Go Back   ADVrider > Riding > Regional forums > The Sandbox - AKA Flatistan
Old 05-25-2013, 09:32 AM   #1
yermaun OP
yermaun's Avatar
Oddometer: 134
Wicked Frankenstein ADV bike
Looking to replace my beloved KLR (sold due to contracting orange fever) however much the KLR was a pig in the sand & unhappy @ highway speeds I still miss it, but I would like to improve on it, so I'm considering a Frankenstein build. I have a DR650 with a shot motor & an EX500 left over from my road racing days, it appears that with some fabrication the two could merge, any inmates undertaken such a project?
yermaun is offline   Reply With Quote
Old 06-02-2013, 02:25 AM   #2
DualSportDad
DualSportDad's Avatar
Oddometer: 2,434
I never have but I have been thinking about a ninja 650 engine in a KLR.
Sent from my Nexus 7 using Tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 06-02-2013, 05:05 AM   #3
yermaun OP
yermaun's Avatar
Oddometer: 134
The Ninja 650 is a great little power plant, light, powerful, compact & reliable, it was actually my first consideration for this project. But there are a couple of drawbacks, the EX650 is fuel injected with down draught intake & high volume air box, neither the KLR or DR can accommodate that layout without major modification, also the EX650 uses a submerged fuel pump ( in the tank) & the 650 hangs in its frame as a stressed member so the mounts are not in an ideal position. I am going forward with the EX500 my plan is to utilize the lower cradle of the EX500 chassis & merge it with the DR main frame. I will post pics soon meanwhile I need to sell my old DT1 to help finance this project.
Old 06-02-2013, 08:14 AM   #4
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,741
sanjoh built a dirt ninja from a wrecked 650 ninja. He didn't swap chassis but made a pretty nice rig. There's a lot of such projects under "some assembly required."
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 06-07-2013, 09:29 PM   #5
DualSportDad
Oddometer: 2,434
I look forward to seeing how this turns out.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 06-08-2013, 05:53 AM   #6
jaydee1445
Footpeg Crash Tester
jaydee1445's Avatar
Oddometer: 4,054
All are valid reasons to go with the 500
jaydee1445 is offline   Reply With Quote
Old 06-08-2013, 06:13 PM   #7
Huzband
Team Dirt
Huzband's Avatar
Oddometer: 4,168
What about yanking the EFI & put a carb or two in it's place? Could it be rewired around that?
'07 R12GSA (Moose)
'04 Sherco 2.9 (Sherpa)
'97 KTM 400 R/XCe (needs a home)
'90 RM250
IBA #30344
Huzband is offline   Reply With Quote
Old 06-09-2013, 06:01 AM   #8
yermaun OP
yermaun's Avatar
Oddometer: 134
Switching from fuel injection to carbs can be done relatively easily but there is still the packaging issue, the EX650 intake is a downdraft which requires alot of room directly above it that would be quite difficult to accommodate on a back bone type chassis used by the KLR & DR. Of course the intake could be altered but I don't have the time or resources to run that to ground, quite simply the EX650 would be a more desirable power plant to use but the EX500 is easier to work with, not to mention less expensive & I already have one. I will be stripping down the DR today anyone looking for a 93 DR650 lump with bad cam let me know.
Old 06-21-2013, 06:44 AM   #9
yermaun OP
yermaun's Avatar
Oddometer: 134
& so it begins
Old 06-21-2013, 06:46 AM   #10
yermaun OP
yermaun's Avatar
Oddometer: 134
This is going to be difficult
Old 06-23-2013, 08:01 PM   #11
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,741
Old 08-29-2013, 12:17 PM   #12
yermaun OP
yermaun's Avatar
Oddometer: 134
slow progress
EX lump installed
Old 08-29-2013, 12:19 PM   #13
yermaun OP
yermaun's Avatar
Oddometer: 134
had to move upper shock mount to clear carbs
crappy pics from phone
Old 08-29-2013, 12:20 PM   #14
yermaun OP
yermaun's Avatar
Oddometer: 134
Naked profile
Old 08-29-2013, 12:22 PM   #15
yermaun OP
yermaun's Avatar
Oddometer: 134
Body parts on
Times are GMT -7.   It's 05:00 AM.
