Old 09-17-2013, 06:28 AM   #31
NickW909
NickW909's Avatar
Oddometer: 596
Rear Shock
I'm replacing the spring on the shock on my 2012 690 Enduro R.
Current spring - 220mm - 80Nm
New spring - 204mm - 95Nm
The supplier is checking if this is correct.
Any ideas? Should the stronger spring be shorter?
Thanks,
Nick.
NickW909 is online now   Reply With Quote
Old 09-17-2013, 08:02 AM   #32
gen
gen's Avatar
Oddometer: 804
Not if you want less suspension travel?
I think you want your new spring to be the same length as the OEM.
Also, if you are replacing the spring, you should seriously consider replacing the collar with a Rally Raid UK or Super Plush (US) aftermarket collar because the OEM collar has failed on a number of shocks with aftermarket springs.
see: http://www.advrider.com/forums/showp...3&postcount=26
DoD#1458
gen is offline   Reply With Quote
Old 09-17-2013, 08:06 AM   #33
NickW909
NickW909's Avatar
Oddometer: 596
I'm replacing the collar also.
This is what concerns me.
Shorter spring = less travel.
Is this correct?
Nick.
Sent from my GT-I9505 using Tapatalk 4
Old 09-17-2013, 08:16 AM   #34
LukasM
Oddometer: 5,427
Is this correct?
Only if you are running into coil bind before the shock bottoms out internally. Otherwise the spring length has no effect on the stroke/travel of the shock.
Old 09-17-2013, 08:41 AM   #35
NickW909
NickW909's Avatar
Oddometer: 596
Is this correct?
Nick.
Ok, thanks. That makes sense.
The piston can move 52mm before it touches the stopper.
The spring looks like it would compress 100mm.
So no worries....
Thanks,
Nick.
Old 09-19-2013, 11:09 PM   #36
DirtSolace
Oddometer: 96
adjustable rear shock control
"......Available in 250mm & 275mm wheel movements."
Mitch,
Two Questions?
1. Can you explain the criteria (function) for selecting between the two sizes which are offered?
2. Are the units you've received prototypes or are you selling units that have already (hopefully) had the "bugs" worked out?
thanx in advance--stan
DirtSolace is offline   Reply With Quote
Old 09-26-2013, 08:29 AM   #37
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 872
Originally Posted by Yellow Pig View Post
I'm getting mine put on this week and will test out the full 300mm Rally suspension this weekend.
I'll post up a performance report once I get some miles in.
Nice. Hey YP, when you redid your stock suspension, what size rear spring did you go with?
sdd04 is offline   Reply With Quote
Old 09-26-2013, 02:02 PM   #38
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,624
On the OEM I had an 8.4 N/m
If I remember correctly the OEM rear is marginally OK. It's the front that brutally harsh.
The RR I'm getting w/ a 9.5 N/m
Old 09-26-2013, 02:44 PM   #39
Hoots
Hoots's Avatar
Oddometer: 1,650
This will be great
I haven't been able to find much feedback
Hoots is offline   Reply With Quote
Old 09-26-2013, 05:10 PM   #40
sdd04
Oddometer: 872
Old 10-02-2013, 08:33 AM   #41
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,624
So I finally got the full 300mm Rally Raid suspension installed and tested.
I ran a fast 300 mile offroad loop on Sunday and must say I'm impressed. The Tractive suspension was very plush, floated over the rough stuff, but still kept from bottoming out in the whoops and jumps. I hit a 3->4 ft water bar at 30 mph and caught some decent air and still did not bottom out. The suspension handled it all very well.
I still need to play w/ the clickers a bit to get it 100% dialed in, but it's pretty close.
The one thing I will say is that you really have to want it. My new seat height at its lowest spot is 38".
I'm 5'10" with a 31" inseam and cannot touch the ground. I end up side saddling the bike to get a toe on the ground.
Old 10-02-2013, 08:37 AM   #42
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,624
Old 10-02-2013, 09:39 AM   #43
Uller
Uller's Avatar
Oddometer: 1,699
Originally Posted by Nowwhat View Post
Any way to modify existing shock?
Sorry, I just saw this. At first, I didn't think so. But....
I have read on here of a few who have worked with their suspension tuner to figure out how to get 300 mm out of the OEM Shock.
I am determined to get my suspension up to 300 mm and have contacted a very good suspension guy to see if he can figure this out for me.
It looks like the plan will be to go with 300 mm CC Forks and modify the OEM shock to 300 mm.
I'll keep this thread updated with the progress as it occurs.
Uller screwed with this post 10-08-2013 at 03:01 PM
Uller is online now   Reply With Quote
Old 10-02-2013, 10:03 AM   #44
Velociraptor
TrackBum
Oddometer: 1,139
I am waiting for the RR kit for the older forks. I got one of the Ohlins shocks through KTM twins-this was before RR came out with their shocks, and am happy with it but hard to really evaluate without decent front suspension. Honestly I doubt I need a lot more travel because I do not get airborne much. A plusher front is the main thing.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 10-02-2013, 02:29 PM   #45
Hoots
Hoots's Avatar
Oddometer: 1,650
The height thing was my concern ...
I'm a little taller, but not much ...
Do a fair bit of tight / steep stuff, and the bike is about as tall as I'm comfortable with ...
The height problem seems to be exacerbated by the wide seat - mine is a Seat Concepts adaptation - my 450 is actually taller than the 690, but far easier to get your feet down - I guess the 690's weight is the other factor, inasmuch as it feels OK to lean the 450 at a standstill whereas you don't want to lean the 690 with fuel +/- a bit of gear ...
All that aside, I'd like the 690 to feel like the 450 suspension-wise ...
Times are GMT -7.   It's 04:24 PM.
