Old 06-11-2013, 08:42 AM   #31
scatland OP
Oddometer: 87
oh and forgot to say, bill - The previous owner lost the toolkit so I used a drinking straw VERY carefully down the sparkplug hole
scatland is offline   Reply With Quote
Old 06-11-2013, 10:11 PM   #32
bmwktmbill
Traveler
Oddometer: 5,218
The PO is an idiot.
The drinking straw is a bad idea for me cause I cut one in half as the piston came around so fast. I'd find something metallic before disaster strikes.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 06-12-2013, 05:20 PM   #33
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,291
The nice thing about using a metal rod is that you will have the opportunity to damage things when the piston comes up faster than you planned. Use it carefully if you go that route.
Sent from my SCH-I535 using Tapatalk 2
Sparrowhawk is offline   Reply With Quote
Old 06-12-2013, 09:35 PM   #34
bmwktmbill
Traveler
Oddometer: 5,218
yep, better to make a dedicated piece of brass/bronze brazing rod or some such.
I've used a wooden dowel too, another bad idea.
I think the last time I put it in 5th gear, chain on and cranked with the kick starter, slows things down that way and you can use the wheel to back up.
b
Bill Shockley
Old 06-15-2013, 03:51 PM   #35
scatland OP
Oddometer: 87
Well something new has happened...
went on a quick ride this evening and after around 10 minutes of riding at a stop light I hear - *PING rattlerattlerattlerattle* it literally sounds as if something is rattling around the inside of the cylinder. shit
So I limped it home at as low rpm as possible, when going up the big hill that leads to where I live it was losing power accompanied by an alarming ticking noise that sounds like what you would get out of a sparking electrical socket
Well that seems like 2 grand down the drain damnit...
Old 06-15-2013, 07:00 PM   #36
bmwktmbill
Traveler
Oddometer: 5,218
Check the valves.
bill
Bill Shockley
Old 06-16-2013, 04:16 AM   #37
scatland OP
Oddometer: 87
Valves checked and all in spec. rattling is worse after starting it up, seems to alternate between sounding normal and ticking with noises sounding like there is expensive stuff being crunched around
Old 06-16-2013, 06:13 AM   #38
mountaincadre
Oddometer: 361
Scatland, ken it sounds a wee bit daft but mind these things sound ruff EVEN when running normal, have you tried the screwdriver to casing method?
mountaincadre is offline   Reply With Quote
Old 06-16-2013, 07:03 AM   #39
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,304
It sounds possible that your piston may be toast... I would pull the head and have a look for a chunked apart crown... Don't run the engine any more until you get to the bottom of the problem, as you may risk further damage...
gunnerbuck is offline   Reply With Quote
Old 06-16-2013, 02:01 PM   #40
scatland OP
Oddometer: 87
I did Cadre, dont hear anything coming from the cylinder itself but it is unrideable and making disturbing sheraing metal noises. Going to pull apart the cylinder with the help of a mechanic who knows what he's doing and report back
Old 06-18-2013, 09:29 AM   #41
scatland OP
Oddometer: 87
I swear if I dont get on a bike soon i'm going to go on a rampage!!!!!!! :b aldy
Old 06-19-2013, 01:36 AM   #42
scatland OP
Oddometer: 87
Alright so had a look at the cam chain and it still has a fair bit of stretching left in it. Drained the oil and... WE'VE STRUCK GOLD!!!
Oil was full of shiny copper shavings so im guessing its a bearing of some kind in the top end but not sure what yet.
Old 06-19-2013, 01:23 PM   #43
scatland OP
Oddometer: 87
Well, Droptarotter was right
Worn rocker roller bearing which then failed catasrophically causing a load of crunching.
Parts getting replaced :-
Rocker arm roller
Camshaft
Could have been worse but, ouch.. only had this bike for 2k Miles
Old 06-19-2013, 09:25 PM   #44
bmwktmbill
Traveler
Oddometer: 5,218
Rocker arm roller
Camshaft
Was the cam damaged?
Pictures?
bill
Bill Shockley
Old 06-20-2013, 04:50 AM   #45
scatland OP
Oddometer: 87
Its sitting in a workshop at the moment, Will post pics of bits when I get it back in a couple days
Times are GMT -7.   It's 05:46 AM.
