Old 07-19-2013, 06:08 PM   #361
nwpa
Generally amused
Oddometer: 499
MachineArt Moto Fender Extender
If you install the MachineArt fender extender, take some vice grips and bend the claw to reduce the gap to the fender. I checked the extender tonight and it wasn't really snug even though the screws were tightened up. Once I took the clamps off and bent the claw portion some, the extender clamped solidly to the fender.
nwpa screwed with this post 07-19-2013 at 07:21 PM Reason: vice trips?
nwpa is offline   Reply With Quote
Old 07-19-2013, 07:15 PM   #362
fubar201
fubar201's Avatar
Oddometer: 256
Originally Posted by TroutHunter View Post
I picked up my GS last week then headed to the Touratech store a few days later - the good but expensive thing about living in Seattle.
Navigator IV
Small GS Tank Bag (backordered, so I'm still shopping)
OEM Auxiliary Lights (to be installed at break-in maintenance)
Touratech Engine Crashbars
Touratech Cylinder Head Guards - Black
Touratech Zega Pro Panniers 31/38 - Anodized Silver
Touratech Zega Pro Topcase 38 - Anodized Silver (not installed, waiting on the topcase rack)
On Order:
Shuberth C3 Pro
Shuberth SRC System
Planned:
Touratech Radiator Covers
Touratech Headlight Cover
Touratech Works Footpegs
Touratech Bar Risers
Maybe:
Touratech Beak Extender
Touratech Folding Adjustable Rear Brake Lever
A second f-ing job!!!
Man, I need to get my '04 GT sold!
Great list. Second job is right.
I tried the small tank bag and found it to be useless. Now have the large bag and am much happier.
fubar201 is offline   Reply With Quote
Old 07-20-2013, 05:25 AM   #363
iride4u
iride4u's Avatar
Oddometer: 321
One note about the Schuberth SRC. The neck roll can be very tight I removed mine because of that and now have a Sena SMH10R. This provides a similar low profile on the outside of the helmet without the fit problems.
iride4u is offline   Reply With Quote
Old 07-20-2013, 06:45 AM   #364
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 830
Thumb
I'm at the moa rally and installed this yesterday with the t25 under the seat without needing to do this.
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 07-20-2013, 07:03 AM   #365
kindofblue
kindofblue's Avatar
Oddometer: 830
Thumb adjustable rox risers
Chris Olin pres of rox risers and I figured out how to install his prototype 2.25 inch adjustable risers on Friday here at the moa rally. He's going to get them into production and they should be available online in 4 weeks.
You will need to drop the right fork (nut is 44nm and use blue locktoite when you reinstall) and zip tie the cables to the right side of the body work after snipping the zip tie that holds the cables as they enter and run under the tank area. On the left you'll only Ned to loosen the clutch bracket and move it inboard about 1/8".
If you're here at the rally the risers are on the GS LC at the Adventure Designs booth.
Doc Reid
Old 07-20-2013, 07:35 AM   #366
nwpa
Generally amused
Oddometer: 499
Sounds good, maybe I have a thin front fender?
The extension would "hold", but I could slide it around some before I tightened up the bend on the claw. Maybe I had the oddball piece.
Old 07-20-2013, 08:27 AM   #367
vproven
Oddometer: 9
What size shield did you install?
vproven is offline   Reply With Quote
Old 07-20-2013, 11:01 AM   #368
RichBMW
RichBMW's Avatar
Oddometer: 2,065
That depends on what you want to put in it. For me, its perfect as a day bag, or as an addition to some bigger luggage for a few days away.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 07-20-2013, 03:12 PM   #369
mefly2
mefly2's Avatar
Oddometer: 1,211
Navigator IV
On Order:
Shuberth C3 Pro
Shuberth SRC System
Planned:
Maybe:
Similar to my list ... except I went with the Rigid lights ...
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 07-20-2013, 03:16 PM   #370
mefly2
mefly2's Avatar
Oddometer: 1,211
Originally Posted by marchyman View Post
On the GSW there is a simple tap for a relay trigger under the saddle that is switched with the ignition. I only went to the headlight because I prefer to delay farkle power until after the bike is started.
Anyway, you've two fuses under the saddle. The red w/brown trace coming from the 7.5 amp fuse is easy to get at. That idea came from the instruction for the P3 lights from Skene design.
Is there a reason to NOT use the tail lamp wire - very easy access as well??
Is there an on line wiring diagram for the GSW ... I know BMW long ago stopped putting them in the rider manual - standard for most bikes for a long time.
Old 07-20-2013, 05:12 PM   #371
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,467
It is reported to be more likely to throw a fault. if that is fact or fiction.
Nope. I asked my dealer sales critter if she could sweet talk the service department into printing off a copy of whatever they had.... the answer was they don't have anything. I'll ask for more info when I take my bike in for it's first service on Tuesday.
marchyman is offline   Reply With Quote
Old 07-20-2013, 05:28 PM   #372
Voz
Voz's Avatar
Oddometer: 484
Is this for the pivoting riser? Is any of this required for the block riser already available on the Rox website or is that a simple install?
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 07-20-2013, 07:38 PM   #373
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,467
Let's see how much this improves the ride. It made a world of difference on my '05.
Non standard install: http://www.snafu.org/pics/r1200gsw/2013/0720-buttpad/
Old 07-20-2013, 08:28 PM   #374
JM
JM's Avatar
Oddometer: 783
I talked to a very cooperative and friendly service tech as well as everyone else at my local dealer about a wiring diagram. The tech told me there is no central file or organized wiring diagram specific material availabe for them to look at. When they have wiring questions the information is all located with each job or component they are working on. He didn't seem to like the system either but that's all BMW has given them to work with.
John
Postponing retirement one farkle at a time!
JM is offline   Reply With Quote
Old 07-20-2013, 09:35 PM   #375
fubar201
fubar201's Avatar
Oddometer: 256
*My* install was pretty simple for the block riser. Clipped the zip tie on the right but may drop and move when I have a spare moment.
Times are GMT -7.   It's 02:08 PM.
