Old 05-28-2013, 12:30 PM   #1
Chris_W_65 OP
XR KILLER
Oddometer: 51
XR650R blown crank
Help!!
I changed my oil and filter on Saturday and there were no unwanted particles in the oil, filter or strainer, now 130km later my big end is stuffed and my engine is full of bronze shavings - not sure why this happened? I used the same oil, the filter was in the right way and I put in 1.6L oil.
Should I replace the crank with a brand new OEM crank or use an aftermarket conrod kit? I want something that will last.
I see Carillo, Falicon and Pro X rods - can anyone tell me which are good?
I have an 11:1 Wiseco (which I will be replacing). I didn't check what cam is in but I am thinking about getting a stage 1 Hotcam. I was planning on fitting a CRF450 flatslide carb but after the crank problem that may have to wait.
Chris_W_65 is offline   Reply With Quote
Old 05-28-2013, 01:29 PM   #2
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,936
Originally Posted by Chris_W_65 View Post
I changed my oil and filter -- 130km later my big end is stuffed and my engine is full of bronze shavings
You changed oil and 78 miles later one of the most reliable engines in the off-road world suffered a highly unusual failure. Either you are the victim of a remarkable coincidence or something went wrong with your oil change. I think you'll want to decide which before you spend a lot more money picking aftermarket parts.
montesa_vr is offline   Reply With Quote
Old 05-28-2013, 02:22 PM   #3
cognugget
cognugget's Avatar
Oddometer: 243
I say keep the motor stock. Stock Bore, stock cam, stock compression. They run forever without a bunch of mods.
Plated XR650R
cognugget is offline   Reply With Quote
Old 05-28-2013, 02:49 PM   #4
crypto666
Oddometer: 1,231
Falicon seem to be the top rod, and when you price it you will see why.
Someone, I think it was ridefreak, said only a couple weeks ago that there were issues with some factory cranks not having the correct side clearance on the big end from the factory, and once they start to go, they go quick.
However, when that 11:1 was put in there, was the crank done also?
The rod is the weakest link in this motor eitherway, so get something with rollers on the big and small end.
I would stick with 11:1, it isn't really that radical.
I know a few racers who have tried and like the Hot Rods crank kits; it is a complete crank w/ rod all put together for a reasonable price. Just make sure its got roller bearings on both ends.
You put oil in, filter was correct, yes its a coincident. Unless you put sun tan oil in it, that stuff sucks, even the spf 30.
crypto666 is offline   Reply With Quote
Old 05-28-2013, 03:04 PM   #5
sintax
Oddometer: 495
what year XR?
sintax is offline   Reply With Quote
Old 05-28-2013, 09:03 PM   #6
woodsxr
Oddometer: 181
Nothing to add. Just want to follow this to see what you find.
Good luck with the rebuild
woodsxr is offline   Reply With Quote
Old 05-29-2013, 08:07 AM   #7
Motomochila
Mad Scientist
Motomochila's Avatar
Oddometer: 914
Go with the Falicon and a crank balance. I'm running that and a hot cam stage 2 on my 2000 street converted 650R, Cush hub too to also protect the tranny. She a good engine and parts are becoming scarce so treat her well.
2014 KTM 690 Enduro R, 2014 EXC500,2012 BMW GTL1600, 2015 BMW GS800 Adventure, and 16 other motorcycle projects in various stages of completion. It's an addiction thing.
Motomochila is offline   Reply With Quote
Old 05-29-2013, 08:57 AM   #8
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 1,895
Cart before the horse much?
From your post you just changed the oil and changed it again within a short ammt of time...odd. Did you hear a rod knock or some such?
I agree that something major is wrong, but don't you think you should find out what exactly the problem is before you start parts shopping?
Jimmy the Heater is offline   Reply With Quote
Old 05-29-2013, 08:58 AM   #9
crypto666
Oddometer: 1,231
I asked around about balancing my crank, or really any thumper crank.
A guy at Crank Works told me to not bother with it; it doesn't buy you much if anything.
Considering that advice came from a respected crank shop, I trust it.
Old 06-30-2013, 12:23 PM   #10
Chris_W_65 OP
XR KILLER
Oddometer: 51
No, it was due for 1000km service that is why I changed it - I bought the bike used.
Now that I am riding my friend's XR650L I realize my engine did sound a bit noisy compared to the XRL
Here is what is going in
Wossner 11:1 (it had a Wiseco 11:1 but I only found out when I stripped it down)
New cam chain
New oil pump
All gaskets and seals
Probably stage 2 Hotcam and Kibble White springs
Flowed head
Pumper carb will have to wait
Apart from the big end and the resultant scoring of the piston skirts from the bronze bits the rest of the motor is mint - rockers, clutch basket, clutch bushing, cam, shift forks and bore look like brand new. Even the oil pump and timing chain are still good but I am changing those
Old 06-30-2013, 12:43 PM   #11
Chris_W_65 OP
XR KILLER
Oddometer: 51
I gave my oil change a lot of thought
Drained oil from frame (when hot)
Removed and cleaned sieve
Drained oil from engine
Removed oil pump/filter cover and removed oil filter
Replaced oil filter with correct filter (although a Champion as this was supplied with my bike). Made sure spring was behind filter and hole was facing outwards. Fitted oil filter/pump cover.
Fitted drain plugs
Filled 1.6L of Castrol Activo 4T 10W-40 (supplied with bike and same as previous owner was using)
Kicked bike over 6 or 7 times
Started engine and watched oil level come up to max level in my oil sight tube
The only possible mistake I thought I could have made was to have the filter not properly aligned with the hole in the cover and partially blocking the hole with the oil filter's seal but I checked and this is not possible as the oil filter basket is not big enough for this
The motor had an 11:1 Wiseco in - probably the big end was worn and at the same time as the oil change I dropped a tooth on the front sprocket and it was a hard 130km after that till it went pop
Obviously I will check all oil channels are clear before assembling the motor
Old 06-30-2013, 01:04 PM   #12
joexr
Oddometer: 3,773
Are you sure you didn't twist the bottom oil line after cleaning the strainer? And what do you mean by the oil level came up in the tank? Did you put ALL of the oil in the rocker cover and none in the tank?
Old 07-01-2013, 10:33 AM   #13
Chris_W_65 OP
XR KILLER
Oddometer: 51
1.6L in the frame - no, the pipe was not kinked. If my motor didn't have oil the other components would be damaged after 130 hard km
Old 02-05-2014, 12:58 AM   #14
XRPOWER
Oddometer: 90
Hi mr! Did you fin out somting what was hapend with the engine? HP
XRPOWER is offline   Reply With Quote
Old 02-05-2014, 05:47 AM   #15
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,983
I doubt it's you oil change, just coincidence. The gold shavings are what's left of the big end thrust washers. It's rare but when an XR blows a crank, 99% of the time that's the symptom. There were some 01s & 02s that suffered this problem, some before the bike was out of warranty. those were caused by incorrect side clearance at the big end when the crank was assembled. You see it more often in the street (high RPM) ridden motors. HiComp adds to the big end stresses which I'm thinking probably made a marginal situation bad enough to eventually cause a failure. Back through this thread there's more than a few examples of the same failure.
If you run higher RPMs (Sumo/street) with your HiComp I'd suggest getting it rebuilt by a reputable company like Falicon. If you run it like many folks do, a replacement crank works fine.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Times are GMT -7.   It's 02:20 AM.
