Old 06-08-2013, 11:26 PM   #1
Nailhead OP
Painting by numbers
Nailhead's Avatar
Oddometer: 6,144
Some FM Questions...
Frequency Modulation, not Flea Market...
First, I've wondered for quite some time why FM reception seems to get worse as the weather warms. In the winter, WPR comes in consistently, well...decent on my stereo receiver. About a week ago, its signal started its seasonal degradation to "almost unusable", and it'll be this way until September or so. Why would air temperature have any effect on FM radio reception? It's gotta be something to do with the sun and its differing position in the sky, right?
Second, I was listening to said radio station about a month ago, when several times, an Oregon Public Broadcasting station faded in and out. I'm familiar with "skip", but I was under the impression that was exclusively an AM phenomenon. What gives?
Anyway, just curious & thought there would be some radio experts around here somewhere.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 06-08-2013, 11:56 PM   #2
troidus
Oddometer: 13,681
No expert, but it's probably summer foliage getting in the way.
troidus is offline   Reply With Quote
Old 06-09-2013, 09:31 AM   #3
Manuel Garcia O'Kely
Back at last
Manuel Garcia O'Kely's Avatar
Oddometer: 12,847
Christ, there are guys earning their PhD's who cannot give you a good answer.
I'm a radio amateur and it's still a mystery.
Usually what happens is that one of your RF signal paths either gets much worse or multipath gets BETTER and degrades your signal. I live in a deep valley and get radio via multpath and some days you are the windshield, some days the bug. With my amateur FM station, I get better signals in winter when the leaves are gone off the hills.
Also possible your station turned down the power due to repairs?
Do you have a real antenna or a chunk of wire?
If the latter, the former will help a lot - I put up a 6 element FM antenna for a friend and it made a huge difference.
Never ascribe to Evil that which is more resonably explained by Ignorance and Stupidity
There's casting, then there's running into the stream with a baseball bat trying to club the fish to death. - Jim Moore
Manuel Garcia O'Kely is offline   Reply With Quote
Old 06-09-2013, 09:38 AM   #4
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,001
Humidity surely is a factor as well if the signal is weak imho. My family has always owned radio stations, by the way, and Dad is a broadcast design engineer who probably knows all there is to know about RF. So I probably ought to ask him. Part of the deal is that modern receivers can work with almost no signal, and the line between almost and no signal is a thin one.
John
Sent from my SCH-I535 using Tapatalk 2
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
Another '98 DR350 for sale http://advrider.com/forums/showthread.php?t=1036981
scarysharkface screwed with this post 06-09-2013 at 09:48 AM
scarysharkface is offline   Reply With Quote
Old 06-09-2013, 09:53 AM   #5
Hardware02
Hardware02's Avatar
Oddometer: 3,397
Cold winter air is denser and transmits FM signals better...
...or...
"These instructions are at our present level of
knowledge. Legal requirements do not exist.
Technical issues subject to change."
Hardware02 is offline   Reply With Quote
Old 06-09-2013, 10:05 AM   #6
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,018
It is called ducting, where VHF radio signals get refracted or bent toward the ground which increases the range. Very different from the shortwave long range propagation which is more like bouncing than bending of the radio waves. This bouncing occurs at very high altitudes. http://en.wikipedia.org/wiki/Tropospheric_propagation
Like MGOK said radio propagation is actually quite mysterious and can change minute to minute and can change when you move your antenna a few feet. I have done a bit of modeling of VHF and UHF propagation to design telemetry systems, but I have very little faith in my models, though they at least give me a starting point (and something to show when they ask why I thought it would work all the time and it doesn't)
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 06-10-2013, 09:30 AM   #7
The_Commander
The Man.
The_Commander's Avatar
Oddometer: 6,157
Possible that the station is still using a tube type transmitter and they have poor ventilation and ducting.
At least that's what happened to one of my FM stations a decade or so ago. Mama bird built a nest which caused the transmitter to overheat and cut power.
The_Commander is offline   Reply With Quote
Old 06-10-2013, 04:38 PM   #8
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Its cause of the damn Gophers.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 06-10-2013, 07:16 PM   #9
68deluxe
68deluxe's Avatar
Oddometer: 13,714
Turn your tinfoil hat upside down. Catch more rays that way.
Seriously, FM is more affected by dense stuff like clouds, mountains, trees etc but can bounce off real hard stuff such as concrete and metal buildings. At least that is what I remember from my radio wave class 40 years ago.
2010 KTM 990ADV
2004 KTM 250SX
68deluxe is offline   Reply With Quote
Old 06-10-2013, 10:02 PM   #10
Nailhead OP
Painting by numbers
Nailhead's Avatar
Oddometer: 6,144
I do indeed have a tree between my receiver and the WPR transmitter in Douglas. I thought foliage, wood, etc., was transparent to RF, though.
Hmm...
-Chris
Old 06-11-2013, 04:52 AM   #11
garandman
garandman's Avatar
Oddometer: 6,111
OT but I discovered this at age 12 when I used to listen to an old tube radio. A Chicago AM pop station would often come on, clear as a bell - in Boston, nearly 1,000 miles away.
Edit - at night.
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman screwed with this post 06-11-2013 at 08:52 AM
garandman is online now   Reply With Quote
Old 06-11-2013, 08:46 AM   #12
The_Commander
The Man.
Oddometer: 6,157
After sunset, I suppose?
Old 06-11-2013, 08:55 AM   #13
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Edit - at night.
AM condidiotns change drastically between daylight, dusk and night. As well, some AM radio stations go to half power at night if their license dictates.
Old 06-11-2013, 09:03 AM   #14
The_Commander
The Man.
Oddometer: 6,157
And some drop their power even further during 'critical hours'. For example one of the AM stations that I operate runs at a full 50kW from sunrise to sunset, then goes to between 474 and 90 watts depending on month of year.
Some go off the air all together to allow for the clear channel stations.
Old 06-11-2013, 08:30 PM   #15
troidus
Oddometer: 13,681
1170 KVOO in Tulsa used to be used as a nav beacon. Dunno if anyone still uses AM for navigation.
Thread Tools
Times are GMT -7.   It's 02:03 AM.
