Old 05-28-2013, 12:25 PM   #1
kadesean OP
eyesuck
kadesean's Avatar
Oddometer: 981
'92 R100GS Carburation
New-ish to me '92GS. Bike runs well. Changed all fluids (trans was milky), lubed the splines (good condition, but dry) and took off on a 1,000 journey loaded 2-up around Lake Huron (well most of it anyway).
Overall fantastic trip.
Question: 2-up with bags, 80+ mph bike doing 5,500-6,000 rpm in top gear was all I could get. Started to feel like it was running out of fuel until I backed out of the throttle. Other than that hiccup bike was flawless. I have yet to do a solo, unloaded top speed jaunt. I'm not sure that I necessarily want to change anything if I don't have to. I'm wondering if I were near normal limits or should I start 'troubleshooting'.
steve-0
kadesean is offline   Reply With Quote
Old 05-28-2013, 01:10 PM   #2
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,509
Was your new-ish bike purchased some place that was at altitude? If it has 60k or so on it you might look at the carburetor diaphragms.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-28-2013, 01:52 PM   #3
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,431
Had you just filled up the tank? Sometimes when there is very little 'air' in the tank the vacuum builds quickly and it can't deliver fuel as fast as it would like. Next time that happens (if ever), unscrew the refill cap to see if the problem immediately corrects itself.
Fred * '85 R80RT G/Sified * '73 R75/5 LWB
Need a pre-80 Airhead Part? I May Have It!
Beater is offline   Reply With Quote
Old 05-28-2013, 01:53 PM   #4
kadesean OP
eyesuck
kadesean's Avatar
Oddometer: 981
No altitude here in Michigan. The last time I had a diaphragm issue on my R90/6 it was apparent even when I was solo. I suppose an inspection is easy enough.
steve-0
Old 05-28-2013, 01:54 PM   #5
kadesean OP
eyesuck
kadesean's Avatar
Oddometer: 981
Tank wasn't recently filled and it has pretty good homemade ventilation. The pulse air and shedd system have both been removed and all holes have been plugged nicely.
steve-0
Old 05-28-2013, 03:01 PM   #6
darklight79
scaffold builder
Oddometer: 426
So how accurate is your speedo. You are right on 80 mph is about 5500 plus however might have to downshift to get more. Think yer a bit crazed to roll 2 up past 80 mph on this bike Doesnt have the brakes for it maybe breifly my speedo a good 20 mph high at 80 precison german engineering
darklight79 is offline   Reply With Quote
Old 05-28-2013, 03:36 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,710
1...Sounds like it might be a fuel delivery problem, clean the petcocks.
2...And/or float adjusted to low.
do both but my monies on #2
---Albert Einstein
Old 05-28-2013, 03:54 PM   #8
kadesean OP
eyesuck
kadesean's Avatar
Oddometer: 981
Speedo was just refurbed and I believe it to be fairly accurate. I was thinking floats over diaphragms since I've experienced a torn diaphragm before and this is different. BTW: This problem happened about a quarter of a way into a 1,000 mile trip. Bike was flawless rest of the way, I wasn't on big slab afterwards
steve-0
Old 05-28-2013, 09:04 PM   #9
supershaft
because I can
Oddometer: 9,116
The way I have seen many a GS loaded two up for a 1000 mile trip, their might be absolutely nothing wrong with your bike.
Old 05-29-2013, 09:01 AM   #10
akabeton
akabeton's Avatar
Oddometer: 420
What is the rush all about?
+1
I'm surprised you didn't get out the whip.
2up and loaded, I don't think I'd be pushing it any further.
Smell the roses.
1995 R100 GSPD
akabeton is offline   Reply With Quote
Old 05-29-2013, 09:56 AM   #11
kadesean OP
eyesuck
kadesean's Avatar
Oddometer: 981
Wasn't really in a big rush. Maybe 70 miles out of 1,000 we were on the big slab. I cruised along at 70mph (the speed limit in MI), but most traffic does 75-80 so I was really just going with the flow.
I'm going to do a high speed solo run with no bags and if she pulls right along I'm going to attribute it to not needing to go any faster loaded with bags and 2-up.
I'm also getting used to the different gearing of the GS as compared to my R90/6. As I had mentiond the GS was around 5,500 rpm at 80-ish mph. I think at 5,500 rpm on my other airhead(s) I was traveling at a higher clip.
BTW: Canada is cool. Props to Manitoulin Island and the Chi-Cheemaun Ferry.
steve-0
Old 05-29-2013, 10:53 AM   #12
driggles
Oddometer: 40
Originally Posted by akabeton View Post
+1
Recipe for a tankslapper?
driggles is offline   Reply With Quote
Old 05-29-2013, 10:56 AM   #13
darklight79
scaffold builder
Oddometer: 426
They stutter
A lil at 80 plus run both petcocks open for high speed go practice a high speed 50 mph stop before venturing above 80 again
Old 05-30-2013, 09:50 AM   #14
Dreossi
Oddometer: 36
Check your plugs to see if you are runnig rich. Air filter clean? Check compression, might need rings or a valve job...
Dreossi is offline   Reply With Quote
Old 05-30-2013, 05:43 PM   #15
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,860
to be clear: It will rev up, right? Not like it wont go above 6K's right?
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Times are GMT -7.   It's 12:28 AM.
