Old 06-09-2013, 06:02 PM   #1
cbmoggia OP
Oddometer: 19
Another fuel gauge question
My fuel gauge is toast. I don't mind using the odometer but I hate the yellow warning light. Is there a way to delete the gauge?
cbmoggia is offline   Reply With Quote
Old 06-09-2013, 06:44 PM   #2
Callisto224
Callisto224's Avatar
Oddometer: 1,097
Don't think there is a way to fool the computer. Why not just use the piezo lighter trick? It's well documented here (assuming you have a fuel strip).
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Old 06-10-2013, 04:40 AM   #3
Spaggy
Spaggy's Avatar
Oddometer: 919
What bike?
Spaggy is offline   Reply With Quote
Old 06-10-2013, 05:36 AM   #4
cbmoggia OP
Oddometer: 19
06 gsa
Old 06-10-2013, 04:46 PM   #5
jzeiler
ADWrencher
jzeiler's Avatar
Oddometer: 109
Dig back in the long "Faulty Fuel Strip" post and there is a collection of resistors you can put on the connector to fool the ZFE module. You want it to think it is seeing 2.7K ohms abut there needs to be another resistor from the power lead to "tickle" the fake out resistor. I could not get it to work so that is when I came up with the lighter method. That worked.
John
2009 R1200GS (Gone)
2005 K1200LT
2009 K300GT
K4AN
jzeiler is offline   Reply With Quote
Old 06-11-2013, 05:16 AM   #6
Spaggy
Spaggy's Avatar
Oddometer: 919
Isn't there a bulb in the dash you could pull? Wondering this about my '04 because it quit working and I like it.
Old 06-11-2013, 06:42 PM   #7
Frostback
Frostback
Oddometer: 234
Simplest trick I know is a small piece of black electrical tape to obscure the light.
Lee
Frostback is offline   Reply With Quote
Old 06-11-2013, 07:00 PM   #8
UrsaMobili
Canoodian Expat
UrsaMobili's Avatar
Location: Back on the left coast, on island with no ferry
Oddometer: 72
Talking
Lee
+1. Works everywhere and every time. Cost $0.00005, time consumed < 30sec.
UrsaMobili is offline   Reply With Quote
Old 06-14-2013, 10:47 AM   #9
cbmoggia OP
Oddometer: 19
I guess tape is the way to do it. I hate having such an expensive bike and having things not work. I left KTM because of stuff breaking. I can't seem to get away from that.
Old 06-15-2013, 06:24 AM   #10
Spaggy
Spaggy's Avatar
Oddometer: 919
The dash is easy to get at from the front side.
1 - Remove windshield.
2 - two torx screws hold the cover on.
3 - two allen head bolts hold the instrument panel on, then you slide it up off of the lower rubber dealys holding it on.
4 - Undo the speedo cable and cut a wiring tie to access the bulbs.
5 - Pop the offending bulb out.
Times are GMT -7.   It's 08:00 PM.
