Old 07-18-2013, 08:50 AM   #346
atg
Oddometer: 211
Originally Posted by marchyman View Post
When removing the screws I noticed that they were all the same size save one at the front center tank panel. Great... don't need to worry about which goes where. That was Monday. Today I notice this:
Note the different shoulder length.
Luckily there is only one with no shoulder (battery cover) and it is easy to tell which take the long shoulder and which take the short when you put it back together... if you are paying attention. Apparently I wasn't paying enough attention, The very last screw had a long shoulder and the remaining hole required a screw with a short shoulder. Tomorrow I get to remove the plastic again to see where I screwed up. I think I know where. I hope.
ARCHYMAN;
Run it to the same problem: which screw goes where...
In the link below if you check the part you are trying to fix you will find the appropriate screw in the listing and its attachment point.
http://www.maxbmwmotorcycles.com/fic...1&rnd=04302013
I printed the complete set of all fairing parts and now, when in doubt I only have to check the drawings where I marked red the long neck screws.
Andre
atg is offline   Reply With Quote
Old 07-18-2013, 01:33 PM   #347
TBob
Offroad Fab Guy
TBob's Avatar
Oddometer: 697
Got these last week and they are great!!
Originally Posted by kindofblue View Post
Well I've been using the prototype riser now for about 1500 mi. and couldn't be happier. (I'm their beta tester for the GS LC.)
The 40mm risers really alter one's sitting position on the bike, giving me a much more upright and comfy position. This is going to be a must have farkle for tall riders. I'm stoked about them.
The risers don't bind the cables but just barely on the left side. YMMV if BMW's cable lengths vary a bit.
I would post pics but these are the prototype that's polished aluminum and black bolts. The production version will be brushed chrome with matching bolts.
Chris, Pres. of Rox said the production version should be available July 1.
'13 BMW R1200 GS WC
01 KTM 520 EXC
Had God not driven man from the
Garden of Eden, the Sierra Club would have.
TBob is offline   Reply With Quote
Old 07-18-2013, 03:50 PM   #348
nwpa
Generally amused
Oddometer: 499
Fender Extension
MachineartMoto fender extension
nwpa is offline   Reply With Quote
Old 07-18-2013, 05:10 PM   #349
mefly2
mefly2's Avatar
Oddometer: 1,211
nice!
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 07-18-2013, 07:47 PM   #350
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,467
That works. It also works if you pay attention to what you are doing. The two screws that go in the beak use the long shoulder because of extra thickness around the attachment point. I wasn't paying attention and used a short shouldered screw on one side. Problem resolved and now, because of the problem, I'll never forget which goes where.
Today I finished up adding the fuzeblock and powering the things controlled by the fuzeblock. I have fog lights...
and the fuzeblock install looks like this:
Note the covered SAE pigtail. That is always hot for things like battery charger, air pump, what-have-you.
The gory details are at http://www.snafu.org/pics/r1200gsw/2013/0718-fuzeblock/
marchyman is offline   Reply With Quote
Old 07-18-2013, 08:22 PM   #351
iride4u
iride4u's Avatar
Oddometer: 321
I have been looking at these for a few days so I just ordered one.
iride4u is offline   Reply With Quote
Old 07-19-2013, 02:52 AM   #352
oz97tj
oz97tj's Avatar
Oddometer: 819
I don't know about that fender extender. It looks weird. And its 80 bucks. The Fenda Extenda is 30 and looks less weird
How about an overall pic with it? Maybe then it'll blend better. Close up photos make it look like it doesn't blend with the lines of the bike.
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 07-19-2013, 04:31 AM   #353
bmwrider1946
Young Old Fart
Oddometer: 47
Modified old farkle
[IMG][/IMG]
Took the hacksaw to the old backrest form my Adventure. Purchased the Touratech rack extender and strapped on the backrest. Wife loves it. Comes off very easily.
bmwrider1946 is offline   Reply With Quote
Old 07-19-2013, 10:50 AM   #354
KermitBike
usually lurking
KermitBike's Avatar
Oddometer: 18
Originally Posted by JM View Post
I think we need pictures of your install. I don't have a '13LC but I do have a '13GSA and would really like to see the guts of your bike with the plastic off to compare it to what I say when I had the plastic off of mine. Are you planning on pulling the tank? Once I got the tank off of mine it was pretty easy to route the wires.
I've never had trouble running wires once the tupperware is removed.
My big question right now is where to tap into for the relay trigger without bothering the canbus. Is there anything under the seat that would work, or do I need to go to the headlight as suggested?
2013 BMW R1200GS LC
1976 BMW R90/6
KermitBike is offline   Reply With Quote
Old 07-19-2013, 12:02 PM   #355
mefly2
mefly2's Avatar
Oddometer: 1,211
Will the tail light feed work or because it is one of the "safety" circuits it will raise problems with CANBUS ??
Old 07-19-2013, 04:32 PM   #356
TBob
Offroad Fab Guy
TBob's Avatar
Oddometer: 697
Got my jesses today
Did this from iphone no idea if it will work
'13 BMW R1200 GS WC
01 KTM 520 EXC
TBob screwed with this post 07-22-2013 at 07:19 AM
Old 07-19-2013, 04:35 PM   #357
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,048
Nice! Is the lower part black or charcoal?
Old 07-19-2013, 04:36 PM   #358
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,467
On the GSW there is a simple tap for a relay trigger under the saddle that is switched with the ignition. I only went to the headlight because I prefer to delay farkle power until after the bike is started.
Anyway, you've two fuses under the saddle. The red w/brown trace coming from the 7.5 amp fuse is easy to get at. That idea came from the instruction for the P3 lights from Skene design.
marchyman screwed with this post 07-19-2013 at 05:30 PM Reason: spelling
Old 07-19-2013, 04:39 PM   #359
TBob
Offroad Fab Guy
TBob's Avatar
Oddometer: 697
Black
'13 BMW R1200 GS WC
01 KTM 520 EXC
Old 07-19-2013, 05:45 PM   #360
TroutHunter
Oddometer: 2
My New Toy
I picked up my GS last week then headed to the Touratech store a few days later - the good but expensive thing about living in Seattle.
Navigator IV
Small GS Tank Bag (backordered, so I'm still shopping)
OEM Auxiliary Lights (to be installed at break-in maintenance)
Touratech Engine Crashbars
Touratech Cylinder Head Guards - Black
Touratech Zega Pro Panniers 31/38 - Anodized Silver
Touratech Zega Pro Topcase 38 - Anodized Silver (not installed, waiting on the topcase rack)
On Order:
Shuberth C3 Pro
Shuberth SRC System
Planned:
Touratech Radiator Covers
Touratech Headlight Cover
Touratech Works Footpegs
Touratech Bar Risers
Maybe:
Touratech Beak Extender
Touratech Folding Adjustable Rear Brake Lever
A second f-ing job!!!
Man, I need to get my '04 GT sold!
TroutHunter is offline   Reply With Quote
Times are GMT -7.   It's 07:11 PM.
