Old 05-27-2013, 06:17 PM   #1
Yachtie OP
Oddometer: 105
Broke my only key.
Hey guys. Been away for awhile. I got the bike running great. Fluids, timing, and some fuel flow fixes sorted her right out.
Well I went and broke my only key in my wheel lock assembly.
What are my options?
1976 R90/6 Cafe
Sorting out all the kinks.
Yachtie is offline   Reply With Quote
Old 05-27-2013, 06:27 PM   #2
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,982
Locksmith. And have extra keys made.
'73 R60/5 Toaster
Old 05-27-2013, 06:29 PM   #3
Plaka
Brevis illi vita est
Oddometer: 4,609
Turn the bars hard? Supposedly you can break the wheel lock assy and keep riding.
Or dig the remains of the key out. (toothpick and superglue surgery) then take to a locksmith.
or take to a locksmith with tape over it so you don't lose the thing and have them repair.
Or abandon it and put in a kewl hidden ignition switch somewhere.
Know what tuition is?
Old 05-27-2013, 06:31 PM   #4
Yachtie OP
Oddometer: 105
Had a brain fart. Stuck the key in the wheel lock and turned the wrong way. Snapped like a twig.
I can try and fish the remnants out. If I can't get it out. Can A Locksmith use my ignition key slot to make a new key. And can you find blanks with the plastic bmw housing?
1976 R90/6 Cafe
Old 05-27-2013, 08:03 PM   #5
Plaka
Oddometer: 4,609
Blanks from any parts house.
Ask the locksmith. try very carefully supergluing the part you have to the part that broke off.
Old 05-28-2013, 01:18 AM   #6
ME 109
ME 109's Avatar
Oddometer: 2,985
+1
otherwise the key might get stuck to your finger.
It's not all bad tho' I can still ride. I just can't use the clutch.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 05-28-2013, 01:51 AM   #7
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,582
I did that way back in about 1977 or 78.......never done it since.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 05-28-2013, 02:10 AM   #8
ME 109
ME 109's Avatar
Oddometer: 2,985
You too!
I thought I was the only one. Things are looking up!
Old 05-28-2013, 04:05 AM   #9
Yachtie OP
Oddometer: 105
Thanks guys. Will try the superglue technique. Not sure it will be successful cause its so flush in the lock assembly. Will look for blank online
1976 R90/6 Cafe
Old 05-28-2013, 04:12 AM   #10
_cy_
Oddometer: 6,358
use a dental pick ... betcha you get it out. here BMW keys are hard to find... only one locksmith in town that's got special BMW blanks. save your pieces, locksmith can use pieces to help make another key.
_cy_ is online now   Reply With Quote
Old 05-28-2013, 05:38 AM   #11
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
Nother option.....buy another switch with keys. Just an option. Not sure what a locksmith charges these days.
Old 05-28-2013, 11:15 AM   #12
Yachtie OP
Oddometer: 105
I'm searching for key blanks. I've found the folding keys. Will they work on my R90? I'd love to get a exact match to the round plastic cap bmw emblem key I have. Any suggestions.
1976 R90/6 Cafe
Old 05-28-2013, 11:37 AM   #13
Plaka
Oddometer: 4,609
Keep looking. Try Bobs and Capitol Cycle, both regular dealers.
Also get some cheap flat blanks as spares.
Old 05-28-2013, 12:31 PM   #14
Kai Ju
Kai Ju's Avatar
Oddometer: 1,896
The folding keys are easy to find, the knob keys not so much.
BTW, the folding keys will clear when left in the steering lock, that's why the left headlight ear has the dents on the inside.
Anyway, my buddy did exactly what you did but luckily had a spare. But like you wanted the knob key.
Here is what I did. Clamp the remaining portion of the broken key into a vise, leaving enough room to get fuel line pliers between the vise jaws and the knob. Squeeze the pliers and the knob will come off. The key is vaguely shaped like a T which is what holds it in the knob. Take the new key and duplicate the shape of the old key. Insert the key into the knob using the vice or an arbor press.
Lube the key with epoxy glue so that it goes in easier and stays in once it's in.
Kai Ju is online now   Reply With Quote
Old 05-28-2013, 08:27 PM   #15
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 1,017
We had a number of customers do that exact same thing. We were usually able to get the remains back out using a dental pick or a straight nut pick (yeah, the ones you use at Christmas).
Things NOT to do, DON'T try to snap the lock by turning the bars hard, you will ruin any chance to get it back out PLUS you will damage the steering stem.
DON'T try to use "super glue" you will end up making the remainder of the key impossible to get out.
A locksmith may be able to extract the old key from the lock but it will cast about $60. You can do it yourself with a pick.
If you can't get the old key out, Just leave it alone and use a screw driver to opperate your steering lock.
A locksmith CAN'T make you a new key without the code and he will still charge an arm and a leg!
If you want to pull out the lock out, just drift off the chrome cover (held in place with a rivit, use a drift from the back-side), turn the tunbler with a screw driver and it will "pop" out.
Pokie is offline   Reply With Quote
Times are GMT -7.   It's 08:05 AM.
