Old 05-22-2013, 02:12 PM   #1
scatland OP
Oddometer: 87
640 LC4 - Is mine dying?
I bought a 2004 640 LC4 Supermoto a few months back with 5600 miles on the clock, it seems to have had a shady history as far as servicing documents go and has only got proof from its first 600 mile service. It runs pretty well when warmed up and pulls like hell but seems to idle like a feckin harley
this in itself doesnt bother me but I seem to be hearing (or imagining) a bit of metallic clattering from the engine. Im thinking and hoping the valves are the problem here and are just loose (no record of any valve work done on it) but i'm quite worried something is majorly wrong and it will explode at any minute
I plan on taking this several thousand miles to greece and back in the summer so want to know if I have a grenade on my hands here..
Any suggestions LC4 Gurus?
scatland is offline   Reply With Quote
Old 05-22-2013, 02:56 PM   #2
scatland OP
Oddometer: 87
Bluhduh
here's what it sounds like
Old 05-22-2013, 03:37 PM   #3
Droptarotter
Oddometer: 1,254
Start with checking the valves...........if lots of clearance, the rocker roller bearings are probably shot.
Do the water pump at the same time.
What does the oil/ magnetic plug/filters look like?
We have heard a lot of bikes that sound like this lately...........some have just needed valve adjustments...........some have needed a total rebuild.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 05-27-2013, 02:43 PM   #4
scatland OP
Oddometer: 87
Took it to the KTM dealer today and the mechanic had a listen then told me all the 640s he's worked on sounded like this, apparently if it goes quiet I should start getting worried (tight valves) so with that worry gone he then pointed out the small leak in my base gasket that I hadn't noticed up until now
Probably just going to run it as normal and maybe reseal it when I do the valves and oil in 1500 miles. A small leak wont harm anything unless its literally spraying oil right?
Old 05-27-2013, 06:24 PM   #5
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
Small leak is small stuff,but could get bigger at a bad time and make a mess.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 05-27-2013, 06:30 PM   #6
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,775
1...do a FULL service replacing all the fluids, check and if needed adjust your valves... check the brake pads and...
2....ride it like you stole it
wrk2surf is online now   Reply With Quote
Old 05-27-2013, 08:02 PM   #7
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,224
I listened to your video/audio, and to me it sounds like you have excessive valve tappet clatter... Sometimes posted video exaggerates and amplifies the actual sound being produced... But from what I am hearing it would be worth doing a valve adjust to see if you indeed have excessive clearances...
Like Droptarotter mentioned, if you find that your clearance is open past spec then there is a high possibility that your cam follower bearing is shot and needing replacement... The Norm on these engines is for the clearances to shrink with valve to valve seat wear...
If you do check the valves and they are withing spec then your good to go and won't have to check them again for a while...
gunnerbuck is offline   Reply With Quote
Old 05-28-2013, 09:00 AM   #8
Hair
Outside the boxer
Oddometer: 13,980
I recently repurchased an 2003 LC4 enduro. I owned it many moons ago. Sold it to a guy who had track racing in his blood. He sold it to a friend of mine. And I bought it back from him.
The bike needs a fair amount of work on it. But I am really liking the carb vs FI. So I think that the extra work is worth it.
So what can I do to get a better understanding of the overall condition of my motor? I really don't have any good shops around. I am thinking of replacing my upper cam bearings.
My concern here is how can I check to see if the main bearings are worn? The bike currently has 15000 miles on it.
Hair is offline   Reply With Quote
Old 05-28-2013, 10:40 AM   #9
Idle
Oddometer: 719
Scatland, I'm far from being an LC4 guru or jedi, but your valves should/must be checked.
If you've changed the oil already, it might be a good idea to change it again.
This assuming it's only been changed once at the 600 mile service. It could use a flush if that's the case.
Regarding the valves..
If they are way too loose, as stated above, the CFB's should be checked.
You need to pull the valve cover off to check them, and at that point, it might be a good idea to just replace them if you want piece of mind and have the $..
The CFB's (cam follower bearings, or rocker arm bearings) can go for hundreds of hours without a problem.
When the needle bearings wear to a certain point, one will escape, and it will seize and likely destroy your cam.
Sometimes they can fail at a much shorter interval. The rocker arm end-play is critical to get right if you replace the CFB's.
You need to put a feeler gauge between the rocker arm and the valve cover, then finger tighten the screw that goes through the shaft.
Then tap the plug on the outside of the valve cover, then torque the screw down. Remove feeler gauge and do the other one.
Good luck with your bike, and check the valves (yourself). It's a piece of cake..
