Old 05-22-2013, 10:29 AM   #1
Lvl. 29 Adventurer OP
Garage Inmate
Lvl. 29 Adventurer's Avatar
Oddometer: 44
Install a gel seat, with video! (klr650)
I was tired of ass-numbing slab sections so I looked into reasonably inexpensive fixes: The atv seat cover, sheepskin, changing seating positions etc... I decided to do a more permanent fix. I installed a gel pad in my seat.
I found one that was 5" wide at the front, 7" wide in the back and 16" long for under $50 on Ebay. It finally came in today and within 45 minutes I had it installed.
Boys and girls, if I can do this and get reasonable results, anyone can.
Here's a link to the video I shot of it:
VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO
If it doesn't work I can do a write-up with stills. but basically you cut a grid out the section where you want the pad to go. Test fit the pad and get it in its final placement. Glue down a "smoothing" foam layer over the pad and recover your seat.
Things I learned through the course of the install:
-Have all of your gear staged and ready
-The gel pad is super sticky without a protective film on it (mine came without one)
-Cut don't tear out the little cubes if you are doing this on a fancy bike.
-80 grit sandpaper is awesome at shaving down low spots but is messy.
-3M spray adhesive is extremely sticky so apply the smoothing foam carefully.
-The pad has settled in more and is already less visible than it was and I haven't even ridden it yet.
Stupid weather... i
f it wasn't all thunderstorms, wind, and rain I'd be out testing it right now.
I'll be sure to get back to you with a review soon to let you know if it's worth the money (assuming it doesn't snow here again in the next week).
Perpetually fixing a Yamaha XT600 as old as I am...
Lvl. 29 Adventurer is offline   Reply With Quote
Times are GMT -7.   It's 12:57 PM.
