Old 06-07-2013, 04:06 PM   #1
D K OP
Oddometer: 482
TKC's or MT90's for a 3000 mile asphalt trip?
I'm taking my 950SE down to the Mex/Guatemala border doing all asphalt on the way down there (unfortunately).
Once down there, I will probably put more dirt oriented tires on for riding and exploring.
I have heard lots of good things about the TKC's, but the wear rate is pretty quick. Other than that, they would be my first choice.
Any case, looking for feedback from inmates with experience on these types of tires.
David
'13 EC300 Racing
’07 950SE - sold
’08 950SE - sold
’09 FE570 - sold
D K is offline   Reply With Quote
Old 06-07-2013, 04:17 PM   #2
KTMADV
Hammer Down
KTMADV's Avatar
Oddometer: 178
I like the stock tire for the asphalt its last a long time. Not bad off road if you air down to 22 psi single track hard dirt.
Ceasar Vasquez
KTMADV is offline   Reply With Quote
Old 06-07-2013, 04:37 PM   #3
Sumi
Sumi's Avatar
Oddometer: 1,813
This is for the Adventure, not the SE, but it will give you and idea:
I'd go with the Scorpions.. For onroad, they are way better than the TKC's, and almost as good offroad (don't get me wrong, the TKC's still aren't good for loose or soft offroad).. They also last longer. They're more expensive though, especially the ones with "V" speed rating.. Also keep in mind, that the ADV has a 150/70-18 rear wheel instead of the SE's 140/80-18.. So.. the wider rim on the ADV comes in handy when riding onroad. I don't know if the 140/80-18 Scorpion is as good on the SE, as the 150/70-18 Scorpion is on the ADV.
To tell the truth about the TKC and K60, etc. "dual sport" tires.
IMO!!:
They suck. :)
They aren't really good for either purpose.. The MT90 is however the best compromise (if you ride mostly onroad, maybe some light "offroad"). IMO the MT90 is the best "dual sport" tire for onroad - well I don't count the Conti trail attacks as a dual sport tire, sorry.
The best to do is to have an offroad oriented tire (or wheel) set - with proper knobbies installed on them, and an onroad oriented tire (or wheel) set - with proper onroad tires, or at least MT90's on them.. That's the only way to go if you want the best performance both on- and offroad.
But then some have reported high speed wobble problems with the MT90 front - never happened to me..
I'd forget the TKC's..
Sumi screwed with this post 06-07-2013 at 04:49 PM
Old 06-07-2013, 04:58 PM   #4
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,421
just did 1,400+ on my mt-90's and am very happy with their performance. i started with a half worn tire and ran it with too low of pressure which was not good. i was fully loaded, 2-up and pretty much ruined the tire on the 3rd, 200 mile day, granted it wasnt in the best shape to begin with. i replaced it with another in St. George, UT and put in the right amount of air (40 PSI) the tire did awesome and had no heat related issues. this was in 100-112 degrees weather coming all the way from southern utah to tucson averaging over 80 mph. tire still looks new.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 06-07-2013, 05:01 PM   #5
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
Yes, it is all compromises. I have run both the 140 and 150 Scorp on my SE, not much difference onroad but the 140 is better off I think. The scorp front will suck all the fun out of your trip if you try to use it for dirt. The TKC front is a decent compromise (use with scorp rear), will work in dirt and get u there and back. Best is your plan to switch to something like a Rallyrace front or Dunlop when down there, that is what the SE is for. Personally, I would have a Super Explorer on the rear. You lose a little bit of cornering traction if you want to run a canyon but again, more fun, will last the trip, and better offroad.
DeepInIt is offline   Reply With Quote
Old 06-07-2013, 06:19 PM   #6
triplenickel
triplenickel's Avatar
Oddometer: 2,430
TKC won't last that long, total waste of money. MT90, K60, or Mefo whatever you can get cheaper.
