Old 06-07-2013, 09:27 AM   #1
vwboomer OP
Buffoon
vwboomer's Avatar
Oddometer: 11,173
you jokers! you had me goin
Thinking you can break a bead with the sidestand
I need to get my Heidenau off so I can put on my new Karoo3. Tried tire irons to break the bead
put the wheel on the ground and leaned the 950 over as far as I could with the foot on the edge of the rubber Entire weight minus what the front wheel was bearing was on the bead.
5' long 1/2 x 3 flat stock under the bumper of the truck pushing on a 1' pry bar. Bent the bar, Lifted the front of the truck a few times before shooting the pry bar out. Several times.
C'mon this is ridiculous. I put the K60 on last year after taking almost 45 minutes to break the bead.
venting. but the bead still isn't broke.
vwboomer is offline   Reply With Quote
Old 06-07-2013, 09:38 AM   #2
boat.man
Chief bottle washer
boat.man's Avatar
Oddometer: 193
Did you let the air out of the tire first?
I asked God for a bike, but I know God doesn’t work that way. So I stole a bike and asked for forgiveness.
boat.man is offline   Reply With Quote
Old 06-07-2013, 09:40 AM   #3
Sumi
Sumi's Avatar
Oddometer: 1,864
Try deflating the tire first
Old 06-07-2013, 09:41 AM   #4
Sumi
Sumi's Avatar
Oddometer: 1,864
Boat.man lol
Old 06-07-2013, 09:41 AM   #5
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
dam, beat me to it.
But I am surprised it did not work. Maybe the ground was really soft?
100mpg is offline   Reply With Quote
Old 06-07-2013, 09:47 AM   #6
ToddLite
ToddLite's Avatar
Oddometer: 107
yeah I hear ya. Tried the ol' side stand bead breaking technique on my previous GS and Tourance tires that were still relatively new. no go. One thing that you might find helpful (if you haven't tried it already) is giving it a go with the side stand, rotate the tire a bit, give it another go.. etc. all the way around the tire. Eventually it'll work it's way around the bead enough that it'll finally give in. Might take a lap or two in my experience. Also, silicon spray in the bead area never hurts too...
good luck
ToddLite is offline   Reply With Quote
Old 06-07-2013, 10:00 AM   #7
DrKayak
Retro Rider
Oddometer: 808
Harbor Freight Bead Breaker - $20
http://www.harborfreight.com/motorcy...ker-98875.html
I have broke loose old tires on restore projects where the rubber was bonded to the rim with this.
Why not make it easy when changing the tires at home?
DrKayak is offline   Reply With Quote
Old 06-07-2013, 10:01 AM   #8
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,075
Definition of a true bastid luv it.
On a sensible note without sound old here chuck the wheel complete either in the sun or mums oven total deflated.
Softening these babies even on the wheel makes a HUGE difference.
Short or that, disc grinder, cutting blade and a new tube that you have been talking about for years
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 06-07-2013, 10:34 AM   #9
DirtyADV
DirtyADV's Avatar
Oddometer: 2,409
Never had a problem using the sidestand, well using the light XR400 on some hard tires it has needed to pretty much balance the entire weight of the bike on the sidestand and move it around a few times.
Never needed to use the 950 to do it yet.
Here is the solution 25 ton press with a sturdy bent press and a ratchet strap to stop it slipping:
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 06-07-2013, 10:44 AM   #10
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,538
What year is your bike? I have heard that the early ones like mine have a bigger safety bead.
I haven't been able to make the sidestand trick work either. The only way I have been able to break the rear wheel bead on this bike is to put the tire in a bench vise.
Bench vises don't pack very well, so I converted the rear wheel to tubeless in hopes I can save my bead-breaking for home.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 06-07-2013, 10:54 AM   #11
BuilderScott
BuilderScott's Avatar
Oddometer: 991
I have an '04 and I have a hell of a time breaking the bead. I use my DRZ400 side stand and lift the ass end of the bike up many times before it finally breaks. I might try out that HF bead breaker...
BuilderScott is offline   Reply With Quote
Old 06-07-2013, 10:58 AM   #12
vwboomer OP
Buffoon
vwboomer's Avatar
Oddometer: 11,173
Originally Posted by 100mpg View Post
dam, beat me to it.
ah. hah.
Air was out, concrete driveway was the base for the effort.
2004, so it probably is the safety bead. I also had a big clamp compressed as much as I could and it would not come off the bead.
Upcoming trip to Colorado. If I get a flat it's either going to come off the bead riding it flat, or it's going off a cliff.
Old 06-07-2013, 11:02 AM   #13
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,940
I'd like to talk to you about this at Hells Canyon later this month.
It's not an adventure until you cross a bridge , 2011 WR250, 2015 ktm 690r
findLadukebob
Ladukebob is offline   Reply With Quote
Old 06-07-2013, 11:06 AM   #14
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,192
I had a heck of a time getting a K60 off my 950 rear wheel...
I eventually took a Dremel and cut the bead off.
No more K60s for me.
Q~
Old 06-07-2013, 11:08 AM   #15
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
These are the go http://www.motionpro.com/motorcycle/partno/08-0519/ light enough to travel with and will break the bead easily. The side or center stands also work - just make sure that you are nice and close to the rim.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Times are GMT -7.   It's 06:47 PM.
