Old 07-23-2013, 02:28 PM   #406
Stinez
Rhymes with Heinz :D
Stinez's Avatar
Oddometer: 48,563
The GOP puts the "Con" in Conservative.
Stinez is offline   Reply With Quote
Old 07-23-2013, 03:03 PM   #407
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,341
marchyman is offline   Reply With Quote
Old 07-23-2013, 04:09 PM   #408
FREDO RIDER
I'll find my way !
FREDO RIDER's Avatar
Oddometer: 664
Originally Posted by marchyman View Post
Love these crash bars.
They make sense to me, compare all the one I've seen on this forum...
FREDO RIDER is offline   Reply With Quote
Old 07-23-2013, 04:30 PM   #409
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,556
Originally Posted by KermitBike View Post
Thanks for the step-by-step. Looks like a good evening project.
It would sure be nice if the manufacturer would provide an under-seat pigtail for this purpose so that thousands of customers all didn't have to make the same mod.
No shit. It would be nice if they would do just that 'cause just about everybody does at least a few farkles.
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
'13 R1200GS
'08 WR250R
Dahveed is offline   Reply With Quote
Old 07-23-2013, 04:43 PM   #410
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,556
A quick question to those of you who have heated gear, but what size (amps) of circuit do you need to power a jacket and glove combo? Will a 10A circuit be enough for 1 person?
'13 R1200GS
'08 WR250R
Old 07-23-2013, 05:03 PM   #411
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,341
I just got heated gloves and haven't needed heated gear in quite a while. I'm hoping 10A is enough. I rarely ran as much as 50% power using just the liner. FWIW the heat-troller is rated for 15 amps.
Old 07-23-2013, 06:12 PM   #412
mefly2
mefly2's Avatar
Oddometer: 1,201
For those of you with the hard to come by upper crash bars on the 1200GSW, how do yours fit in terms of the distances from the bar to the side plastic being equal on both sides? I recently installed my TT upper bars to the BMW lower crash bars and the TT are not very symmetrical ... more than 1/2 inch difference between left and right.
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 07-23-2013, 09:54 PM   #413
iride4u
iride4u's Avatar
Oddometer: 321
Todays add-ons.
2013 R1200GS LC red
2012 K1600GTL blue
iride4u is offline   Reply With Quote
Old 07-24-2013, 04:46 AM   #414
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Originally Posted by iride4u View Post
Todays add-ons.
What's that thing below and to the left of the radar detector with what looks like a grey button?
Old 07-24-2013, 07:19 AM   #415
iride4u
iride4u's Avatar
Oddometer: 321
It is a Sena SM10. This allows my helmet to pick up the voice and sound alerts from the Escort. It also will help in rider to rider communications and you could plug in an I-pod if you wanted. I have music recorded on a mini SD card in the GPS. I like to get everything connected either hard wired or Bluetooth.
2013 R1200GS LC red
2012 K1600GTL blue
Old 07-24-2013, 01:04 PM   #416
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,556
I'm thinking 10amps should do a jacket and gloves. I don't own either now, but I'm planning ahead. If its 15amp, then the fuzeblock will be tapped out for 2 people.
'13 R1200GS
'08 WR250R
Old 07-24-2013, 01:53 PM   #417
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,341
From the Fuzeblock web page (assuming you are being specific about the Fuzeblock FZ-1 and not using the name in generic terms).
The FZ-1 has two separate current paths. One is for constant power and the other goes through the relay for switched power. Each circuit can handle up to 10A (120W). The total amperage used via the relay (switched power) should not exceed 30A (360W). The total amperage on the constant side should not exceed 30A (360W). The total amperage for the entire FZ-1 should not exceed 30A (360W).
This is why I really hope the liner/gloves will work with 10 amps. If not I'll have to add another relay and feed the relay trigger from the Fuzeblock.
Old 07-24-2013, 02:32 PM   #418
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 831
Rox Risers has 40mm risers available now. Just sayin...
Originally Posted by Hambonee View Post
ugh...have had those on order since mid June and Wunderlich said today on back order till Aug still. How the heck did you get a hold of a set?
Have a trip to Bend early Aug that those would be really nice having for.
Doc Reid
2013 GS LC Red (the fastest color )
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 07-24-2013, 02:35 PM   #419
kindofblue
kindofblue's Avatar
Oddometer: 831
I thought the Sena SM10 (have one) could only pair with 1 other bluetooth unit at a time. Isn't that right? If so, you couldn't listen to your iphone music and radar detector at the same time.
Doc Reid
Old 07-24-2013, 04:13 PM   #420
nwpa
Generally amused
Oddometer: 499
SW Motech Luggage Rack
SW Motech Luggage Rack, Soft Luggage Adapter Plate, and Moto Fizz Medium Bag
Adapter Plate:
Luggage Rack
MotoFizz Medium, Unexpanded
nwpa is offline   Reply With Quote
Times are GMT -7.   It's 06:23 AM.
