Old 06-07-2013, 06:28 PM   #31
vwboomer OP
Buffoon
vwboomer's Avatar
Oddometer: 10,706
Originally Posted by MortimerSickle View Post
I don't know when the bead change was done, nor do I know first-hand whether they actually did change.
I found the following in the HOW.
Maybe the change came with the black wheels. Mine are silver. I have the earliest model, the one with the bluish silver paint.
Black bike, black wheels here.
Originally Posted by corndog67 View Post
I've busted off many types of beads over the years, now I just take them to the shop, fuck the busted knuckles.
But, in the end, I use an 8 foot 4x4 or 2x4, a 16 or 18 inch piece of 4x4 and lever down on it against the bottom of my truck bumper and the short piece of 4x4. It s worked every time. And a kickstand will usually work, too, but the bumper trick always works.
I have done this with stubborn sportbike wheels. Couldn't believe that the steel bar used as a lever bent
Sure did lift up the front of the truck nicely
I WILL get this off. As noted above, I may remount it and ride around the block to see if that helps.
vwboomer is offline   Reply With Quote
Old 06-07-2013, 06:56 PM   #32
DuctTape
Oddometer: 351
I fixed 3 flats on the side of the road last summer on my 2011 using the kickstand to break the bead. I carry a small bottle of windex and spray the bead (Standing pool of windex) and then start working around the tire with the kickstand and no problem if you're patient, but she has to be good and wet.
That also goes for putting the tire back on..........good and wet. I thought about carrying a tube of KY but was afraid the Queen would find it and "for changing a tire" even to me sounds lame.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 06-07-2013, 06:59 PM   #33
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,958
Hack saw it offff
mcmann is offline   Reply With Quote
Old 06-07-2013, 07:31 PM   #34
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Well just did another carpark tyre change - as you when you travel.
Broke the bead without lube using the motion pro tools.
Spooned it back on with some lube and away we are.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 06-07-2013, 09:46 PM   #35
David37
David37's Avatar
Oddometer: 401
If a tire is that hard just trying to break the bead take it the local dealer and have them change the tire.
David37 is offline   Reply With Quote
Old 06-07-2013, 11:29 PM   #36
vwboomer OP
Buffoon
vwboomer's Avatar
Oddometer: 10,706
Problem is, there aren't a lot of dealers on the trails in the mountains
And, since that's where I'm heading next, I thought I might give it another go. I will soak it down and try again tomorrow. Good thing I have that CJ relocator
Old 06-07-2013, 11:45 PM   #37
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
As I said get the stand in nice and close to the rim. I have had to lean on the seat in the past.
Old 06-08-2013, 06:36 AM   #38
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,819
How does one use the sidestand when the bike is balanced with one wheel off?
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 06-08-2013, 06:42 AM   #39
jon6.0
jon6.0's Avatar
Oddometer: 546
My guess is they are assuming you are riding with somebody else and are using their bike to break the bead.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 06-08-2013, 06:55 AM   #40
BuilderScott
BuilderScott's Avatar
Oddometer: 977
BuilderScott is offline   Reply With Quote
Old 06-08-2013, 07:01 AM   #41
FakeName
FakeName's Avatar
Oddometer: 1,819
Ah.
2014 500EXC Black
Old 06-08-2013, 09:21 AM   #42
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
Ah.
name change? oh I get it, your under cover! oops. ignore this post...
100mpg is offline   Reply With Quote
Old 06-08-2013, 10:07 AM   #43
vwboomer OP
Buffoon
vwboomer's Avatar
Oddometer: 10,706
Well we got it. Foot of the stand was right at the rim and even with leaning on it after lubing it up, no go.
So, a 16" spoon, 2 8" spoons and a 1' prybar, lots of cursing and near missing with punches to each other's faces, but we got it
Old 06-08-2013, 01:04 PM   #44
FlyingPenguin
FlyingPenguin's Avatar
Oddometer: 213
Sidestand works fine to break the bead. Though I found out the hard way that it is best practice to use a tie down and secure the centerstand to the front of the skid plate.... when the bike rolled off of the stand and fell on its side I had to leave it down until I got the wheel back on.
"We'll burn that bridge when we get to it"
Deadhorse- 2002, 2012
ALCAN 5000- 2004
COBDR- 2014
FlyingPenguin is offline   Reply With Quote
Old 06-08-2013, 01:45 PM   #45
bigkuri
bigkuri's Avatar
Oddometer: 785
Bloody hell, another thread on this? Just stand on the damn thing
I've never had a bead on any bike or tyre that won't pop off if you just stand on the thing with your heal. Tubeless, dirt, whatever.
Are you guys trying for some surgical/clinical perfect bead break?...
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R
bigkuri is offline   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
