Go Back   ADVrider > Bikes > Battle Scooters
Old 05-22-2013, 06:47 AM   #1
paulter OP
Oddometer: 49
Honda CT 90, 110 battery tender
I have a 1971 CT 90, and a 1981 CT 110 and would like to wire them for a battery tender. Is there a harness already made for the battery, or what is the best way to accomplish this? As you know, the battery has a funky connection. Thanks for any insight. Walt
paulter is offline   Reply With Quote
Old 05-22-2013, 07:47 AM   #2
tortoise2
tortoise2's Avatar
Oddometer: 576
A battery connector is usually included with the tender . . example.
tortoise2 is offline   Reply With Quote
Old 05-22-2013, 09:16 AM   #3
paulter OP
Oddometer: 49
Tortoise,
The CT battery doesn't have the normal battery terminals. I can charge the battery using alligator clips, but wanted to leave attached leads on the bike, so all I have to do is plug the tender connector to it.
Old 05-22-2013, 09:51 AM   #4
tortoise2
tortoise2's Avatar
Oddometer: 576
Splice battery connector wires.
Old 05-22-2013, 11:23 AM   #5
FAW3
Old wanderer
FAW3's Avatar
Oddometer: 685
I have a '72 CT-90 and found a "Shumaker" (sp) brand 1 amp charger at AutoZone for about $20. Had both a 12v and 6vt selector switch.
I just tapped the "bike lead end" of the supplied pull apart plug into the standard battery wires (they are too small to be called cables).
I normally just leave the bike lead tucked into the battery cover. I do recommend using a marker/laberler to clearly mark the bike as 6 Volt...I use a tag on the cable. Just in case....
FAW3 is offline   Reply With Quote
Old 05-23-2013, 10:13 AM   #6
paulter OP
Oddometer: 49
Tortoise,
Did the splice thing--works beautifully. Thanks.
Times are GMT -7.   It's 12:34 AM.
