Old 06-09-2013, 11:05 PM   #1
michaelc54 OP
Oddometer: 2
KTM640 LC4 Analogue Speedo Rebuild Info Required
Hi,
Had a hunt around but can't find anything on the above
I have a 1998 640 with the old, black plastic box style speedo
On run recently the odometer stopped working and the trip dials are full of dust. The speedo works fine
I want to open the box to clean out the inside and get the odo working again. I had a little prise around but decided to see if there was any higher knowledge here
Has anyone any experience of opening up the box?
In advance - Thanks
michaelc54 is offline   Reply With Quote
Old 06-10-2013, 06:47 AM   #2
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,446
Originally Posted by michaelc54 View Post
Hi,
In advance - Thanks
most likely your cable broke. i lost count of the number if times i broke mine before ditching the whole thing. as for ccleaning the box, just pull it off, remove the lights, and then fill with water and shake it out. i would not try and take it apart. let it air dry well, reinstall the lights and call it good.
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 06-11-2013, 08:07 AM   #3
Kawidad
Kawidad's Avatar
Oddometer: 5,064
I'm not sure about the water thing, unless it was distilled water (no spotting), but what I did was to remove the lights and blow into it with an air compressor. That seemed to work fairly well, not perfect, but pretty good.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Times are GMT -7.   It's 12:16 AM.
