Old 06-08-2013, 03:07 PM   #1
renogeorge OP
Oddometer: 1,330
Adventure Tank for 990 Adventure
I have been looking at this tank for my bike, with a 2 into 1 exhaust.
Does anyone have pictures of this setup installed that they could share??
And any comments good/bad?
I also am considering just the 2 into 1, and using a Roto plex type tank attached to the inside of the hard bag racks on the left side where the 2nd muffler was. Anybody try something like that?
Thanks!!
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 06-08-2013, 07:30 PM   #2
genghis9021
Arak Connoisseur
genghis9021's Avatar
Oddometer: 238
ADVTank
I've been using it and the 2-1 from Ned since 2009 without any issues and alot of satisfaction.
Included have been shakeout rides to Inuvik from SF, across the Yukon (Campbell, Cassiar, Canol "highways", etc) and a run from Frankfurt to Ulaan Bator across the 'Stans (avoiding tarmac whenever possible).
I don't think it'll be hard to find plenty of positive comments.
2011 Husky TE 630 2011 Husaberg FE 570S
2006 KTM 950 'S' ADV 2005 Suzuki DRZ 400 SM
"The perfect is the enemy of the good." 4 bikes in 3 countries.
Orange, it's the new black Tour.
genghis9021 is offline   Reply With Quote
Old 06-09-2013, 07:57 AM   #3
renogeorge OP
Oddometer: 1,330
No pictures of an Adventure with one of these tanks installed??
KTMs--300, 518, 990
Old 06-09-2013, 08:18 AM   #4
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 674
http://www.advrider.com/forums/showt...856278&page=27
here are some
XR650 parts for sale. http://www.advrider.com/forums/showthread.php?t=1038286
BigNastybrp is offline   Reply With Quote
Old 06-09-2013, 08:36 AM   #5
renogeorge OP
Oddometer: 1,330
Thanks much!
KTMs--300, 518, 990
Old 06-10-2013, 12:55 PM   #6
Masa
Masa's Avatar
Oddometer: 297
Do a search for "advtank" and you'll get many pros and cons.
I got mine this spring and regardless of some quality issues, I've been happy with it. Just don't expect it be a straight bolt on thingy. Do your research before assembly.
Don't buy the AdvTank 2into1 pipe though, build quality on those is very poor. Unless they have corrected the manufacturing process.
Masa is offline   Reply With Quote
Old 06-10-2013, 06:56 PM   #7
renogeorge OP
Oddometer: 1,330
Thank you very much for the picture. That clears up the interference issue between the top/rear case brace and the gas filler. I would have to do a little cutting and rerouting. And I can see the front mount point to the subframe. Is there an additional mounting point other than the obvious muffler hanger?
Am I correct that a fuel line is just run forward and T'd into the left side petcock on the original tank?
KTMs--300, 518, 990
Old 06-10-2013, 07:18 PM   #8
renogeorge OP
Oddometer: 1,330
I had searched for Adventure Tank previously, getting nothing. Tried AdvTank and found threads on the install and the rack interference. Thanks again.
I'm a little on the fence about the setup now. I can handle the mounting issues, building a bracket and relocating the brace. But $800 for the 2 into 1 plus the tank, seems like it should buy you a little cleaner setup. And I haven't even read up on their 2 into 1 issues.
KTMs--300, 518, 990
Old 06-10-2013, 10:33 PM   #9
BigNastybrp
Big Nasty
Oddometer: 674
I know and thought the same thing but I tried the roto pax and have not been happy with it. I just put the 2-1 and fmf on and I like it. cooler seat and sounds good. adv tank will be next a few months from now. all my friends are running this set up 2-1 cj welded swap and a pipe of some kind.
I think the plastic is better than the other I have seen. will take a good hit but needs a brace so it cant hit the tire 908 is a tank killer I hear. B
Old 06-10-2013, 11:09 PM   #10
chrish4ku
chrish4ku's Avatar
Oddometer: 769
Currently I am at 217 miles with no fuel light. Gotta like that....
2.2 extra gallons and full ADV Remus setup = less weight than original setup with stock boat anchor pipes. I also agree with Bert - the pipe runs cooler now that it doesn't have those crappy heart cloggers on the end.
Photo & Video Sharing by SmugMug
Just make SURE you reinforce that long bracket that stabilizes the tank. It is WEAK and bends, allowing your tank to hit the tire under stress. Mine has a custom bracket that bolts to my luggage rack. Ain't no way it's going to bend and hit the rear tire now.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku screwed with this post 06-10-2013 at 11:17 PM
chrish4ku is offline   Reply With Quote
Old 06-10-2013, 11:45 PM   #11
Yascher
Yascher's Avatar
Oddometer: 388
The way you have fuel line routed inside the frame is wrong. The reason I'm saying that, is I had it the same way, until riding 2 up with ful lugguge I found I ran out of fuel too fast. On a gas station while filling up observed fuel leaking from ADV tank line inside frame. Reason-completly destroed line by chain rub with compressed susupension/ I managed a temporary fix, but routed it outside the frame since then and had ZERO issues in 2 years.
Also recently I've loast a chain tensioner, and was happy trhat the line was relocated, as the chain messed up a lot of stuff around it, way beyond any normal chain reach.
Just a tip
Yascher is offline   Reply With Quote
Old 06-11-2013, 04:28 AM   #12
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 935
I was thinking of getting the storage box version of this tank, CJDesings I think. That way I can use it for storage, or if I need extra fuel, fill one of those fuel bladders and put it in the box. Best of both worlds? Opinions?
rossguzzi is online now   Reply With Quote
Old 06-11-2013, 01:19 PM   #13
Masa
Masa's Avatar
Oddometer: 297
Originally Posted by Yascher View Post
The way you have fuel line routed inside the frame is wrong...
I see nothing wrong with chrish4ku's install. Fuel line is routed on top of the chain roller as it should be. Mine is laying on the roller and I'm fine with it, but only 2k kms with the setup. I wouldn't run it outside the frame, but I'm sure it works just fine too.
I'd get the tank. It's easier to ad an extra bag for stuff, than a proper storage for fuel.
Masa screwed with this post 06-11-2013 at 01:25 PM
Old 06-11-2013, 01:54 PM   #14
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,364
Advtank a great solution...
The combination of advtank and two into one works great for my bike. I like the lighter load of a single performance can... mine being a Remus Ti, but Wings is a great economical choice... CJDesigns for 2 into 1 connector, has proper flow test. Like others have said, add the lower brace. I'm currently running a "C" clamp off passenger mount.
200 plus mile range is great for my normal adventure touring. Of course Starbucks coffee bag for emergency fuel bladder.
You'll be quite happy.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 06-11-2013, 02:33 PM   #15
chrish4ku
chrish4ku's Avatar
Oddometer: 769
Would be cool to see a close up of your C clamp bracket for those who do not have luggage racks. I wondered how you would firm that up without racks.
Chris
Chris' Sat Tracker
Times are GMT -7.   It's 12:19 AM.
