Old 06-05-2013, 05:37 PM   #1
blowout OP
on a mission
blowout's Avatar
Oddometer: 19
1982 XR200R 6v - 12v Conversion
i am trying to swap out the stock 6v head and tail light on a stock 1982 Honda Xr200R to a brighter 12v setup ... the bike has a street title and i just need a bare bones setup. . (no blinkers or horn or battery)
..... any detailed suggestions on how to wire it all up?
thanks
a-
(the possible parts list = ... 12v rectifier, mechanical pull brake switch, 12v hi/lo 8" bucket, a high discharge capacitor and a 3 wire 12v enduro tail light )
https://www.denniskirk.com/210301.sk...FaN9OgodBBkA5g
http://www.trailtech.net/regulator.html
http://www.oregonmotorcycleparts.com/BEC.html
http://www.ebay.com/bhp/universal-brake-light-switch
2009 KTM 690 R - 2008 DRZ 400 SM
2005 KTM 450 SMR - 2005 TW 200 SM
1985 ATC 70 - 1984 XT 550
1982 XR 200R - 1982 FT 500
1974 TL 125 - 1974 XL 350 K
blowout screwed with this post 06-05-2013 at 06:03 PM
blowout is offline   Reply With Quote
Old 06-06-2013, 10:02 AM   #2
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,769
You really shouldn't have to do much. If you wire in a capacitor, believe you will have to direct your lighting coil light to that, and then split the output to your respective headlight/taillight. I've done similar with my older TT500. Be warned; running said lights will work, but not too effective when both are running, especially you're brake light. Recommend putting a simple 2 way switch for the headlight just in case you run in the woods; that way your brakellight is somewhat visible.
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 06-06-2013, 10:34 AM   #3
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,241
The regulator you linked to is an AC regulator. If you use that, don't use the capacitor (Battery eliminator). That's only for DC systems.
If you want a DC system so you can use an LED taillight or power a GPS or something, get a regulator-rectifier and use the capacitor with it.
Luke is offline   Reply With Quote
Old 06-06-2013, 10:38 AM   #4
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
Id see if Ricky Stator still (or did) make a high output stator for it and get that and a regulator rectifier and the 12v sockets and all for it....do it right and you'll be happy and have piece of mind.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 06-06-2013, 10:48 AM   #5
Onederer
Crunch Nugget
Onederer's Avatar
Oddometer: 868
I'm not sure why you would use a rectifier or capacitor; you don't need either of those when using incandescent bulbs with AC current.
If you were converting to DC then they would be needed.
For either one you'll need a 12v regulator and likely a new stator.
The '82 or '83 XL200R used an AC system to power the headlight with a seperate system for the DC powered stuff and ignition was on it's own circuit. The headlight and ignition on the XL are close to what you already have; a wire diagram from the XL would be beneficial.
If you are using the factory tail light, it is probably a single pin and you can't get brake light function with just a switch unless you switch to a two pin socket. There is an option of using a resistor in the circuit with the single pin socket and using the switch to bypass the resistor when braking, causing the light to get brighter.
I have used LEDs for tail lights with AC current and I have yet to have one fail, they just visibly flicker a little bit while idleing.
I staired a whole thru the breaks until I remembered the carb prolly has a problem to and I'm gonna hafta work on em.
Onederer is offline   Reply With Quote
Old 06-09-2013, 07:06 AM   #6
blowout OP
on a mission
blowout's Avatar
Oddometer: 19
i ended up buying only the trailtech regulator and tying it into the single wire powering the lighting system. works fine. brake tail (12v led) and headlight 12v (25/35w) work fine with no battery.
Old 06-11-2013, 05:44 PM   #7
slimy
Wanabe Adventurer
slimy's Avatar
Oddometer: 142
Did you change out the stator from a 6V to a 12V?
You say your XR200r has a street title. Did you change out or hook up brake light to the single bulb tail light?
How much brighter is the 12V vs. the 6v lights?
I have a 1983 XR200R. We need pictures .
The adventure begins when the plan fails....
slimy is offline   Reply With Quote
Times are GMT -7.   It's 09:43 AM.
