/6
Old 05-22-2013, 11:26 PM   #10
Plaka
Oddometer: 4,608
You're supposed to have a rim. it's a pan facing down.
You use contact cement to hold the material while you rivet from the outside. First through the outer cover, then through the 'glass, then through the edge of material that has been wrapped over the rim.
Stretch your cover on, warm if it's vinyl and press it onto the contact cement and wrap the rim.. Add some clamps as you go (mongo spring clamps or small C-clamps) to hold it while the CC grabs. With it in place and lying down nice lay out for your rivets and drill, putting a rivet in each hole as you go but only set them lightly. Then start setting the rivets for real and pulling the clamps.
Old 05-22-2013, 11:29 PM   #11
Hearse OP
Project n'gagi
Hearse's Avatar
Oddometer: 148
Cheers Plaka,
So ...
from the "under side" of the seat (as viewed in the picture) I cut a hole in the material, drill a hole in the fibre glass and the rivet through them all?
ah man im making myself confused, sorry eh - dont mean to be a pain in the ass...i appreciate your help Plaka...legend
2006 Honda VTR1000f
1975 BMW R90/6
Old 05-22-2013, 11:35 PM   #12
Plaka
Oddometer: 4,608
Cheers Plaka,
So ...
What picture?
Always lay out your holes and drill from the outside. I use fancy layout tools but a ruler with marks on both ends works fine. One mark spaces the hole in from the edge, The other mark is the distance between rivets.
Drill all the way through, rivet goes all the way through, Head on the outside, washer on the inside. 'Glass sandwiched between the folded over cover.
Old 05-22-2013, 11:52 PM   #13
Hearse OP
Project n'gagi
Hearse's Avatar
Oddometer: 148
What picture?
ah just my picture above mate,
that ^^ what you just wrote makes perfect sense.
You good sir are a legend.
Thanks heaps mate. Really appreciate it eh
2006 Honda VTR1000f
1975 BMW R90/6
Old 05-23-2013, 12:12 AM   #14
Plaka
Oddometer: 4,608
Oh, that picture. Didn't give yourself a lot of edge. You can fold over extra, plenty of contact cement (lightly sand the 'glass first if you used polyester to get the wax off!) and then add some blind rivets (pop rivets) upwards past the curve of the rim. Use a large diameter and use a plastic drill bit to get a super clean hole. pop rivits in 'glass are iffy unless you can get to the other side to peen them over a washer. But it's something. Depend on your rim rivets for most of the strength. I'd go smaller and use more of them.
I went with more than a 5/8" rim to give myself plenty to wrap over and to keep my rivet holes away from the edge.
Note, when you recover it, and you will eventually, you grind the rivets on the inside to remove them (an advantage of copper). Then when you wrap your new cover, you probe for the existing holes in the 'glass with a pin and re-use them.
The stock BMW seat used tiny t-bolts. These engaged a piece of trim on the outside (aluminum on the early models, I still have some) and had a nut on the inside. Rusted like crazy.
Using stainless button head cap screws is an option. Would look trick. About 4 to 5mm. nut + washer on the inside. I have them going in around my windshield.
Legend in my own mind? Definitely.
Old 05-23-2013, 02:05 AM   #15
Hearse OP
Project n'gagi
Hearse's Avatar
Oddometer: 148
hahah dude - you have helped me get some mean idea's for this - to me you are a legend.
yea that sounds sick, i am just worried about rubbing on the bolt head.
I will head to the hardware store, see what i can find in terms of fasteners and hit up some ideas.
I have a 3mm aluminium seat pan under the seat now, so i could even run the material around the ledge, and have a strip of metal that will sandwich the material between the strip of metal and the seat pan, pop rivet and done....
ideas are over flowing, where as before there was none!
mate ill call back in to this thread after the weekend with what i put together...lookout!
2006 Honda VTR1000f
1975 BMW R90/6
Times are GMT -7.   It's 06:44 AM.
