Old 12-09-2001, 02:03 AM   #1
Daan Verhaar OP
Oddometer: 10
Question accessory wire 955i for heated grips?
Can anyone tell me if the 955i has a accessory wire where I can fit my (non Triumph) heated grips on?
If not, which ignition key operated wire (rearlight?) should I use to connected a relais.
Thanks in advance for your help.
PS. the day after I received a letter from Triumph concerning the 'bad' clutch cables it snapped......
I've got the Hepco & Becker crasshbars installed (finally) and the look great.
Best regards,
Daan Verhaar
01' 955i
Daan Verhaar is offline   Reply With Quote
Times are GMT -7.   It's 07:14 PM.