You really don't have enough hours on it to worry about the CFB's at this point. Around 10-12k miles is a good time to inspect and/or replace them.
Hair, correct me if I'm wrong, but I thought the cam bearings are sealed?
If they are, they should be fine for many more hours. Is it the CFB's you are talking about?
I have checked my berg main bearings by taking the ignition cover off, and physically moving the flywheel in-out and up-down.
You need to pull the plug maybe, and turn the engine over untill it's slack. It won't move for you unless it is at a slack point. TDC or around there and/or BDC or around there.
Grab the flywheel with both hands and push it in and pull it out.
It's tough to measure, you may just have to do it by feel. It should have a little bit of end-play, check the specs for your bike.
Iirc, on my berg it's ~.5 mm. *actually I don't remember anything correctly and I'm guessing. The point is it HAS to have some end-play (in-out).
Then grab and try to move the flywheel up and down and forward and backwards. You should have no play at all. If it does, start collecting parts and tools for a rebuild.
After checking it both ways, get a second or third opinion by rotating the engine 180 until it's slack and then check it again and again for good measure.
On the bergs, premature main bearing failures were or may have been caused by not enough end play from the factory. The LC4 engines don't have main bearing issues as far as I know.
I'm somewhat of a n00b at wrenching on bikes, and never have owned an LC4 so I would advise checking with someone who is more familiar with them.
Maybe creeper or another inmate has a writeup in the LC4 index thread on the main bearings and how to check them in situ.
Or maybe there isn't one because they are bulletproof.
Idle is offline   Reply With Quote
Old 05-28-2013, 02:05 PM   #10
Hair
Outside the boxer
Oddometer: 13,980
Thanks for that reply.
I adjusted my valves a while ago. Probably less than 10 hrs. Right from the get go I was worried that my intakes were to lose. They made a fair amount of noise. Then after reading this thread I was about to check my bearings. I still might.
As far as the crank goes I will defiantly use your post.
Oh by the way. Which berg do you have? I have had an 04 650 great bike
and 10 570 and 10 390. Sadly to say I don't have any of them any more. There is talk that the 70 degree motor might come back. I loved my 570 I would like to get another.
Old 05-28-2013, 02:34 PM   #11
Idle
Oddometer: 719
2005's FS 650e, FE 650e, FE 550e... The 550 is in pieces, the engine is in the FS.
I'm keeping them as long as possible.
Or I might sell them all and get a 500exc and a 17" wheelset.
I recall seeing your posts on the UHE site.
Old 05-28-2013, 03:10 PM   #12
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,462
Unless the thing has been run out of oil your mains should be fine at even 4x that mileage - they're big beefy roller bearings in there. My big end wore out at 60K miles - slight knock plus lots of metal on the sump bung was a giveaway - the piston, cam & valves were all due for some attention also but the mains were still fine.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 06-04-2013, 06:01 AM   #13
scatland OP
Oddometer: 87
Thanks for the replies guys, really helpful. Will be finding a weekend some time very soon to give the bike a big overhaul, the leak appears to have stopped (or it wasnt a leak maybe?) but I had to top up the bike with about 700ml of oil this week after 1800 miles since the change. Quite worrying.. they possibly hadnt given it enough at the dealership im hoping otherwise it is burning oil like a mofo
In any case, this bike is going on a 4000mile tour in August (yes sumo touring ) I and will be doing all of the work on this bike from now on. Hopefully I can manage this as I am a 20 year old student with less than stellar mechanical skills.
next service will be -
Pull carb, clean and rejet for akra exhaust (dont think was done as I think its running pretty lean - exhaust sounds like a machine gun on deceleration)
Check Valve clearances adjust if necessary
Oil and Filters
Check Cam Follower bearings (not sure how I would do this)
Check wheel bearings
Install 18 liter tank and comfort seat
and then I will hopefully be ready to kick some ass
Old 06-04-2013, 07:04 AM   #14
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,224
The engine noise along with the oil use for sure would be a worrying combo.. I would recommend you have a leak down test {compression} performed to check on the top end condition..
Old 06-04-2013, 02:18 PM   #15
clintnz
clintnz's Avatar
Oddometer: 3,462
The valve clearances being really loose is a giveaway on that one. If you are worried, set them to spec then check again after a few hundred miles & see if they have opened up. FYI I've had around 30K miles ea on the 2 sets of cam followers I've removed, so if yours are toast at 5600mi you may also have other issues.
x2 These motors are not known for using oil. Even just before I rebuilt mine with a well shagged piston it only needed 250-500ml extra between 3K mile services. It can be tricky to get the oil level right after a change so it might just be that.
Cheers
Clint
Times are GMT -7.   It's 10:12 PM.
