Old 06-11-2013, 12:15 AM   #1
pizellu OP
Oddometer: 43
Rear wheel stuck!!!
Hi everyone, after a long gearbox overhaul I went to try out my bike. I felt the bike slowing quickly when i leave the throttle. A bit of better inspection and i found out that the brakes were sticking!!! So i changed all the oil and brake lines( one split while bleeding) and even the brake pads were changed. Yesterday while cleaning the bike on the centre stand i checked the rear wheel!!!! Still really hard to turn by hand and the bike is dead heavy when i try to move it!!
Any tips or help would be greatly appreciated.
pizellu is offline   Reply With Quote
Old 06-11-2013, 12:20 AM   #2
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,753
Probably the piston is stuck in the brake caliper. Nothing to do but strip it down and clean it real good.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 06-11-2013, 03:37 AM   #3
koenig
koenig's Avatar
Oddometer: 117
Maybe, maybe not
Perhaps remove the rear caliper and rotate the wheel. Just to elimenate binding somewhere else in the drive train. Like a partly seized rear bearing perhaps?
If it doesn't hurt
Your not doing it right.
koenig is offline   Reply With Quote
Old 06-11-2013, 03:38 AM   #4
koenig
koenig's Avatar
Oddometer: 117
I can't believe I mis-spelled eliminate. Sorry.
If it doesn't hurt
Old 06-11-2013, 03:39 AM   #5
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,572
Undo the rear caliper (or push it with your foot so the pistons are retracted) and then turn the wheel and see how free it is.
That way you'll be able to see if the problem is with the brakes or somewhere else in the drive train.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 06-11-2013, 06:15 AM   #6
pizellu OP
Oddometer: 43
Rear wheel stuck
That seems the most logical thing to do, will check that way and revert. I hope that it's not the caliper cause I have just cleaned them and changed the brake lines too, anyway i will have to test first
Old 06-11-2013, 06:43 AM   #7
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,724
If I were you I would hope it IS the caliper. It is much cheaper and easier to fix than the next most likely cause, the driveshaft U-joints.
Jim
JimVonBaden is online now   Reply With Quote
Old 06-11-2013, 09:55 AM   #8
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 2,847
I need a donor driveshaft. we have a place here in O-lando that does every kind of driveshaft known to man in the auto/truck industry. they would love to see why they would not be able to do one of these.
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 06-11-2013, 10:59 AM   #9
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,172
I have one..and internal clip servicable u joints..my thinking is broach inside of yokes flat to accept clips..
Interested?
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 06-11-2013, 11:35 AM   #10
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,755
Interested?
Broaching? I might be inclined not to broach because an ear could bend. I would rather bore the yoke ear holes to size and machine the lock ring groove.
def is offline   Reply With Quote
Old 06-11-2013, 11:37 AM   #11
def
def's Avatar
Oddometer: 9,755
If you do a BMW driveshaft repair with your Orlando shop, please keep us up-to-date and report the success, price, level of customer service...and photos too please!
Old 06-11-2013, 11:46 AM   #12
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,172
These are internal clip joints..
Old 06-11-2013, 02:32 PM   #13
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 2,847
Is it for a 1200?
Interested?
-- Charles Kuralt
Old 06-11-2013, 02:57 PM   #14
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,172
Is it for a 1200?
Yes...
Old 06-11-2013, 03:04 PM   #15
def
def's Avatar
Oddometer: 9,755
You may have some rubber debris from the old brake lines that has gotten into the master cylinder or the caliper and is impeding the caliper piston from releasing pressure. You have some more work to do it would seem. Lots of compressed air and some cleaning solvent and you'll be fine.
Times are GMT -7.   It's 06:02 PM.
