Old 05-29-2013, 03:31 PM   #1
Drumboy OP
Drumboy's Avatar
Oddometer: 219
Laugh Finally got a GSPD
The first time I really looked at a GSPD much as at D2D last year and I've wanted one ever since. The day after D2D my motor seized in the middle of nowhere between the border & Chicken and there was one near Anchorage that I should have bought but I was stuck in Fairbanks and just sold my KLR for next to nothing and flew home.
I found this last night on Craigslist and it won't run because of a broken throttle cable. It has aftermarket Mikuni carbs and the PO had some stock cables modified to work and one of them broke. It hasn't been babied and needs some other work including a new drive shaft boot. What are some things I should immediately check?
Drumboy is offline   Reply With Quote
Old 05-29-2013, 03:45 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
Your two threads belong in Oldscool!
Nice bike by the way!
Jim
Old 05-29-2013, 03:55 PM   #3
Drumboy OP
Drumboy's Avatar
Oddometer: 219
Oops. I'm opening one there.
Old 05-29-2013, 04:15 PM   #4
Noonen
Noonen's Avatar
Oddometer: 21
Jim
he's an Aggie, whaddya expect
1978 Kawi ke175 (Green)
1983 Yamaha rz350 (White)
2013 Yamaha Super Tenere (White)
Noonen is offline   Reply With Quote
Old 05-29-2013, 04:17 PM   #5
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,511
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 05-29-2013, 04:20 PM   #6
Drumboy OP
Drumboy's Avatar
Oddometer: 219
Ha. True that.
As I was unloading it a new neighbor with a British accent asked if I had a tough trip. Told him "I wish" and how it wasn't running and he said he noticed the "scramblers" in my garage. I need to sell him my old KLR.
Old 05-29-2013, 04:43 PM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,512
Change all fluids and check the drain plug magnets on the trans and final drive for metal particles. Fine metal fuzz is normal, but gritty particles you can feel between your fingers or fish-scale-like flakes are bad news. Replace the driveshaft boot as it keeps crud out of your driveshaft which already has a tendency to fail early anyway. When you pull the swingarm off to replace the boot, pull the shaft out of the swingarm and make sure the u joints have ZERO play in them and are nice and tight. If not, your shaft is on its way out. Check valve clearances and rocker end float. Adjust them to spec if they're out. Depending on mileage, it might be up for some head work. Exhaust valve guides on the R100s tend to get loose and wobbly early. You might check exhaust valve wear by shining a light down a plug hole and turning the engine over with the rear wheel until you can see the edge of the exhaust valve. If it's getting really thin, it's time for a head rebuild. Steering head bearings, paralever bearings, bla, bla, bla the list goes on.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-29-2013, 05:45 PM   #8
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,045
They prefer to be called Agro-Americans now.
I'm a Red Raider.
Cordless screwed with this post 05-29-2013 at 08:15 PM
Cordless is offline   Reply With Quote
Old 05-29-2013, 06:32 PM   #9
patrkbukly
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,101
Congrats fellow BUT NOT...
Congrats fellow GSPD'er.
Great bike.
Now for the bad news....I'm a Longhorn.
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 05-30-2013, 12:05 PM   #10
Drumboy OP
Drumboy's Avatar
Oddometer: 219
We're cool as long as you're not a dirty corn dog smelling Cajun.
Times are GMT -7.   It's 10:40 AM.
