Old 08-18-2013, 09:33 PM   #751
bolderboulder
Oddometer: 120
Originally Posted by fubar201 View Post
Laminar Lip install today. Booming buffeting problem solved! 80 mph with face shield up and no ear plugs. I'm a huge fan.
I installed a Laminar Lip last week and did a 300-mile ride today. It didn't seem to do anything at all, at least nothing noticeable, same buffeting
bolderboulder is offline   Reply With Quote
Old 08-18-2013, 10:09 PM   #752
Rustynuts
Rustynuts's Avatar
Oddometer: 80
Originally Posted by emack View Post
I haven't taken any farkle-specific pics of the bike yet, just been riding a lot. I LOVE THIS BIKE!
I am also loving mine...KCCO
Rustynuts is offline   Reply With Quote
Old 08-19-2013, 05:59 AM   #753
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 831
Originally Posted by Emoto View Post
I installed an accessory socket today.
Thanks for the excellent write up!
Doc Reid
2013 GS LC Red (the fastest color )
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 08-19-2013, 06:10 AM   #754
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
My pleasure. As I add or do more things, I'll post those up, too. Sadly, my budget does not permit lots of things to happen at one time.
Old 08-19-2013, 07:45 AM   #755
mefly2
mefly2's Avatar
Oddometer: 1,201
Many of us are in the same boat as you are ...budget-wise.
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 08-19-2013, 07:46 AM   #756
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Old 08-19-2013, 08:47 AM   #757
fubar201
fubar201's Avatar
Oddometer: 256
That's a shame. It's still working for me.
It is such a complex thing. Screen size, shape, height/size of rider, helmet, etc. I struggled for 3 years on my Buell Ulysses until I finally found the right combo of shield and wings. Good luck!
fubar201 is offline   Reply With Quote
Old 08-19-2013, 09:52 AM   #758
Stinez
Rhymes with Heinz :D
Stinez's Avatar
Oddometer: 48,563
Yes, as previously said, the PIAA switch works very well ...IIRC, the load for two D2s is around 5 amps max. PIAA also makes a nifty switch bracket for around $20 - but you can easily make one out of alum flat stock from the hardware or hobby store. I mounted my bracket to the mirror post rather than the housing mounting bolts.
Dahveed- PIAA makes an very nice universal bracket (#74000) with which to mount lights to the crash bars.
After reading the controller diagram closer it looks like the switch doesn't see the amperage I thought it did. It simply talks to the controller so it's actually only seeing a slight bit of amperage.
I have a PIAA switch that was removed from a bike before I sold it.
(The lights didn't survive the vibration of back road Baja. The wiring and the switch did.)
I think I'll try to integrate it into this new, and hopefully better, set-up.
I just bought p-clamps from Lowe's and they work just fine. Not pretty, but I don't really care. And the lights stay where I put them.
We use these clamps at work.
They are great in a stationary application.
I personally wouldn't use them on anything that includes lots of vibration, a little twist and some weight because they crack where they get stressed. And once they crack they'll tear all the way through in a short amount of time.
If it was me I'd add a loose fitting tie wrap to that set-up (To catch them if they fall) until you find out if they can handle the stress. BUT that's just me.
The GOP puts the "Con" in Conservative.
Stinez screwed with this post 08-19-2013 at 10:09 AM
Stinez is offline   Reply With Quote
Old 08-19-2013, 11:19 AM   #759
bolderboulder
Oddometer: 120
Laminar Lip for sale here. I'll get a Cee Bailey shield - hope it'd work
bolderboulder screwed with this post 08-19-2013 at 11:45 AM
Old 08-19-2013, 12:26 PM   #760
cnj3
Oddometer: 53
P3 Lights and Eastern Beaver Fuse Block
AM installing P3 Lights per earlier posts where power is tapped into 7.5 amp accessory plug. Also need to trigger a relay for Eastern Beaver fuse block. Think I can use same 7.5 amp accessory plug wire for triggering relay as well as power for P3 lights?
cnj3 is offline   Reply With Quote
Old 08-19-2013, 01:17 PM   #761
mefly2
mefly2's Avatar
Oddometer: 1,201
Should work, but I went to the park/city light for my trigger source ... not wanting to risk any CANBUS issues...and also a relay for the actual power to the lights. What's another 18" of wiring! Now, if somehow BMW would give us a schematic like they used to, we could track down the wiring much better.
Old 08-19-2013, 06:25 PM   #762
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
TT/Wunderlich headlamp guards
The manufacturers state they are 'for offroad use only' and they are not E-marked. But I figure you're just as likely (maybe more so) to get a cracked headlamp from a stone flying out of someone's tyre on the motorway than at low speed off road particularly if you're not in a group.
Anyone use these on the road? Any problems with the authorities?
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 08-20-2013, 04:55 AM   #763
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
I have one of the TT wire mesh ones on my 2005 since almost new and have had no issues of any sort with the authorities, even when pulled over for various reasons.
Still waiting for more choices on the new one.
Old 08-20-2013, 09:21 AM   #764
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Thanks for getting back... might remove it for riding at night, sounds like it wouldn't be a hassle in the daytime.
Old 08-20-2013, 09:49 AM   #765
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,139
Aka: Adel Clamps, commonly used on aircraft.
Lowe's refers to these as a "Rubber Insulated Clamp", but if you want to find a vast assortment of sizes and materials (like stainless steel) you can search online under "Adel Clamp" and come up with zillions, these clamps are handy.
Remove chocks and chains.
JetSpeed is offline   Reply With Quote
Times are GMT -7.   It's 01:31 AM.
