Old 05-24-2013, 10:14 AM   #1
bay OP
bay's Avatar
Oddometer: 43
ate calipers
hi, i have swinging ate calipers on my 78 r100/7 and the pads in them rattle against the discs all the time both have the pad retaining pin and all the bolts are tight,they work really well but they make a horrible rattle when i go over cobble stones or small bumps,is this normal.also my clutch slips when the engine is warmed up and its under load ,i have replaced every thing in the clutch and the main is not leaking,any ideas folks.
bay is offline   Reply With Quote
Old 05-24-2013, 12:02 PM   #2
Kai Ju
Kai Ju's Avatar
Oddometer: 1,889
O ring
You're probably missing the O-ring that goes on the pad that sits in the piston.
Mine did the same thing until I replaced it.
34 11 1 233 120 O-RING (to 09/80) 2 $3.38
Kai Ju is offline   Reply With Quote
Old 05-24-2013, 05:49 PM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,927
Sounds like clutch adjustment. There is always a probability of oil or grease on the clutch or the thing just being worn out but most of the time it needs adjustment. You have to do it by the book. Either Clymer's or Haynes'. Do you have a manual?
As a general rule there needs to be free play at both ends. About a nickel's worth of free play at the lever on the handle bar and the lever on the rear of the trans should make contact when it is sort of parallel to the rear of the trans. There is a measurement from the rear boss of the trans where the cable passes to the front edge of the barrel at the cable end, it is 201mm.
BTW, you have dual brakes? Or one brake is a single caliper.
O-ring on the moveable brake pad.
---Albert Einstein
disston is online now   Reply With Quote
Old 05-24-2013, 07:51 PM   #4
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,032
o-ring on the pad.
I have the same problem.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 05-26-2013, 06:39 AM   #5
craydds
craydds's Avatar
Oddometer: 1,167
Check your clutch adjustment as Disston has described. Take a look at http://www.youtube.com/watch?v=1oj8NMid_LU for a clutch adjustment tutorial.
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 05-26-2013, 06:52 AM   #6
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
I've never heard any describe ate brakes as working "really well".
The rattle is the o ring.
Have you tried backing off on the clutch cable tension?
Old 05-26-2013, 07:03 AM   #7
bay OP
bay's Avatar
Oddometer: 43
great thanks,ill give your ideas a go
Old 05-26-2013, 12:59 PM   #8
GCCR
GCCR's Avatar
Oddometer: 175
Thanks for posting this link. It was very useful!
GCCR is offline   Reply With Quote
Old 05-26-2013, 01:50 PM   #9
supershaft
because I can
Oddometer: 9,116
There is no reason to loosen adjuster nut on the tranny before you set the cable length. Adjust the cable length first and then loosen the tranny adjuster to set free play.
Pull the clutch lever in while you tighten the tranny adjuster lock nut. That keeps your adjustment from moving while you tighten the lock nut. The tranny lock nut needs to be on the tight side or it will come loose. Good luck!
Old 05-26-2013, 04:19 PM   #10
craydds
craydds's Avatar
Oddometer: 1,167
True... for those in the know (like supershaft). But I think it is safe to teach all to loosen everything first, then begin all the adjustments. This assumes that everything is CLEAN and LUBED - if not, take all apart and clean/lube throwout assembly and handlebar clutch lever, etc.
ABC #12947
'75 R90S
Old 05-26-2013, 04:20 PM   #11
craydds
craydds's Avatar
Oddometer: 1,167
ABC #12947
'75 R90S
Old 05-26-2013, 04:23 PM   #12
craydds
craydds's Avatar
Oddometer: 1,167
Hey! After all the time and work and $$$ I've spent on my ATE's? My brakes work almost "really well".
ABC #12947
'75 R90S
craydds screwed with this post 05-26-2013 at 04:24 PM Reason: s
Old 05-26-2013, 05:09 PM   #13
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,671
+1 on the " almost really well " I have them on the race bike and they do the job with the mods, and I like them as they are different.
Voltaire is offline   Reply With Quote
Old 05-26-2013, 05:31 PM   #14
supershaft
because I can
Oddometer: 9,116
As long as the play in the loosened tranny adjuster nut isn't throwing off your cable measurement and it very well could. It's opening up a can of worms that doesn't need to be opened. That's why the manual has you do it as I am suggesting. Three out of four of this type of instructional idiotnet article has some serious flaws in part or in whole. Personally, I think overall you are much better off getting some manuals. In this case the owners manual would do you a lot better.
Old 05-26-2013, 05:52 PM   #15
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,927
I couldn't watch the whole video. I'm sorry but the idea of everybody being able to share on the internet is a wonderful idea. Now let's find some people that can make a video that holds the attention of an adult for more that 60 seconds.
The part I watched was OK. I would guess he got the rest correct also. It's not really all that hard ya'know.
---Albert Einstein
Times are GMT -7.   It's 07:49 AM.
