Old 05-28-2013, 01:55 AM   #1
olec OP
Rookie
Oddometer: 273
ī11 990R - fork springs w/o spring guide work
Hi!
What is the stiffest spring I can install in my forks w/o having the need for trimming the spring guides. Bike is ī11 990R. The correct spring rate for me is probably in the area where spring guide trimming is needed, but I have other bikes for other purposes and I just want to stiffen up the 990R a bit to stay a little higher when braking. I have no plans to do any revalve so itīll be stock.
olec screwed with this post 05-28-2013 at 02:07 AM
olec is offline   Reply With Quote
Old 05-28-2013, 02:48 AM   #2
Gimme 2
Team slo ass
Gimme 2's Avatar
Oddometer: 1,988
Originally Posted by olec View Post
Hi!
Its no big deal to linish the plastic guides on a bench linisher or sander , you also can do it with a block plane and a vice, very simply. as for spring rate i will choose .60
Gimme 2 is offline   Reply With Quote
Old 05-28-2013, 03:51 AM   #3
olec OP
Rookie
Oddometer: 273
I am lazy BUT, fork springs I usually change with the forks still on bike just lifting the front after caps are dismounted. Is it possible to dismount the spring guides from the rod when it is sticking out on top of the forks (which are still mounted to the bike) ? I guess yes.... ?
Old 05-28-2013, 06:46 AM   #4
henryroten
Oddometer: 241
I've got 7.0 in mine....no trimming needed.
henryroten is offline   Reply With Quote
Old 05-28-2013, 08:42 AM   #5
olec OP
Rookie
Oddometer: 273
Where did you buy the springs and what kind of bike do you have? And you are pretty sure no binding is present?
Old 05-28-2013, 08:54 AM   #6
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,128
I used 0.64 springs from slavens racing and had to trim the guides - 5mins job using a rasp file.
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is offline   Reply With Quote
Old 05-28-2013, 09:32 AM   #7
henryroten
Oddometer: 241
Got them from Superplush Suspension and certain that there is no binding. You might want to call them to discuss. Very helpful.
Old 05-28-2013, 09:42 AM   #8
LukasM
Oddometer: 5,384
I had to trim my guides for .59 SE springs, took about 5 mins per side with a file.
Removing the guides doesn't require any more work than the springs, just unthread them when you have the caps off and the springs removed.
Old 05-28-2013, 12:52 PM   #9
jon6.0
jon6.0's Avatar
Oddometer: 546
I just put in some .62's from Slaven's and didn't need to trim.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 05-28-2013, 12:56 PM   #10
tacosupreme
tacosupreme's Avatar
Oddometer: 257
Me too, no trimming required on my '12.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 05-28-2013, 06:53 PM   #11
woodchuckexc
Oddometer: 799
Funny because I know the guys at SuperPlush and you have to trim the guides. Watched them do it many times. You might want to open your forks and take a look. I'd bet your wrong
woodchuckexc is offline   Reply With Quote
Old 05-28-2013, 11:45 PM   #12
olec OP
Rookie
Oddometer: 273
Could I also ask about your opinion for springs?
ī11 990R
1.60 / 2.50 combo on real knobbies (you know these )
Rider: 110 kg w/o gear
Luggage: Typical only one medium roll bag on the tail for some daily needs
Terrain: Gravel roads with pot holes, no carving, no woods
Style: Fast as possible with heavy breaking into turns, standing up most of the time
My problem is that the different advise is all over the places starting from .58 to over .70 Thatīs a huge difference. Canīt I use the sag rules for this type of bike? Why should it be so different so some guys take a .70 spring for their usage and another rider in the same ballpark chooses .59 ?
If the sag rules should apply, then someone knows the bike weight + my own weight and could easily mention the correct spring rate + - one step in each direction. Am I totally wrong?
Old 05-29-2013, 08:03 AM   #13
tacosupreme
Oddometer: 257
ī11 990R
The difference is the preload setting. .59 with the preload maxed out will have about the same sag as .70 backed all the way off. I went with .62 and have lots of adjustment either way depending on load, and I am happy with them. For your weight and luggage the stock rear spring should be fine. Adjust the sag by the owners manual and roost on.
Times are GMT -7.   It's 10:24 PM.
