Old 06-11-2013, 11:43 PM   #16
AccelRus MaxiMus
Oddometer: 144
Originally Posted by ktmmitch View Post
2012 on have different lower legs,less axle offset and different compression adjusters.
I assume you were referring ^^ to the 690's ?
Same lenght tubes = surprising to me since the KTM
manuals list such different fork and spring lengths
for the EXc's and 690's...
Not that I know that because I have been trying
to find a longer travel fork for my 690...
Err.... very.... much....
Will these new kits will fit the 2012-2013 690's ?
AccelRus MaxiMus is offline   Reply With Quote
Old 06-12-2013, 12:57 AM   #17
LukasM
Oddometer: 5,426
That's what KTMMitch has been saying, they are building new custom parts to extend the 2012/13 690 forks up to 300mm.
On the older forks it's easy because you can just swap in EXC internals.
Old 06-12-2013, 06:48 AM   #18
NovaMoto
Oddometer: 133
Re-springing both ends of this bike is near $400 before you even consider taming down the valving.
If you managed to buy new springs all around & pay someone to re-valve the front & install the works for 500$ OTD you got yourself one great deal!
Originally Posted by Albie View Post
Not if you find a good suspension shop that doesn't feel the need to rape you.
Revalve forks, and shock, respring shock (fork springs are way stiff enough for most riders), cost me less then $500 from SMS Racing.
NovaMoto is offline   Reply With Quote
Old 06-12-2013, 11:17 AM   #19
AccelRus MaxiMus
Oddometer: 144
The inner & outer tubes are definitely the same on all 690's & same as EXC
Good info - must mean a lot of overlap in the
690's - likely cross-compatibility saves on parts
and development as well
The tricky bit is getting the new damper rod to work with both the old EXC-type 690 fork,and the 2012-on 690 fork,which has a different lower fixing.But between us & tractive(we are dealing with the ex-WP guy who designed the 48mm WP fork!!) we seem to have come up with a kit that will work with both types.
Nice to work with guys who know the details !!
Looking forward to trying these out - and glad
they will work with the older and newer 690's
Great work !!
Old 07-01-2013, 03:47 AM   #20
gen
gen's Avatar
Oddometer: 804
Superplush rear shock and upgraded collar
Just received my new upgraded Superplush springs and rear shock collar.
I didn't take photos of the fork springs.
DoD#1458
gen screwed with this post 09-17-2013 at 08:04 AM
gen is offline   Reply With Quote
Old 07-01-2013, 04:56 AM   #21
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,718
$400 for springs They only cost $200 down here. Even with my fat ass though I didn't need to respring the front. Re-valving front and back was $200
Old 07-01-2013, 07:49 AM   #22
gen
gen's Avatar
Oddometer: 804
Springs cost about $150 for the forks and about the same for the shock. Not sure if your $200 price is for both ends or just one end?
The upgraded collar is not cheap but the OEM shock collar will most likely break with the heavier spring and then you've got to replace the whole shock. It's also a custom designed piece for the OEM shock, so it's not something that you can buy off the shelf from WP. Only SuperPlush and Rally Raid UK make upgraded shock collars afaik.
DoD#1458
Old 07-01-2013, 08:41 AM   #23
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,718
That's BOTH, hell Racetech springs are like a $115 for the front and $115 for the rear and that's full MSRP direct from them. My cost was $99 for the shock spring.
I've had my OEM shock collar with the heavy spring running on 6 years and probably 25K miles now and it still hasn't broken.
Old 07-01-2013, 09:36 AM   #24
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,017
gen: I see that you went with a 100nm rear spring, how much do you weigh?
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is offline   Reply With Quote
Old 07-01-2013, 10:00 AM   #25
gen
gen's Avatar
Oddometer: 804
125 kgs; it's what Sean at Superplush recommended.
DoD#1458
Old 07-03-2013, 02:34 PM   #26
bruceca2002 OP
Oddometer: 279
I want to change my front fork caps to the adjustable pre-load caps. Do I need to alter the 472mm spring length when I install the adjustable caps?
bruceca2002 is offline   Reply With Quote
Old 07-03-2013, 02:56 PM   #27
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 487
The bikes sag is about 1/2" and I am 240lbs so when I sit on the bike it sags maybe another 1/2" Is this typical? I'm guessing I need to loosen up the spring?
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 07-03-2013, 10:44 PM   #28
The Letter J
Oddometer: 1,017
No need to cut the springs, but the caps will add a few mm of preload even when they are backed all the way out... they are only intended to add preload to the stock setting, they cannot lessen it. FYI: 1" PVC pipe can be cut into any size you'd like and placed between the stock caps and springs to add preload, though if you think you'll have the need/want to regularly adjust preload, the caps are clearly the better option.
Old 09-16-2013, 11:17 AM   #29
Uller
Uller's Avatar
Oddometer: 1,681
http://www.rally-raidproducts.co.uk/...r-shock-rallye
-or-
http://www.rally-raidproducts.co.uk/...ktm-690-enduro
Uller is offline   Reply With Quote
Old 09-16-2013, 11:46 AM   #30
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
Any way to modify existing shock?
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Times are GMT -7.   It's 05:09 PM.
