Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-10-2013, 11:11 PM   #1
JonesTheBiker OP
JonesTheBiker's Avatar
Oddometer: 4
KTM1190 Adventure - the Electronics
After 3 GS's and I just bought the 1190 to go with my 300EXC - excellent tool.
Just wondering if anyone has any tips on the electronics - specifically
1.Shift light - the rev limits that I set seem to be cleared each time I turn the bike off.
2. Do you know anyway of setting defaults for instance MTC - making it default to off ( it resets to on every time the bike is turned off)
3. And for the longer dirt trips it would be good to be able to get the ABS to default to Off-Road
Cheers
JonesTheBiker is offline   Reply With Quote
Old 06-10-2013, 11:34 PM   #2
AdvIvan
Rock on!
AdvIvan's Avatar
Oddometer: 111
Cheers
Hi there!
1. When I change my shift lights, they stay at my settings until I change them, unaffected by ignition. Sounds fishy!
2. To get the MTC to stay OFF or OFFROAD, you have to buy the Bad Fuel Dongle, which will let you drive with low octane fuel as well as save your ABS/MTC settings when torning off the bike.
3. Same as (2).
Have fun! I sure do!
AdvIvan is offline   Reply With Quote
Old 06-14-2013, 02:01 AM   #3
Bundu
Bundu's Avatar
Oddometer: 760
I've been told the shift light will only work to your own settings after the 1st service...... not sure if that is so, as I still need to do my 1st service
It has been discussed elsewhere, but on my bike, the DRL setting also resets when the ignition is turned off - very annoying!
Bundu is offline   Reply With Quote
Old 06-14-2013, 02:45 AM   #4
umitc
umitc's Avatar
Oddometer: 353
3. And for the longer dirt trips it would be good to be able to get the ABS to default to Off-Road Cheers
I was thinking the same; it's time consuming everytime struggling with the buttons to go back to Offroad ABS mode. Maybe Offroad ABS would be default, with the Offroad MTC.
umitc is offline   Reply With Quote
Old 06-14-2013, 10:51 PM   #5
paturoa
paturoa's Avatar
Oddometer: 270
Speedo error
On my R at 110 ks indicated my GPS reads 100 ks. WTF?
I'll inquire at the 1000 k service if the dealer app can do speedo tuning.
EDIT: Not sure on the error for the T model, but that guy who took a video at 270 ks was probably only doing 245ks
paturoa is offline   Reply With Quote
Old 06-14-2013, 11:36 PM   #6
paturoa
paturoa's Avatar
Oddometer: 270
Accesorey socket always on.
Has anyone got a wiring diagram yet? I'd be keen on changing the source for the acc socket to only power when the key is on.
Old 06-15-2013, 08:28 AM   #7
Bundu
Bundu's Avatar
Oddometer: 760
PM me....
Old 06-22-2013, 02:54 AM   #8
paturoa
paturoa's Avatar
Oddometer: 270
Originally Posted by Bundu View Post
PM me....
Done.
Old 06-23-2013, 02:05 AM   #9
Bundu
Bundu's Avatar
Oddometer: 760
I see the switched ACC2 connectors in the front and rear of the bike are labelled 1A max
I wonder if that is true, as there is no 1A fuse on the bike except if it has an electronic auto resetting fuse.....
Old 06-23-2013, 02:16 AM   #10
Katoom72
Katoom72's Avatar
Oddometer: 917
Almost every speedo does that
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 06-23-2013, 11:40 PM   #11
paturoa
paturoa's Avatar
Oddometer: 270
Looking at the diagram you sent, that is feed directly from the MCU pin 8. It is quite straight forward electronics to current limit or "electronically" fuse. Perhaps an email to the KTM peeps at head office to explain?
Oh and thanks heaps for the diagram. I'll insert a relay and control it off Acc2, which sounds like it is right next to the socket.
paturoa screwed with this post 06-23-2013 at 11:49 PM
Old 06-24-2013, 05:47 AM   #12
Tancakar
Tancakar's Avatar
Oddometer: 370
It might be nothing to with the electronics but a week ago I drop the bike 0 mph and the engine kills it self . This is very good safety feature ;) the bike is ok just a little scratch on the crash bar :) and the bag . Bike fall to the left .. .
Tancakar is offline   Reply With Quote
Old 06-24-2013, 06:17 AM   #13
Katoom72
Katoom72's Avatar
Oddometer: 917
roll over safety switch :)
Now:
Before:
Old 06-24-2013, 07:15 AM   #14
AdvIvan
Rock on!
AdvIvan's Avatar
Oddometer: 111
Mine didn't switch of. Not to the right, not to the left. And not to the left again
Old 06-24-2013, 07:25 AM   #15
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,350
Try dropping it to the right again, an even number of drops will reset the tipover sensor
Jaime
KTM 1190 Adv R
Jaimoto is online now   Reply With Quote
Times are GMT -7.   It's 05:30 PM.
