Old 06-04-2013, 07:19 AM   #1
grant22 OP
grant22's Avatar
Oddometer: 487
Extended Warranty Questions - 2013 990 Baja
Hi men, let me first apologize for not having searched first.......I'm currently on my way to Phx to pick up a Baja and wanted to ask about opinions on an extended warranty, and was hoping you could all help without me doing a search.
I'm not looking for the opinions such as 'I never get an extended warranty' or broad opinions like that. I've owned many new small engine vehicles and have never bought extended warranties. Never bought them for cars, either. It's also turned out ok every time.
The 990 has me a little more apprehensive though due to its complexities and expensive repair costs.
Regarding 990 Adventures specifically, what do you guys think about a 5 year warranty for $899? Yay or nay? Does any little mod void KTM's warranty?
Within the first 5 years of ownership, have any of you needed to use your warranty or had problems causing you to wish you had a warranty?
Thx for any help.
grant22 is offline   Reply With Quote
Old 06-04-2013, 07:29 AM   #2
catalina38
Contrarian
Oddometer: 1,667
I wouldn't bother with the extended service contract and you have until the factory warranty runs out to buy it. Ride the bike for a year or two depending on the length of the warranty then decide. You can then shop around for a better deal with out the salesman pressure.
$899 is not a good deal.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 06-04-2013, 07:30 AM   #3
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,850
When faced with the same decision, I passed on the warranty. I figured I was likely to make so many modifications to the bike they could easily avoid paying out on it. Also, they could easily argue abuse based on the condition the bike will be in after the standard warranty expires.
Further, I guessed the odds of my totalling the bike in some crash was greater than catastrophic loss of engine parts. For that, I have insurance.
Don't know if that helps.
Watch out on the highway with the 908 tire. Not stable. The Corvair of tire combinations.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 06-04-2013, 07:46 AM   #4
grant22 OP
grant22's Avatar
Oddometer: 487
Thx guys. I'll likely pass on it.
Regarding tires, I'm having them put on some different tires.
Old 06-04-2013, 07:58 AM   #5
GJ990
GJ990's Avatar
Oddometer: 345
The 908 front end has a wiggle when hitting a tar snake or crossing the center line under acceleration and after 2500 miles it has become less of an issue, but I wouldn't call them outright dangerous. They are so good off road that I've actually accepted the trade off. I find them stable up to 85 but they do get dicey above that. I would love to try this bike with proper road tires like the Conti TAs, but I'm hesitant in losing a lot of off road capability. The sandy tracks in FL will most likely not take well to a road biased tire.
990 Baja
GJ990 is offline   Reply With Quote
Old 06-04-2013, 07:58 AM   #6
catalina38
Contrarian
Oddometer: 1,667
PM sent 908RR tires
KTM 990R 500EXC
Old 06-04-2013, 07:58 AM   #7
GJ990
GJ990's Avatar
Oddometer: 345
Which tires did you request?
990 Baja
Old 06-04-2013, 08:04 AM   #8
grant22 OP
grant22's Avatar
Oddometer: 487
T63
Old 06-04-2013, 04:14 PM   #9
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 695
T63
a 130? do they make a 150? I don't see it online?
BigNastybrp is offline   Reply With Quote
Old 06-04-2013, 04:16 PM   #10
BigNastybrp
Big Nasty
Oddometer: 695
I got it for $900 I sleep better does the Baja get a 24 month or 12 like the R?
Old 06-04-2013, 09:33 PM   #11
PatSmith
Oddometer: 391
Extended warranty
I would spring for it. You will need it
PatSmith is offline   Reply With Quote
Old 06-04-2013, 09:53 PM   #12
jon6.0
jon6.0's Avatar
Oddometer: 546
T63
I put a T63 on the front and left the 908 on the rear. Clickers set to sport. Then set the preload to full stiff in front and full soft in the rear. That stopped the sketchy handling at highway speeds.
What dealer in Phoenix are you getting the bike from? I got mine from Motocity.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 06-04-2013, 10:08 PM   #13
BigNastybrp
Big Nasty
Oddometer: 695
I had super plush do the forks and shock and WOW I will tell everyone Have the fork springs and valve work done. so much better! now if my front tire didn't pop on the highway at 70mph I wouldn't have done it. now that I see the change WOW its so much better At 260lbs it needed done
Old 06-04-2013, 10:17 PM   #14
jon6.0
jon6.0's Avatar
Oddometer: 546
I just put .62 fork springs in mine and it helped a huge amount. I'll probably do a road trip to Superplush this summer or fall.
Old 06-04-2013, 10:58 PM   #15
grant22 OP
grant22's Avatar
Oddometer: 487
Yep, got the bike from Geoff at MC.
Times are GMT -7.   It's 01:22 PM.
