Old 06-11-2013, 10:05 PM   #16
Yascher
Yascher's Avatar
Oddometer: 388
Originally Posted by Masa View Post
I see nothing wrong with chrish4ku's install. Fuel line is routed on top of the chain roller as it should be. Mine is laying on the roller and I'm fine with it, but only 2k kms with the setup. I wouldn't run it outside the frame, but I'm sure it works just fine too.
I'd get the tank. It's easier to ad an extra bag for stuff, than a proper storage for fuel.
I only shared my experience)))
Actually mine was running lower, flat with the bottom passenger peg bracket to ensure complete emptying of the ADV tank.
Running the line outside the frame, fixed with the robust 10mm plastic ties and resting in the bend above the plastic frame protector has proven itself bulletproof!!!...unfortunately not so much the case with the right hand side main tank line getting burned on the exhaust one day, just because it got one of the plastic clamps around battery case opened and was sitting higher and resting on the exhaust header....almost set the bike on fire
Yascher is offline   Reply With Quote
Old 06-12-2013, 05:50 PM   #17
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,364
Simple advtank lower bracket...
Originally Posted by chrish4ku View Post
Would be cool to see a close up of your C clamp bracket for those who do not have luggage racks. I wondered how you would firm that up without racks.
Of course I stole this setup from another inmate in years past. It secures the lower tank away from the swingarm path... and it uses the passenger frame mount as extra support for the weight of a full tank.
There is a better bracket I've seen for those who weld, but I've been using this for some time and it solves the advtank from sagging just as well.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer screwed with this post 06-12-2013 at 05:58 PM
DesertSurfer is offline   Reply With Quote
Old 06-12-2013, 06:19 PM   #18
sonoran
je suis sonoran
sonoran's Avatar
Oddometer: 23,629
This is a good solution. Thanks for sharing, I'll be doing the same!
sonoran is offline   Reply With Quote
Times are GMT -7.   It's 08:01 AM.
