Old 06-07-2013, 05:55 PM   #31
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,615
Last time I had a seized carb slide I used a high quality penetrating oil and soaked it for a few days, then I pried ever so gently with a piece of plastic and it broke free with little force.
A few heat / cool cycles from a blow dryer may help.
I'd do a leak down test or change out the crank seals before firing it up.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 06-07-2013, 08:12 PM   #32
Imflyinn OP
Oddometer: 24
Its awesome seeing all those Yamaha enduros together on the picture page! I didn't get a chance to try the carb tonight, hopefully I will tomorrow. Anyone know if the slide and sleeve are the same metal? There looks to be very little if any gunk around the carb. And what about freezing the carb? Everything I have seen has said to use heat, but could getting it cold make the sleeve expand and free it up?
Imflyinn is offline   Reply With Quote
Old 06-08-2013, 07:19 AM   #33
joexr
Oddometer: 3,773
Might be worth a try , couldn't hurt. How are you going to get it off of the cable?
Old 06-08-2013, 02:33 PM   #34
Imflyinn OP
Oddometer: 24
Got it unstuck and pulled all apart! Lots of WD-40 and then hit it with a screwdriver and it slid right out, and there is no rust there was only some varnish holding it
Old 06-08-2013, 02:50 PM   #35
joexr
Oddometer: 3,773
Cool. Hope the rest goes as well.
Old 06-12-2013, 11:30 AM   #36
gloud
Oddometer: 158
For varnish a little heat (heatgun) will help. Good luck
gloud is offline   Reply With Quote
Old 06-12-2013, 06:27 PM   #37
Imflyinn OP
Oddometer: 24
I got the case pried open today and there is more varnish inside the case that needs to be cleaned out. I keep reading to soak the carb in carb cleaner, by soak should I fill a bucket with cleaner and let the carb sit in it for a while or keep spraying and drying it?
Old 06-12-2013, 06:28 PM   #38
Imflyinn OP
Oddometer: 24
Also the air filter is crumbling, it is like a triangle shape is it safe to use or should I try and find a new one?
Old 06-12-2013, 06:49 PM   #39
joexr
Oddometer: 3,773
Try to find a filter. You don't want to suck dirt or crumbling filter thru the motor. The carb isn't really that complex. I'd just take it apart and shoot carb cleaner all over it and thru all of the passages.
Old 06-13-2013, 08:44 AM   #40
Imflyinn OP
Oddometer: 24
Is carb cleaner what I should be using or would there maybe be something better for it?
Old 06-13-2013, 01:18 PM   #41
gloud
Oddometer: 158
The carb cleaner is the stuff in a 1 gal pail that Autozone etc sell. Made by Gunk. the spray cans are just to spray it off.
http://www.grainger.com/Grainger/GUN...130613201744:s
Old 06-14-2013, 06:14 PM   #42
adventuro
Oddometer: 16
uni filter makes a filter for it. I found one for my 78 yz400 through dc plastics.
adventuro is offline   Reply With Quote
Old 06-17-2013, 01:57 PM   #43
Imflyinn OP
Oddometer: 24
Got the Gunk hopefully I will be able to clean the carb tonight or tomorrow. Thanks for finding that I will be ordering one soon!
Old 06-17-2013, 05:18 PM   #44
joexr
Oddometer: 3,773
The YZ and DT filters are going to be different.
Old 06-19-2013, 12:41 PM   #45
gloud
Oddometer: 158
http://www.bikebandit.com/k-n-replac...-filter?m=7101
and ebay has Yamaha filters for it.
Times are GMT -7.   It's 12:19 AM.
