Old 05-24-2013, 01:45 PM   #1
crunchiespg OP
Oddometer: 1,031
has anyone used one of these?
http://www.ktmtwins.com/ktm-universa...andlebar-mount
the ktm bar top gps mount?
will it work with the wiring cradle for the garmin Zumo?
like it?
thanks
crunchiespg screwed with this post 05-24-2013 at 02:03 PM
crunchiespg is offline   Reply With Quote
Old 05-24-2013, 08:24 PM   #2
Imachimper
Newer than Noob
Imachimper's Avatar
Oddometer: 130
Not sure if you can angle the GPS more upright? At that angle, it has been my experience that you would get lots of reflection from the sky.
Might be something to think about.
Imachimper is offline   Reply With Quote
Old 05-24-2013, 08:33 PM   #3
crunchiespg OP
Oddometer: 1,031
Good point. I like the fact it fits so neatly and doesn't need drilling like mounting it above the speedo in the windscreen.
Old 05-25-2013, 02:08 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
I think it positions the unit too low.
Totally out of vision. Will need taking your sight from the road. Looks really neat though.
Cheers.
Old 05-25-2013, 06:26 AM   #5
fasteddiecz
Panama Ed
fasteddiecz's Avatar
Oddometer: 14
I have the zumo 350 mounted with a touratech bracket and its is easy to see. I mounted it with hardware provided with my 2013 baja. Hard wiring was easy, I did it under the glove box.
2013 KTM 990 Baja
fasteddiecz is offline   Reply With Quote
Old 05-25-2013, 06:29 AM   #6
fasteddiecz
Panama Ed
Oddometer: 14
Almost forgot, if you use a tank bag it may get in the way of seeing it. My ridding parter has his zip tied to his handle bar and his head has to tilt way down to see it but making any adjustments takes his eyes off the road big time. The installation of the bracket to hold any GPS was not that hard, just take your time and it comes out looking nice.
2013 KTM 990 Baja
Old 05-25-2013, 07:25 AM   #7
alongat
alongat's Avatar
Oddometer: 1,055
Sounds like you may be looking for a creative way to mount GPS, etc. I recently bought one of the HDB top clamps to have a good place to mount switches, etc but one of the added benefits is that it has tapped holes out front and at the front sides that enable other things to be bolted onto it (they are there to provide mounts for the HDB hand guards). Have a look and see if this may be a good fit for what you are trying to accomplish:
http://www.highwaydirtbikes.com/HDB_...KTM_Top_Clamps
By the way, HDB are absolute top notch - quick to ship, great communication and fantastic quality products (no affiliation - I'm just a very happy customer).
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 05-25-2013, 07:59 AM   #8
crunchiespg OP
Oddometer: 1,031
I like the mount that comes with the baja. But I don't like the big metal cages from touratech for the actual GPS.
I was thinking I might use some sort of ram mount in the same poisition though.
What power supply did you wire it to? Acc2 or somewhere else? Ideally I'd like to keep acc2 free for the ktm plug and play heated grips. Or can you have more than one thing connected to acc2?
crunchiespg screwed with this post 05-25-2013 at 08:05 AM
Old 05-25-2013, 08:01 AM   #9
crunchiespg OP
Oddometer: 1,031
Cheers.
Yeh I think you're right. Tucked under the screen above the speedo is a better place.
Old 05-25-2013, 08:07 AM   #10
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,232
I copied the install inmate Masa and other guys here did with a ram mount.
Very clean and solid, maybe that's what you're looking for...
http://www.advrider.com/forums/showp...8&postcount=48
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 05-25-2013, 08:13 AM   #11
crunchiespg OP
Oddometer: 1,031
yep that's what i was thinking of if the consensus was the handle bar clamp mount is no good. which it is..
thanks guys.
Old 05-26-2013, 06:06 AM   #12
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 883
Cheers.
Have a similar one, only works if you ride mostly seated. I'm refitting the GPS above the dash.
690R
Old 05-26-2013, 09:11 AM   #13
Imachimper
Newer than Noob
Imachimper's Avatar
Oddometer: 130
The angle that I can get with this setup is just barely enough. It stays out or the way of the instruments. Everything is a work in progress.
Old 05-26-2013, 09:38 AM   #14
crunchiespg OP
Oddometer: 1,031
Yeh I'm thinking on top of the dash is the way to go. Ill use a ram ball mount and brace it from inside. I went for a ride last night and above the speedo is definitely a more natural position to glance at when sitting or standing.
Old 05-26-2013, 10:32 AM   #15
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,136
Different setup (Ram mount,) but this position works well for me, even with a tank bag.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Times are GMT -7.   It's 11:29 PM.
