Old 05-22-2013, 07:12 AM   #1
canadasax OP
canadasax's Avatar
Oddometer: 345
Ktm adv wiring question
Is there a circuit on the 950 that cuts out when the starter is engaged?
On some bikes it is the headlight circuit that cuts out when you press the starter button.
I have a small power line running up to my tank bag that is fused and is switched by a relay.
I want to power the relay from a circuit that is off when the starter is activated.
Any ideas?
My bike is a 2005.5 KTM 950 adventure.
canadasax is offline   Reply With Quote
Old 05-22-2013, 07:46 AM   #2
Sumi
Sumi's Avatar
Oddometer: 1,773
Nope. I know of no curcuit that cuts out when cranking. You could then buy the euro headlight switch ( some jap bikes use the same switch as well, and it's cheaper, although the connector is not a direct plugin ), that way you can switch the circuit with the position or the headlight switch.
Old 05-22-2013, 11:52 AM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,565
You can easily wire a relay into the start circuit, use a normally closed pair of contacts. When the relay is energised it breaks the contacts.
Go across the red wire and yellow wire of the start auxilliary relay
Peanuts is offline   Reply With Quote
Old 05-22-2013, 12:04 PM   #4
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,741
Any ideas?
So the only time the relay gets power is when you crank over the motor?
I have to ask...
Why? What is the application for such a momentary pulse of energy?
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 05-22-2013, 02:41 PM   #5
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,939
I have to ask...
He wants to do the exact opposite. My guess would be to protect electronics from a power surge while the bike is cranking.
Sent from my GT-I9305T using Tapatalk 2
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 05-22-2013, 05:25 PM   #6
canadasax OP
canadasax's Avatar
Oddometer: 345
YES, that is a great idea,
Thank you
Old 05-22-2013, 05:26 PM   #7
canadasax OP
canadasax's Avatar
Oddometer: 345
Yes, exactly
Old 05-23-2013, 09:34 AM   #8
DSM8
DSM8's Avatar
Oddometer: 3,741
If that is the case why not have the solenoid triggered by the ACC2 circuit IIRC which is only powered when the bike is running.
If power spikes are what your worried about a 12vdc surge protector could be plumbed inline with the output side of the relay.
I know they some stuff like that in model train stores etc.
I have my LED's GPS and heated grips all running through a relay that is triggered by the ACC2 circuit, and spikes etc don't seem to be an issue. Been running it like this since day 1.
I also think the latency between the ACC circuit and the solenoid being triggered helps to isolate the items from the spikes.
Old 05-23-2013, 10:32 AM   #9
spafxer
spafxer's Avatar
Oddometer: 2,599
You must be a pilot !
Normally closed relay is the best "automatic" option..
spafxer is offline   Reply With Quote
Old 05-23-2013, 02:44 PM   #10
DSM8
DSM8's Avatar
Oddometer: 3,741
You would realize just how hilarious that statement is if you knew me in the slightest...
Times are GMT -7.   It's 11:32 PM.
