Old 06-09-2013, 06:16 PM   #1
bruceca2002 OP
Oddometer: 275
KTM 690 Suspension
I picked up a new 690 and so far I love the bike except for the suspension. Riding over wash board is brutal and I need help from some suspension experts. I weigh 260 pounds and so far all I have done is put a stiffer spring on the shock and turn out the front and rear compression damping screws. Any info is appreciated. Cheers, Bruce
bruceca2002 is offline   Reply With Quote
Old 06-09-2013, 07:16 PM   #2
DirtSolace
Oddometer: 96
at 230 lbs (with gear) and a 8.8 Slaven spring. I have gone in the soft direction and gotten way better performance than when I had everything tight... In phases (after new spring) I've gone from 13 clicks to 20 and it feels lighter and turns better--yet, it does not feel soft....
DirtSolace is offline   Reply With Quote
Old 06-09-2013, 11:53 PM   #3
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
The front sucks and is set-up for street riding. in my opinion a re-valve is mandatory. The rear is OK, just needs a heavier spring.
Yellow Pig is online now   Reply With Quote
Old 06-10-2013, 03:28 AM   #4
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,680
could also try changing the fork oil to a heavier weight.
CanadianX is online now   Reply With Quote
Old 06-10-2013, 05:14 AM   #5
NovaMoto
Oddometer: 133
Once you re-valve the front and select springs for your weight it becomes a different bike. That is a >1,000$ solution though if you can't do the work yourself!
NovaMoto is offline   Reply With Quote
Old 06-10-2013, 05:56 AM   #6
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 982
Try 5w fork oil with an air gap of 110-115mm. Compression completely open, then in 2 - 3 clicks. Rebound 10 to 15 clicks open.
Rear - try to get balance with the front
By the way, it becomes better just before its time for a rebuild...
KTM 690 R - "Its just a little crush..."
Bill the Bong screwed with this post 06-10-2013 at 06:03 AM
Bill the Bong is offline   Reply With Quote
Old 06-10-2013, 08:11 AM   #7
gen
gen's Avatar
Oddometer: 804
Rally Raid UK is reporting that Tractive is preparing a new shock for the 690 with travel up to 300mm.
http://www.rally-raidproducts.co.uk/...in-production/
But for someone who's 230# (I am too) you'll need to have a stiffer spring to start.
DoD#1458
gen is offline   Reply With Quote
Old 06-10-2013, 10:41 AM   #8
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,806
Not if you find a good suspension shop that doesn't feel the need to rape you.
Revalve forks, and shock, respring shock (fork springs are way stiff enough for most riders), cost me less then $500 from SMS Racing.
Old 06-10-2013, 10:58 AM   #9
brianpc
Oddometer: 317
Anybody have measurements for the heavier rear spring on the shock? Or, a link on where to order / what type of spring it is? My suspension guy was going to order one for me and the spring shop says they don't have measurements for the '13 690 rear?
brianpc is offline   Reply With Quote
Old 06-11-2013, 01:51 PM   #10
bruceca2002 OP
Oddometer: 275
I weigh 260 lbs in my birthday suit. With all my gear, backpack and a extra 15 pounds of weight from my RR tanks, I am probably close to 300 pounds.
The bike came with a 8.0 n/mm rear spring. I then tried a 10.0 from Super Plush that seemed to make no noticeable difference. I have now installed a 13.0 spring from my Super Enduro and I get proper sag numbers with 10 mm of spring pre-load. I will try this out this weekend. The KTM manual calls for 18mm of spring pre-load which seems to be excessive IMHO.
The front forks seem to have a closer spring rate but also have very stiff valving resulting in a very harsh action.
Maybe a suspension tuner will offer some info as what is wrong with the valving on this bike!!!
Old 06-11-2013, 03:46 PM   #11
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,597
How complicated/involved is it to convert the 2012+ rear shock to full 300mm travel?
Old 06-11-2013, 04:08 PM   #12
Baja Dad
Baja Dad's Avatar
Oddometer: 2,033
send it to BOB BELL at Precision Concepts
or buy the NEW shock from Rally Raid UK
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 06-11-2013, 04:23 PM   #13
DuctTape
Oddometer: 351
I have and used the shimstacker software to re-valve (Gold) my 990 and the 690 is next. If anyone knows the stock shim stack I could put the shims in the software and then upload what it shows and also play around with differnt stacks, oil weight, etc.
The following pic shows 3 different stacks with the dark dotted line being the soft stock stack the 990 comes stock with. The yellow line is the updated stack.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 06-11-2013, 04:41 PM   #14
Velociraptor
TrackBum
Oddometer: 1,128
Put me on the list for the fork kit!
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 06-11-2013, 04:57 PM   #15
gen
gen's Avatar
Oddometer: 804
Race Tech has a calculator but they only have the 2008 Enduro data.
http://racetech.com/ProductSearch/1/...%20Enduro/2008
I'd speak to James at Super Plush Suspension as he is focused on the KTM suspension market.
http://www.superplushsuspension.com/
DoD#1458
Times are GMT -7.   It's 04:17 PM.