07 SE
PG007
Old 06-07-2013, 06:22 PM   #7
D K OP
Oddometer: 482
Thanks for your responses
Unfortunately I cant get aroundnhavingmto do a 3000 mile slab section before I can start having fun. I dont have the option of having a dedicated set of road wheels. Yet.
So, just looking for best performing 50/50ish tire that will last me the trip down here and give good traction, specially on wet asphalt.
From there, I will get a proper set of knobbies.
I have run the super explorer before, but it doesnt have good grip in the wet, I think. I ran them to Morocco and back (from Spain) and they got decent mileage. Thats about it.
D
'13 EC300 Racing
’07 950SE - sold
’08 950SE - sold
’09 FE570 - sold
Old 06-08-2013, 09:40 AM   #8
mousitsas
mousitsas's Avatar
Oddometer: 2,948
I cannot comment on the TKC, but if you sway towards MT90 simply forget it in favour of the Sahara Enduro 3. I'm talking rear tyres. Way better than the MT90 on asphalt (similar mileage but with way better grip and more gradual slidding) and very similar off-road. Expect 6k miles on the SE with lots of spinning and associated hooliganisms.
Old 06-08-2013, 10:40 AM   #9
jon6.0
jon6.0's Avatar
Oddometer: 546
I'm going to try the Karoo 3 in a 140 when my 908 wears out. It's only $94 for the 140, so it's worth a try. http://www.metzeler.com/site/uk/prod...e/Karoo-3.html
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 06-08-2013, 10:59 AM   #10
KMC1
There is no spoon.
Oddometer: 2,561
K60 rear / TKC front.
Watch out if you hit any wet weather - the K60's are terrible in the wet, and the TKC isn't stellar either. But for hot droning on the highway the K60 is tough to beat. The TKC front will be much better offroad and will most likely last at least the life of the K60.
*disclaimer: I haven't tried that combo. I've had TKC's and K60's but always as matching sets. I won't ride with the K60's anymore due to the wet weather performance, and I don't like the fronts at all. But for long distance in the dry, the rear is really good for 80% of everything.
HTH
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 06-08-2013, 11:06 AM   #11
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,818
This is right IMO. The rear just pushing, the front is steering, You don't want to have to jack around with tires during your vacation.
Guero from Texas
COHVCO
AMA
PAPA
SJTR
jimmex is offline   Reply With Quote
Old 06-08-2013, 11:18 AM   #12
jon6.0
jon6.0's Avatar
Oddometer: 546
I've got a buddy with a BMW 800GS and he can't stand TKC80 front tires. He runs the TKC 80 rear with a Karoo 2 front.
Old 06-08-2013, 12:19 PM   #13
D K OP
Oddometer: 482
Would there be any reason to go with a 80/100 front and a 150 vs. the standard sizes?
The other option is to go for trail attacks for 100% road and 908 once I get there
'13 EC300 Racing
’07 950SE - sold
’08 950SE - sold
’09 FE570 - sold
D K screwed with this post 06-08-2013 at 09:55 PM
Old 06-08-2013, 04:30 PM   #14
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,061
The other option is to go for trail attacks for 100 road and 908 once I get there
If you are just stamping down pavement just use a good pavement tyre and try and enjoy the ride a little better, as you say new boots when you get there .
At least if you get something pretty good on the tar like the MT90 you can step it up and fling it through the twisties for at least some giggles, that way you can make the most of what you are being served up.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grόvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 06-08-2013, 04:40 PM   #15
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,107
Just to throw out another thought, I put on a Pirelli Rally on the front at the beginning of this season. I don't mind the Scorpion on the rear, but I never feel comfortable with the Scorpion on the front in the loose stuff. I did one trip with this setup so far -- 250 miles across the state on pavement, 280 miles the next day on gravel and dirt, and then 250 miles back the next day in torrential rain. This setup performed pretty well in every environment, and the Rally front appears to be wearing well for the amount of pavement that it's seen. FWIW.
Orangecicle is online now   Reply With Quote
Times are GMT -7.   It's 07:34 PM.
