Old 05-29-2013, 11:58 AM   #1
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,101
Changing Spark Plugs on a 2007 990ADV
I got my air filter out of my 2007 990ADV and would like to change my spark plugs as well. Can that be done without removing the tanks? I have only changed the plugs once while I was checking the valves and I can't remember what all has to come off. If it don't have to take much off to access the plugs with the filter out, I will change them now, otherwise, I will wait till I check the valves again. Thanks!
Donnie - Retired & Riding - 2010 990ADV - 39,152 Miles - 1 Continent - 10 Countries
Traveling Mexico 2014 - SPOT
dwj - Donnie is offline   Reply With Quote
Old 05-29-2013, 12:53 PM   #2
Hipster
Hipster's Avatar
Oddometer: 1,775
I'm not sure if you can change out both plugs without removing the tanks. That's why I use NGK DCPR8EIX Iridium plugs on my '08, and change them out when I check the valves. Also, these plugs are available from Rock Auto.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 05-29-2013, 12:55 PM   #3
dwj - Donnie OP
Oddometer: 14,101
How often do you change the Iridium plugs?
Old 05-29-2013, 01:02 PM   #4
Hipster
Hipster's Avatar
Oddometer: 1,775
I just changed them out this past weekend after 12,000 miles and they looked good, I'm sure they could have gone many more miles. But, I already had the replacements on hand, so I just changed them.
Old 05-29-2013, 01:04 PM   #5
Orangecicle
Orangecicle's Avatar
Oddometer: 2,473
Realistically, you need to take the tanks off. The rear comes out pretty easily. The front is pure hell. I find the easiest way to get it out is to remove the radiator for easy access. Otherwise, you are fighting space issues all the way.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is online now   Reply With Quote
Old 05-29-2013, 02:20 PM   #6
dwj - Donnie OP
Oddometer: 14,101
Thanks! I think I will wait till I do the valves again.
Old 05-29-2013, 02:32 PM   #7
dwj - Donnie OP
Oddometer: 14,101
BTW, I went ahead and changed the air filter at 20,315 miles, but it did not look dirty at all!
Old 05-29-2013, 02:35 PM   #8
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,237
Not sure if the 990 is the same as the 950,,,, but I can get the front plug out of my 950 Adv without too much drama. Thin wall spark plug socket (I just use a standard deep socket), short 3" extension, universal and a long 9" or so extension. Easy peasy.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 05-29-2013, 02:45 PM   #9
Mud Missile
Aventurero
Mud Missile's Avatar
Oddometer: 170
I just did it on my '08 and as you said, the back spark plug was easy but the front was a bit more complicated. I did not removed the right tank, only the left one. I disconnected the radiator, whose, and moved it toward the front wheel. It gave me enough space to remove the plug. One thin I found out is that the 08 plugs are different than 2010 990. We worked on two bikes simultaneously and the sockets were different as well. I used a spark plug socket from a Yamaha 400 dirt bike.
Mudmissile
Mud Missile is offline   Reply With Quote
Old 05-29-2013, 03:04 PM   #10
Irideeverything
Oddometer: 46
I changed my plugs when both tanks were already off and it was difficult at best, especially the front.
Last weekend I pulled the throttle bodies off and the air box out and the front plug is right there ready for the changing...
This is on an 08 990
Irideeverything is offline   Reply With Quote
Old 05-29-2013, 03:09 PM   #11
dwj - Donnie OP
Oddometer: 14,101
I had changed my plugs at 10,000 miles when I checked the valves. I will recheck them again in the next 5,000 to 10,000 miles and will change the plugs at that time. I just ordered the Iridium Spark plugs. I have a new pair of standard plugs, but assuming my valves are holding steady on the next check, I probably won't check them for another 30,000 miles.
Times are GMT -7.   It's 04:51 AM.
