Old 05-25-2013, 11:25 PM   #1
avocadofarmer OP
Fruit Coot
Oddometer: 280
New air filter, 950 now runs funny
I upgraded out of the stock airbox on my 06 to a really sweet ITG filter (like the Rotweiler setup). The bike still has SAS and the stock exhausts. The bike seems to have the hickups at low engine speeds and at cold idle. It sounds like a small backfire and usually stalls the bike if it is idling. It's a bitch to get started when cold, usually requires full choke and multiple ugly starting attempts. Smells quite rich and feels like it is running rich at first (bog off idle).
The other hickup issue happens when cruising along with very, very little throttle, usually around 3000 rpm. The bike just kinda misses and slaps the chain with a sudden engine movement. Definitely annoying.
I'm running 175/178 mains, 42 pilot, 60 IAJ, 3mm set floats and I've got the flex jets adjusted anywhere between 1.5 and 3 turns out trying to sort this issue (no flex jet adjustment seems to do much). I'm at about 1500 ft elevation. Bike has recently had the valves checked, 13k on motor. Problem seems to be worse in cold, dense air.
I'm thinking I need to swap out the IAJ for the next leaner size, right?
On the other hand, the bike runs awesome if you are racing around everywhere. Lots of power, no flat spots, tons of fun. Just gotta fix this!
avocadofarmer is offline   Reply With Quote
Old 05-26-2013, 04:31 AM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,883
Why not 4mm floats as Sportingwood suggests?
Old 05-26-2013, 06:40 AM   #3
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,983
i've had similar issues when I had a vacuum line air leak on one cylinder. The bike would do a little hickup, which sounds like the chain skipping a sprocket tooth, but it is really backfiring into a carb.
Check your vacuum lines. I check my carb sync with an airflow meter and don't use the vacuum ports, so I sealed all four on my intake manifolds so that I will never have a vacuum leak again.
Orangecicle is offline   Reply With Quote
Old 05-26-2013, 07:51 AM   #4
avocadofarmer OP
Fruit Coot
Oddometer: 280
Hmmm...I'll check those four ports again and the silicon clamps. I've actually got screws placed in mine, seems like that would be pretty air tight.
Any ideas on the hard starting?
Old 05-26-2013, 10:06 AM   #5
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Simple first, Make sure your carbs are snug into their boots. These engines vibrate and it is easy for the carbs to get unseated. I have had that issue with mine before and thought it was the battery not getting enough to fire it up. My rear carb was slightly unseated and once I got it snugged up, she fired right up.
How old is the battery? Is it spinning up but cutting out? Or are you getting the "clacking" noise that sounds like a bunch of wrenches are in your cases? IF it is the clacking noise and it has gotten worse, youre starter torque limiter is about to go and you need the upgraded kit.
Good luck!
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 05-26-2013, 10:28 AM   #6
avocadofarmer OP
Fruit Coot
Oddometer: 280
Howdy,
I just rechecked all of the carb vacuum ports. All four are sealed off with bolts in them and a little dab of RTV. The carbs are also fully seated on the boots and all four clamps are tightened to the stops. Everything appears to be snug.
I took it for another short ride and got 3 backfires. Every time at about 3000 rpm with just a teeny bit of throttle.
I replaced the clacking starter torque limiter a while ago...so that's no prob. It has a tendency to cough a bit on startup with this jetting and filter setup. Not nearly as bad as that horrific starter torque limiter, however!!
Thanks for the ideas, fellas...
Old 05-26-2013, 04:28 PM   #7
D K
Oddometer: 482
Sounds like you are unning lean off idle
'13 EC300 Racing
07 950SE - sold
08 950SE - sold
09 FE570 - sold
D K is offline   Reply With Quote
Old 05-26-2013, 05:07 PM   #8
avocadofarmer OP
Fruit Coot
Oddometer: 280
Hmmm...I've heard that it's kinda tricky to differentiate lean/rich at low RPM...
I've messed with it all day, 100% sure that there are no vac leaks anywhere. Still has a hickup.
It did seem to decrease in frequency when I richened up the Flex jets so maybe that's a sign to richen them up another half turn.
Old 05-26-2013, 05:41 PM   #9
Katoom72
Katoom72's Avatar
Oddometer: 897
Is there a difference in performance on a cold and hot engine?
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 05-26-2013, 05:47 PM   #10
avocadofarmer OP
Fruit Coot
Oddometer: 280
Nothing that I can tell...I'm usually easy on it until it warms up tho
The bog off idle is really small and happens only within the first 30 seconds of starting it when cold.
Old 05-26-2013, 06:27 PM   #11
Katoom72
Katoom72's Avatar
Oddometer: 897
I'd think a smaller IAJ would help.
Stock is 50 so 60 is leaner, you made the carbs breath better with the airbox removal and the problem comes around more on cold dense air. Giving it more fuel on the mixture screws helps aswell.
So the bigger airjet, easyer breathing/more air intake, cold air all makes it leaner then stock.
So if u add all of that up the engine is running to lean on idle trough low RPM cruise.
I'm no carb guru but that's my theory on the issue. If u got no intake leaks and the floats are not way off their stock height then you should try a smaller IAJ.
Did you balance the carbs yet?
Now:
Before:
Old 05-26-2013, 08:19 PM   #12
David37
David37's Avatar
Oddometer: 401
Sounds like you have a lean condition caused by your new air filter which is flowing more air than the stock air box. IMO I would increase your pilot jets from 42 to 45. I would also try dropping the clip (raises the needle) on your needle.
David37 is offline   Reply With Quote
Old 05-26-2013, 09:19 PM   #13
avocadofarmer OP
Fruit Coot
Oddometer: 280
I balanced the carbs a few hrs ago...I didn't have to adjust anything...I'll try plugging back in the stock IAJ...IIRC that's the one on the top of the carb...easy to get to. Thanks for the idea.
David, I'm already on the middle needle setting...(one richer than stock). I'm afraid that another movement would overdo it...?
Old 05-26-2013, 10:37 PM   #14
max2
max2's Avatar
Oddometer: 219
stock air jet and 45 pilots, floats at 4mm, needle 3rd clip, 175/178 mains, air screws 2 frt, 2 1/4 rear
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 05-26-2013, 11:46 PM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,004
So, how is it running?
exhaust system? Results? Consumption?
Cheers.
Times are GMT -7.   It's 02:01 AM.
