Go Back   ADVrider > Riding > Regional forums > Alaska
Old 06-30-2013, 12:38 AM   #31
marbee40
Some Fear is Good
marbee40's Avatar
Oddometer: 1,131
The K60 is a fine tire, even if sloppy. Not nearly as agressive as a full knobby but more than enuf for scooting along. Previous posters are spot on with watching your speed. Fast Eddie and I absolutley rallied it last year but didnt stop for too many pix
R1150GS
01 WR426F
marbee40 is offline   Reply With Quote
Old 06-30-2013, 12:42 AM   #32
nuttynu
nuttynu's Avatar
Oddometer: 981
How about tkc tires ? Any prefer psi to set them for the Dalty ?
nuttynu is offline   Reply With Quote
Old 06-30-2013, 01:03 AM   #33
Full Power
Oddometer: 1,531
Nuttn-you are Wildman..
Are you preparing to fit Knobbies to a CBR ?
. Will they clear front fender?
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 06-30-2013, 05:58 AM   #34
nuttynu
nuttynu's Avatar
Oddometer: 981
Laugh
Yes. They clear it fine. I was surprise when I installed them.
Old 06-30-2013, 08:00 AM   #35
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,239
Check his old posts, he has already mounted a set on They looked pretty nice...
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 07-02-2013, 11:22 PM   #36
Full Power
Oddometer: 1,531
I just put a pair of TKC 80 on F800 this morning.
First ride felt real good with 32 front and 36PSI rear.
Real nice street tire, so far.
Might try dropping pressure down to 25 Front, 30 rear on gravel, if they feel skittery at highway inflation.
Surprised how round they are... didn't notice any runout at either end, and the rear came up at ZERO balance, no weights req'd.
. front used an ounce.., had one laying around anyway..
Old 07-03-2013, 12:51 AM   #37
nuttynu
nuttynu's Avatar
Oddometer: 981
I just installed mines back on.
Used dyna bead, ounce frt,2 ounce rear. And started with 32f,34rear for psi. Did a little off road and think I could had drop it a bit.
Will try to hit the Dalton this weekend. Yay.
May the sun shine bright !!!
Old 07-03-2013, 11:51 AM   #38
Full Power
Oddometer: 1,531
Whats your fuel capacity ?
You packing couple extra gallons ?
Probably see you up there, Friday or Saturday.
Old 07-03-2013, 03:18 PM   #39
nuttynu
nuttynu's Avatar
Oddometer: 981
Did about 170 on my recent trip.
Will pack light this time & bring 2 gallons ...along with my two MSr bottles.
Hopefully that get me there. Or else I'll have to flag someone and spihon some petrol :/
Old 07-03-2013, 03:39 PM   #40
Full Power
Oddometer: 1,531
F8 holds 4.2 gallons inside, not sure how much of THAT is usable.
My spare gas is (2) MSR bottles = half gallon.
Fox to Coldfoot 245 miles/ 4.7 Gallons = 52.13 miles per gallon.
I should be okay, but it will be cutting it close.
For a bit of range extension, I have a couple Techron 16 injector cleaners, and some Thermo-Aid ( ISO-Heet )
figure I'll dump ONE supplement in, and ONE quart of gasoline, at first piss break after Fox.. keep the other quart for emergency reserve.
probably do okay.
Repeat after coldfoot, and return..
The question mark of course is how much extra energy I burn climbing Atigun pass, and how mileage will be TWO-up.
I am hopeful that with speeds under 55 MPH, I can make closer to 60 miles per gallon.
We'll see.
Old 07-03-2013, 11:08 PM   #41
AKDuc
Alaska Born Ducatisti
AKDuc's Avatar
Oddometer: 6,637
Good seeing you on your test run around town this evening.
You sure look mighty comfortable on that bike with those TKC's.
Good luck and have fun, Mark H.
AKDuc screwed with this post 07-04-2013 at 12:32 AM
AKDuc is offline   Reply With Quote
Old 07-04-2013, 12:08 AM   #42
nuttynu
nuttynu's Avatar
Oddometer: 981
Haha I was wondering who you was !
Nice seeing you two !
Met Drunkuncle at the eagle river fireworks show. Currently going ok now ..
--- the testing went fine with the tkc,saddle ,& gears. Packed much lighter than when i rode I to Cali, drop some psi, & tweak the suspension a bit.
nuttynu screwed with this post 07-04-2013 at 02:10 AM
Old 07-07-2013, 11:25 PM   #43
Full Power
Oddometer: 1,531
Confirm:
F800GS can run two-up, Coldfoot to Deadhorse on internal fuel supply.
We used 4.01 gallons. Signage claims 240 miles, bikes tripmeter called 237.8
We ran slow, kept it down to 50 miles per hour until we got North of Atigun, then we let it run 55 the rest of the way.
Managed near 60 miles per gallon with a passenger.
Old 07-10-2013, 06:56 PM   #44
nuttynu
nuttynu's Avatar
Oddometer: 981
Aug 26-29
Will make a Dalton run from Anch . August 26-28.
Stay dry and sunny Mr. Dalton .
Old 07-11-2013, 05:16 PM   #45
eddie98
Oddometer: 638
I'm thinking of getting a new K60 for my trip from ATL.
09 DL 650,08 WR250R
09 KLX250S(gone), 03 R6 (gone)
04 WR 450(gone), 01 EX 250(gone),
06 DL 650(gone) , 89 KLR 650(gone)
eddie98 is offline   Reply With Quote
Times are GMT -7.   It's 02:17 PM.
