Old 07-17-2013, 11:46 AM   #331
HBRDR
Invisible Rider
HBRDR's Avatar
Oddometer: 244
GSW mit Remus
U R Invisible
2013 R1200GS
HBRDR is offline   Reply With Quote
Old 07-17-2013, 12:06 PM   #332
iride4u
iride4u's Avatar
Oddometer: 321
Originally Posted by HBRDR View Post
Be careful about having anything stick out past the license plate holder. I had a pair of P3s and they melted. The new set is below the holder.
iride4u is offline   Reply With Quote
Old 07-17-2013, 05:12 PM   #333
mefly2
mefly2's Avatar
Oddometer: 1,211
Originally Posted by marchyman View Post
Me too.
Today I took all of the plastic off and wired a piece of wire to the low beam that will be the trigger for my Fuzeblock ... And I screwed up slightly installing the panniers first. The mounting bracket is going to have to come off to install the P3 lights... I like doing the same job multiple times.
Is there a reference for the various screw locations on the Tupperware?
Trying to prevent the multiple times ...screwing AROUND! LOL
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 07-17-2013, 10:50 PM   #334
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,467
When removing the screws I noticed that they were all the same size save one at the front center tank panel. Great... don't need to worry about which goes where. That was Monday. Today I notice this:
Note the different shoulder length.
Luckily there is only one with no shoulder (battery cover) and it is easy to tell which take the long shoulder and which take the short when you put it back together... if you are paying attention. Apparently I wasn't paying enough attention, The very last screw had a long shoulder and the remaining hole required a screw with a short shoulder. Tomorrow I get to remove the plastic again to see where I screwed up. I think I know where. I hope.
marchyman is offline   Reply With Quote
Old 07-18-2013, 02:46 AM   #335
Darklord99
Darklord99's Avatar
Oddometer: 94
Originally Posted by fubar201 View Post
Looks great. What size? Does it improve wind noise? How tall are you?
Hi Fubar,
Its 19" in length & 13" wide, yes it does quite a bit, 183cm/6', BUT, I have short legs & a long body (not like a gorilla but close ) and my body & head sit as if I were 6' 2", 6' 3".
Cheers,
DL
Darklord99 is offline   Reply With Quote
Old 07-18-2013, 03:32 AM   #336
Aggroman
Aggroman's Avatar
Oddometer: 61
Love the exhaust. How does it sound compared to stock?
Live to ride
Aggroman is offline   Reply With Quote
Old 07-18-2013, 04:21 AM   #337
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,046
Just got my Wunderlich adjustable shift lever. Holy cow, it is a thing of beauty. Will post up some pics once I install it.
Old 07-18-2013, 05:17 AM   #338
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
Originally Posted by iride4u View Post
this statement is false about the leds turning off when the high beams are on at least with my bike and its led headlamp.
true! IF you have LED.
seatec is offline   Reply With Quote
Old 07-18-2013, 05:18 AM   #339
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
How about an internal (or external) star washer to keep them from pivoting?
I could try that. Thanks for the idea.
just saw somebody else's response to that. I guess that's a no go.
Old 07-18-2013, 05:27 AM   #340
HBRDR
Invisible Rider
HBRDR's Avatar
Oddometer: 244
Remus
Live to ride
It sounds great. A little deeper but not at all obnoxious. Just a bit louder. Seat of pants, feels like it has a bit more punch, which I did not really expect.
U R Invisible
2013 R1200GS
Old 07-18-2013, 06:11 AM   #341
iride4u
iride4u's Avatar
Oddometer: 321
I think that the LEDs act a lot different from the standard lights due to the lower power draw. The LEDs are controlled by pulses not by turning on and off the power to the high beam like a standard light. Both the high and the low beam are hot all the time. I would suspect that the lights are using a ground switch as opposed to a hot wire switch. A ground switch is normally faster and a softer switch.
Old 07-18-2013, 06:30 AM   #342
khones
Oddometer: 15
p3s
Were your P3s mounted against the sides of the plate and inside the reflectors? I'm about to order a pair and this might cause me to go with a Kisan flasher instead.
khones is offline   Reply With Quote
Old 07-18-2013, 07:46 AM   #343
mefly2
mefly2's Avatar
Oddometer: 1,211
Thanks, Marchy - that is what I noticed yesterday ... also, some have the clear plastic washer / protector and others do not.
Old 07-18-2013, 08:18 AM   #344
iride4u
iride4u's Avatar
Oddometer: 321
Originally I had a double set of P3s mounted outside of the reflectors.
The Remus exhaust was installed it is closer to the center of the bike. This caused the exhaust to be directed closer to the P3s and they melted. If I had one set and they would have mounted closer to the license plate it would not have been a problem.
I have mounted the P3s below the license plate and this is not a problem with heat. I still may make a shield out of aluminum as an extra measure of safety against heat.
Old 07-18-2013, 08:27 AM   #345
Aggroman
Aggroman's Avatar
Oddometer: 61
Wow... wish I had $$$ to install one.
Live to ride
Times are GMT -7.   It's 09:51 PM.
