Old 05-28-2013, 09:35 AM   #1
Woogies OP
Oddometer: 84
Random Engine cut-outs
So I have a 1973 CB125s. Great around town bike, but lately I've been having some problems. I thought I fixed these before, but they have returned.
Essentially I was driving along (~40mph), and suddenly the engine shuts off. Sometimes it does this when I pull the clutch as well. I have to pull over and it takes an unusual amount of kicking to get her started again?
Any ideas?
Woogies screwed with this post 05-28-2013 at 10:57 AM
Woogies is offline   Reply With Quote
Old 05-28-2013, 10:23 AM   #2
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,656
Here are a few.
Fouled spark plug.
Gunked up carburetor.
Dirty air filter.
All are dead simple to check on this particular bike.
Old 05-28-2013, 10:59 AM   #3
Woogies OP
Oddometer: 84
Originally Posted by Yossarian™ View Post
Here are a few.
Fouled spark plug.
Dirty air filter.
I've been putting off checking/cleaning the carb, It's simple, but the problem is my laziness. . I have a feeling that is the problem, as it was run using old fuel before I got it. It also sat for a long time before that
I'll definately check the air filter and plug too.
Old 05-28-2013, 12:56 PM   #4
Suzuki Phil
Oddometer: 635
Could be the ignition coil, heat will cause expansion and thus an open coil.
Good luck,
SP
1916 Ford Model T
1996 DR350SE
Suzuki Phil is offline   Reply With Quote
Old 05-28-2013, 01:31 PM   #5
Jan from Finland
Registered
Oddometer: 562
+1 for ignition wiring. Especially if the clutch cable goes anywhere near by.
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 05-28-2013, 01:58 PM   #6
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,050
Adjust your valves and check compression before trying to tune your carb. Tight valves will cause said symptoms and hard starting.
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 06-10-2013, 11:43 AM   #7
Woogies OP
Oddometer: 84
Sorry for bringing back an almost dead thread...
What am I checking for on the ignition coil and what does the clutch cable have to do with it?
Would tight valves cause problems all the time though? My problem is random.
Old 06-10-2013, 02:44 PM   #8
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,743
My valve seat came loose and bent my left exhaust valve. The bike wouldn't start but sometimes it would. It was acting just like tight valves. That one valve is ever so slightly open and it would be so hard to start. And when it did start, it soundling like a rachet being spun by a drill gun.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
