Old 06-10-2013, 08:20 AM   #1
DIRT DERRICK OP
Oddometer: 11
690 enduro r missfire
Hi all,
I recently bought a 09 690r enduro. The bike was running fine and I have ridden it twice once off road.
It has a full akra system which needs sealing properly between the header and the mid section.
The bike started stalling at junctions and took a few seconds of cranking before it fired up.
I bought a rally raid petrol cap to try and stop mud getting in the tank. I also bought a new fuel filter thinking this may be the problem.
I have been away for a few weeks, got back and bike now will barely run, feels like crap in carb (if it had one!)
I have changed the filter inside the tank. This was filthy and quite difficult to blow through compared with the new one!
I thought I had cracked it!
But bike still runs just the same, I did notice the display and clock started flashing a few times while the bike was idaling, its almost as if the bike has a bad connection somwhere.
Any ideas?
I will post this in the off road and adventure section too
Thanks Neil
DIRT DERRICK is offline   Reply With Quote
Old 06-10-2013, 06:07 PM   #2
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Try a new FI filter and cleaning out the FI.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 06-11-2013, 02:51 AM   #3
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 976
Check connection to coil
KTM 690 R - "Its just a little crush..."
Bill the Bong is online now   Reply With Quote
Old 06-11-2013, 03:05 AM   #4
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,656
Dirty fuel injector?
CanadianX is offline   Reply With Quote
Old 06-11-2013, 04:01 AM   #5
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
fuel pumps known to go out too
MookieBlaylock is offline   Reply With Quote
Old 06-11-2013, 08:22 PM   #6
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,289
Its the fuel injector plugging up.
Clean it and run some injector cleaner in the fuel tank for a fill up and you will be good to go.
There is a very fine screen in the injector that clogs up.
Good luck!
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Times are GMT -7.   It's 10:36 AM.
