Old 07-25-2013, 09:31 AM   #436
GSDiva
GSDiva's Avatar
Oddometer: 73
Originally Posted by KTMforget View Post
Just to clarify, we are working on 1-1/2" bar risers. No issues with the cables length or mods required. Hope to have a prototype soon.
Will those risers have the capability of setting the bars back closer to the rider?
Forever young
GSDiva is offline   Reply With Quote
Old 07-25-2013, 10:15 AM   #437
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,560
Originally Posted by marchyman View Post
Yeah, but... you do. At least you do with a heat troller or other PWM control device. You just don't pull full power 100% of the time. 50% power really means full power for 50% of the time.
If the gloves and liner pull more than 10 AMPS the fuzeblock will not work reliably. In that case you'll need to either connect the heat troller directly to your battery (and remember to turn it off when not in use) or connect it to the battery through a relay where the relay is controlled by the fuzeblock.
Today's bike farkling... I installed my personalized plate now that it is assigned to the new bike. That let me toss the dealer bracket and move the P3 lights inboard, closer to the license plate.
I'm now looking at the Eastern Beaver fuse block. It has a higher overall amperage and 8 circuits.
Sent from my iPhone using Tapatalk and my finger.
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
'13 R1200GS
'08 WR250R
Dahveed is offline   Reply With Quote
Old 07-25-2013, 10:48 AM   #438
thepopeofchilitown
thepopeofchilitown's Avatar
Oddometer: 51
Hey guys, I've got a question about luggage. Besides the Vario boxes through BMW, are there any aftermarket boxes that will fit on the saddlebag mounts that are installed from the factory? It seems like all the luggage named off so far requires another mount.
thepopeofchilitown is offline   Reply With Quote
Old 07-25-2013, 11:08 AM   #439
TBob
Offroad Fab Guy
TBob's Avatar
Oddometer: 697
Vario is it for factory mounts
'13 BMW R1200 GS WC
01 KTM 520 EXC
Had God not driven man from the
Garden of Eden, the Sierra Club would have.
TBob is offline   Reply With Quote
Old 07-25-2013, 11:09 AM   #440
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,382
Just thinking out loud here.
If,
- prior model GS's had expensive glass headlight units that broke when hit with rocks
- doesn't the use of plastic (probably Lexan / polycarbonate) in the LC GS now mean that all your headlight protectors are a waste of money?
After all, how many of you guys have headlight protectors on your cars' polycarbonate headlight enclosures?
Gracie's Gold
Lobby is online now   Reply With Quote
Old 07-25-2013, 12:28 PM   #441
Stinez
Rhymes with Heinz :D
Stinez's Avatar
Oddometer: 49,222
If,
There were 2 13GSW's camped near us in Salem. (Colorado plated as I recall)
One had a seriously* broken headlight lens.
* Open enough that rain would get in.
It appears that the lens' flat surface is just waiting for something hard to take it out. (Much like the multiple windshields a friends' Toyota FJ has gone through for the same, flat surface, reason)
The GOP puts the "Con" in Conservative.
Stinez is online now   Reply With Quote
Old 07-25-2013, 01:47 PM   #442
nwpa
Generally amused
Oddometer: 499
LED or Halogen?
nwpa is offline   Reply With Quote
Old 07-25-2013, 01:47 PM   #443
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,464
Is it plastic for both LED and Halogen versions of the headlamp?
Many folks in the car world use a clear film over their headlight enclosures. I've some of that clear film that I'm going to use to cover the halogen light on my GS... I'll get around to installing it one of these day.... maybe even this afternoon.
marchyman is offline   Reply With Quote
Old 07-25-2013, 02:04 PM   #444
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,382
Are you sure those weren't shill Touratech employees?
Gracie's Gold
Old 07-25-2013, 02:39 PM   #445
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,040
I just went out to the garage and tapped my halogen headlight with fingers and then metal. Seems like glass to me.
Old 07-25-2013, 02:44 PM   #446
Hambonee
Hambonee's Avatar
Oddometer: 178
Yeah..purdy sure they are glass...mine sure feels like it...
I don't think the wire ones would offer much protection but would the plexiglass sort difuse or lower the effectivness of the headlight?
Hambonee is offline   Reply With Quote
Old 07-25-2013, 02:46 PM   #447
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,040
Can someone with the LED headlight comment on what they think it is? Glass, or plastic?
Old 07-25-2013, 04:47 PM   #448
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,286
My LED headlight is plastic for sure.
I bought a piece of ClearBra type film and cut it to fit the headlight, unfortunately the film I bought had some spiderweb creases which did not come out when installed, so I removed it and ordered some more from a different supplier.
It's real easy to cut the correct shape by removing the plastic ring around the lens and using it as a template, although it appears that the trim ring does not exist on the halogen light.
Pull chocks.
JetSpeed screwed with this post 07-25-2013 at 05:44 PM
JetSpeed is online now   Reply With Quote
Old 07-25-2013, 05:15 PM   #449
nwpa
Generally amused
Oddometer: 499
Originally Posted by JetSpeed View Post
My LED headlight is glass for sure.
I respectfully disagree. Mine is "plastic".
Old 07-25-2013, 05:22 PM   #450
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
I'm not going to lie. I installed a touratech light guard mainly because it looks bad ass. Sue me!
Got places to do and things to be.
'14 1200 GSA
seatec is online now   Reply With Quote
Times are GMT -7.   It's 09:12 AM.
