Old 05-29-2013, 12:13 PM   #1
smokskrene OP
Creeper
smokskrene's Avatar
Oddometer: 39
Leaking forks
I had my tires replaced and now I have notice that I am leaking a significant amount of oil from the top of the gaitors. Coincidence? Or should I contact the shop about it?
smokskrene is offline   Reply With Quote
Old 05-29-2013, 05:26 PM   #2
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,272
I'm having trouble understanding how a shop changing tyres would result in leaking fork seals?
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 05-29-2013, 05:57 PM   #3
Warin
Retired
Oddometer: 2,145
Never worked with customers? It is always the fault of the guy you paid to work on it last.
Ok OP .. you should where the oil is coming from! It could be a break line ... . Please check before you ride it.
If it is the break line .. then is it a junction or has a line worn through? If the tire has worn through the line then ... If a junction .. it could have been flexed if the break calipers were not supported if they were removed from the legs when the tire was replaced.
If it is from the fork seal .. then you can try cleaning it .. sometimes a bit of dirt can become trapped between the seal and leg ..
Warin is offline   Reply With Quote
Old 05-29-2013, 06:13 PM   #4
Plaka
Brevis illi vita est
Oddometer: 4,612
When you remove the wheel the fork lowers drop to full extension. They may not have been there for quite a while. The seals run over surfaces they have not run over for a while, including dirty or damaged surfaces. This can provoke a leak in an old seal.
The fork legs should be aligned when the front wheel is refitted. Shops that don't know airheads may not do this. This can also result in the forks running in a different way than they were before.
Old 05-29-2013, 07:33 PM   #5
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,745
Every time the bike goes on the centerstand the forks drop to full extension. And you don't have to align the forks when the front wheel is removed.
I call horsepucky.
--Bill
'73 R60/5 Toaster
Old 05-29-2013, 07:41 PM   #6
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,506
I call horsepucky.
--Bill
I'm with you Bill. Yep, lots of horse stuff.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-29-2013, 08:06 PM   #7
Plaka
Oddometer: 4,612
I call horsepucky.
--Bill
I'd forgotten that. Real centerstand. Haven't had one in too long.
Align the forks (the bouncy bouncy routine) every time. From the fork brace down, no need to disturb the triples.
Old 05-30-2013, 11:00 AM   #8
supershaft
because I can
Oddometer: 9,116
Plus the bouncy bouncy routine is applicable to many, many different bikes. Nothing airhead specific about that. Personally, I just pull the slider back out with my hands and then let the slider slide back to it's neutral position on the axle. I think it works better than the bouncy bouncy routine.
Old 05-30-2013, 07:02 PM   #9
100RT
100RT's Avatar
Oddometer: 720
I agree with your method, I do the same. If using the bouncy method on disk brake bikes dont use the front brake while doing so. It clamps the forks to the wheel via the brake.
100RT is offline   Reply With Quote
Times are GMT -7.   It's 04:40 PM.
